The MST43XXA series is a high input voltage (40V), low quiescent current, High PSRR linear regulator (LDO) able to provide 150mA load current.
The LDO features very fast response against line voltage transient and load current transient, and ensures no overshoot voltage during the LDO start up and short circuit recovery.
The device features integrated short-circuit and thermal shutdown protection.
The device is available with fixed output voltages of 3.0V, 3.3V, 3.6V and 5.0V, and available in SOT23 and SOT89 packages.
Application
Ø Battery-powered equipment
Ø Smoke detector and sensor
Ø Micro controller Applications
Ø Home Appliance
Features
Ø Low Quiescent Current:2uA
Ø High Input Voltage Rating:Up to 45V
Ø Output Current:150mA
Ø High PSRR:70dB at 1kHZ
Ø Dropout Voltage:70mV@10mA700mV@100mA
Ø Fixed Output Voltages:3.0V, 3.3V, 3.6V and 5.0V
Ø High VOUT accuracy : ±1%
Ø Good Transient Response
Ø Integrated Short-Circuit Protection
Ø Integrated Thermal Protection
Available Packages:
MST43XXATE MST43XXATE-A MST43XXATE-B MST43XXATE-C SOT23-3 MST43XXATS MST43XXATS-A MST43XXATS-B MST43XXATS-C SOT89-3 MST43XXATG SOT23-5
共1条
高输入电压(40V)、低静电流、高PSRR线性稳压器(LDO)MST43XXA
只看楼主 1楼
关键词: MST43XXA 稳压器 高输入 输入 电压 低静
共1条
有奖活动 | |
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
