![]() | The MST9220B is a high efficiency current-mode boostconverter with a fixed operation frequency. (MST9220B是一种工作频率固定的高效率电流型升压变换器) The MST9220B hasbeen integrated a very low Rds-on NMOS FET to reduce powerloss and achieve high efficiency. (MST9220B集成了一个非常低的Rds-on NMOS场效应晶体管,以减少功耗和实现高效) The maximum efficiency is upto 93%. The output Voltage can be programmed by feedbackresistances, and the maximum output voltage is 10V. (最大效率可达93%。输出电压可通过反馈电阻编程,最大输出电压为10V) MST9220B can output 2A current when VIN is higher than 3.3V and output is5V. (当VIN大于3.3V,输出为5v时,MST9220B可以输出2A电流。) 1.2MHz operation frequency minimizes L and C value, andinternal compensation network reduces external componentcounts. (1.2MHz的工作频率使L值和C值最小,内部补偿网络减少了外部组件数。) SOT23-6 package provides the best solution for PCB. (SOT23-6封装为PCB提供了最佳的解决方案。) 特点: ·Wide Input Range: 2.5-6V Input,(输入范围:2.5-6V输入,) ·MST9220B Up To 2A Output Current(MST9220B最大输出电流2A) · 1.2MHz Switching Frequency(1.2 mhz切换频率) · Low RDS(ON): 70mΩ · Up to 93% Efficiency(高达93%的效率) . Over Voltage Protection(过压保护) · Under-Voltage Lockout Protection(欠压保护) · Over-Temperature Protection(过温保护) · Internal Soft Start(内部软启动) ·1uA Shutdown Current · Accurate Reference: 0.6V VREF · Compact package: SOT23-6 |
共1条
高效率电流模式升压具有且固定工作频率的变频器MST9220
只看楼主 1楼
关键词: MST9220 高效率 电流 模式 升压 固定 频
共1条
有奖活动 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
