#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <fcntl.h>
const char thermal_path[] = "/sys/class/thermal/thermal_zone0/temp";
int main(int argv, char *argc[])
int fd = 0;
int ret = 0;
int i;
char mbuf[128] = {0,};
float temp = 0.0;
fd = open(thermal_path, O_RDONLY);
if(fd < 0)
printf("open file[%s] failed\n", thermal_path);
return (0);
while(1)
memset(mbuf, 0, 128);
lseek(fd, 0, SEEK_SET);
ret = read(fd, mbuf, 128);
if(ret < 0)
printf("read file failed\n");
close(fd);
return (0);
temp = atof(mbuf);
temp = temp / 1000.0;
printf("thermel temp = %f\n", temp);
sleep(1);
close(fd);
return (0);
}共1条
板载温度计的采集
官方已经提供了温度计的实现,所以我们直接打开文件即可,前有两位网友使用cat命令来读取,楼主这里使用文件打开的方式读取,测试效果还是不错的,现将源代码分享出来,供大家借鉴:
关键词: 温度计 采集 imx6
共1条
