电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » STM32G070RB探测28-OLED显示天气(显示图标)
2021-03-07 22:48:06     打赏
如果要求不高的话其实这个小型天气气象站已经算完成了,但是,偏偏咱的要求有点高,既然有OLED屏幕了,咱就把天气图标给显示出来。先去找点好看的图标,使用的是心知天气,刚好心知天气提供的有图标包
可是经我下载,发现,不好看
也不简洁,并不适合单色屏,所以我去到了一个神奇的网站
阿里巴巴图标库
随便搜索一下,针不戳
就简单的凑了一套
哈哈(其实是前段时间做一个墨水屏的小型天气站时存货)
我这使用的是32*32像素,比较小,直接先制作一个试试吧
下载的还是PNG格式的,取模软件支持的也就是bmp格式,所以还要转换,麻烦哦,但是还要继续哦
还是需要pctolcd这个软件
先把图标转换为bmp格式,win10自带的画图就可以完成
打开,然后另存为
然后打开pctolcd软件,先调成图形模式
打开图标
很清楚
设置一下字模存放格式及取模格式
确认,点生成字模
复制,粘贴至头文件内
程序调用
sprintf(buf,"%s",weather);
OLED_Fill_ONE(4u,0x00);
OLED_P8x16Str(38u,4u,(uint8_t *)buf);
memset(buf, 0, sizeof(buf));
sprintf(buf,"Tem:%d",temperature);
OLED_Fill_ONE(6u,0x00);
OLED_P8x16Str(38u,6u,(uint8_t *)buf);
Draw_BMP(0u,4u,32u,8u,(uint8_t *)&BMP1);
就蛮好看的
下边就是繁琐的取模时刻
不多,也就40个(哭唧唧)
const unsigned char BMP1[][128] =
		0x00,0x00,0x00,0x00,0x30,0x70,0xE0,0xC0,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0xDF,
		0xDF,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0xC0,0xE0,0x70,0x30,0x00,0x00,0x00,0x00,
		0x80,0x80,0x80,0x80,0x00,0x00,0x80,0xF0,0xFC,0x1E,0x07,0x03,0x03,0x01,0x01,0x01,
		0x01,0x01,0x01,0x03,0x03,0x07,0x1E,0xFC,0xF0,0x80,0x00,0x00,0x80,0x80,0x80,0x80,
		0x01,0x01,0x01,0x01,0x00,0x00,0x01,0x0F,0x3F,0x78,0xE0,0xC0,0xC0,0x80,0x80,0x80,
		0x80,0x80,0x80,0xC0,0xC0,0xE0,0x78,0x3F,0x0F,0x01,0x00,0x00,0x01,0x01,0x01,0x01,
		0x00,0x00,0x00,0x00,0x0C,0x0E,0x07,0x03,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0xF3,
		0xF3,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x03,0x07,0x0E,0x0C,0x00,0x00,0x00,0x00},//0
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x38,0x78,
		0xF8,0xD8,0x38,0x38,0x70,0x70,0xE0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0xC3,0xFF,0xFF,0x00,0x00,0x00,0x00,0x01,0x07,0x1F,0xFE,0xF8,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xE0,0xE0,0x70,0x70,0x3C,0x1E,
		0x0F,0x03,0x00,0x00,0x00,0x00,0x00,0x80,0xE0,0xF8,0x7F,0x1F,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x01,0x03,0x07,0x07,0x0E,0x0C,0x1C,0x18,0x18,0x18,0x18,0x18,
		0x18,0x18,0x1C,0x1C,0x0C,0x0E,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//1
		0xF3,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x03,0x07,0x0E,0x0C,0x00,0x00,0x00,0x00},//2
		0x18,0x18,0x1C,0x1C,0x0C,0x0E,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//3
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,
		0xC0,0xE0,0x60,0x70,0x30,0x30,0x30,0x30,0x30,0x70,0x60,0xE0,0xC0,0x80,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xF0,0x70,0x38,0x18,0x18,0x1C,0x1C,0x1C,0x1F,
		0x1F,0x31,0x70,0xE0,0xE0,0xE0,0x60,0x60,0xE0,0xC0,0x80,0x00,0xE7,0xFF,0x7E,0x00,
		0x00,0xF0,0xF8,0x1C,0x0E,0x07,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x0F,0x1F,0xF9,0xF0,0x00,
		0x00,0x01,0x03,0x07,0x0E,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,
		0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0E,0x07,0x03,0x01,0x00},//4
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,
		0x00,0x00,0x00,0x70,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,
		0x00,0x00,0x00,0x80,0xC0,0xE0,0x60,0x60,0xE0,0xC0,0xE0,0x71,0x3B,0x3F,0x18,0x18,
		0x38,0x3C,0xFC,0xEE,0xCE,0x0E,0x0C,0x1C,0x78,0xF0,0xC3,0x07,0x03,0x01,0x00,0x00,
		0xF0,0xF8,0x3C,0x0F,0x0F,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x01,0x0F,0x0F,0x1C,0xF8,0xF8,0x1E,0xCF,0xC3,0x80,0x03,0x03,0x03,0x03,
		0x03,0x07,0x0F,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,
		0x0C,0x0C,0x0C,0x0C,0x0E,0x0E,0x07,0x03,0x00,0x00,0x01,0x03,0x01,0x00,0x00,0x00},//5
		0xE0,0xF0,0x30,0x38,0x18,0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x80,0xE0,0xF0,0x78,0x1C,0x1E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1C,0x1F,
		0x3B,0xF0,0xE0,0x80,0x80,0x01,0x03,0x07,0x0E,0x1C,0x18,0x18,0x38,0xF8,0xF8,0x78,
		0xF0,0xF8,0x1F,0x0F,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x01,0x01,0x03,0x87,0xFE,0xFC,0x04,0x0C,0x0E,0x06,0x07,0x03,0x01,0x00,
		0x01,0x03,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,
		0x06,0x06,0x06,0x06,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//6
		0x0C,0x0C,0x0C,0x0C,0x0E,0x0E,0x07,0x03,0x00,0x00,0x01,0x03,0x01,0x00,0x00,0x00},//7
		0x06,0x06,0x06,0x06,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//8
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,
		0xF0,0x70,0x30,0x38,0x38,0x30,0x70,0xF0,0xE0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x80,0xC0,0xC0,0xC0,0xF8,0xFC,0x1E,0x0E,0x07,0x07,0x03,0x07,0x07,0x0F,
		0x1C,0xF8,0xF0,0xC0,0xC0,0x80,0x00,0x00,0x07,0x0F,0x0F,0x0C,0x1C,0xFC,0xF8,0xE0,
		0x3C,0x7F,0xFF,0xC1,0x81,0x81,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
		0x80,0x80,0x80,0x81,0x81,0xC3,0xFF,0x7E,0x00,0x18,0x1C,0x1C,0x0C,0x0F,0x07,0x01,
		0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
		0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//9
		0x00,0x00,0x10,0x38,0x3C,0x98,0xC0,0xE0,0xE0,0x62,0x77,0xF7,0xF3,0xE0,0xE0,0xC0,
		0xD8,0xF8,0xF8,0x98,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x1C,0x1E,0x0C,0x80,0x8C,0xFF,0xFF,0xF9,0xFE,0x0F,0x07,0x03,0x03,0x01,0x01,0x01,
		0x01,0x01,0x01,0x03,0x03,0x07,0x3E,0x7C,0xF0,0xE0,0xE0,0xE0,0xC0,0x80,0x00,0x00,
		0xFC,0xFE,0xCF,0x87,0x03,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x81,0xE7,0xFF,0xFE,
		0x00,0x01,0x03,0xC3,0xF3,0x7F,0x3F,0x07,0x07,0x07,0x07,0x07,0x07,0xC7,0xF7,0x7F,
		0x3F,0x07,0x07,0x07,0x07,0x07,0x07,0xC7,0xF7,0x7F,0x3F,0x07,0x03,0x03,0x01,0x00},//10
		0x00,0x00,0x00,0x00,0x00,0x80,0xE0,0xF0,0x70,0x38,0x38,0x18,0x18,0x18,0x38,0x70,
		0xF0,0xE0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
		0xC0,0xE0,0xF0,0x70,0x3E,0x3F,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x01,0x03,0x01,0x01,0x00,0x00,0x01,0x03,0x3F,0x3F,0x3C,0x70,0xF0,0xE0,0xC0,
		0x1F,0x7F,0xF0,0xE0,0xC0,0xC0,0x80,0x80,0x00,0x80,0xE0,0xE0,0x40,0xC0,0xF0,0xF8,
		0xFC,0xDC,0xC0,0x00,0xC0,0xE0,0xE0,0x00,0x80,0x80,0xC0,0xC0,0xE0,0xF0,0x7F,0x1F,
		0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x03,0x07,0x03,0x01,0x00,0x08,0x1C,0x1F,
		0x0F,0x03,0x01,0x07,0x07,0x03,0x00,0x00,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00},//11
		0x1F,0x7F,0xF0,0xE0,0xC0,0xC0,0x80,0x00,0x00,0x80,0xC0,0xC0,0x00,0xC0,0xF0,0xF8,
		0xFC,0xDC,0xC0,0x00,0x80,0x80,0x80,0x80,0x00,0xC0,0xC0,0xC0,0xE0,0xF0,0x7F,0x1F,
		0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x07,0x07,0x07,0x01,0x00,0x08,0x1C,0x1F,
		0x0F,0x03,0x00,0x00,0x07,0x07,0x07,0x07,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x00},//12
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xE0,0xF0,0x30,0x38,0x1C,0x1C,0x1C,0x1C,
		0x1C,0x1C,0x1C,0x38,0x38,0x70,0xF0,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0xC0,0xE0,0xF0,0x38,0x1C,0x1C,0x1E,0x1F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x07,0x07,0x06,0x0E,0x0E,0x1C,0x78,0xF0,0xE0,
		0x0F,0x1F,0x3C,0x38,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,
		0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x38,0x1E,0x0F,0x07,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x78,0x7E,
		0x1E,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//13
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x78,0x7E,0x1E,0x06,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x20,0x78,0x7E,0x1E,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//14
		0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x78,0x3E,0x1E,0x06,0x00,0x00,0x00,0x70,0x7C,
		0x1E,0x0E,0x00,0x00,0x00,0x60,0x78,0x3E,0x1E,0x06,0x00,0x00,0x00,0x00,0x00,0x00},//15
		0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF0,0xF8,0x3C,0x0E,0x0E,0x07,0x07,0x07,0x07,
		0x07,0x07,0x07,0x07,0x0E,0x1E,0xFC,0xF8,0xE0,0x80,0x80,0x80,0x00,0x00,0x00,0x00,
		0xF0,0xFC,0x3E,0x0E,0x07,0x07,0x07,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x03,0x03,0x07,0x9F,0xFE,0xFC,
		0x03,0x07,0x0F,0x0E,0x0C,0x0C,0x8C,0x8C,0x0C,0x0C,0x0C,0x8C,0x8C,0x8C,0x0C,0x0C,
		0x0C,0x8C,0x8C,0x0C,0x0C,0x8C,0xCC,0x8C,0x0C,0x0C,0x8E,0x8E,0x0E,0x07,0x03,0x01,
		0x00,0x00,0x00,0x00,0x0E,0x0F,0x07,0x03,0x10,0x3C,0x1F,0x0F,0x03,0x60,0x78,0x3E,
		0x1F,0x07,0x01,0x38,0x3E,0x1F,0x07,0x01,0x0C,0x0F,0x07,0x03,0x00,0x00,0x00,0x00},//16
		0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF0,0xF8,0x3C,0x1E,0x0E,0x07,0x07,0x03,0x03,
		0x03,0x07,0x07,0x07,0x0E,0x1E,0xFC,0xF8,0xE0,0x80,0x80,0x80,0x00,0x00,0x00,0x00,
		0xF0,0xFC,0x1E,0x0E,0x07,0x07,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x01,0x07,0x0F,0x0E,0x0C,0x0C,0x8C,0x0C,0x8C,0xEC,0xEC,0x8C,0x0C,0x0C,0xCC,0xEC,
		0x6C,0x8C,0x0C,0x8C,0xEC,0x6C,0x8C,0x0C,0x8C,0xEC,0xEC,0x0E,0x0E,0x07,0x07,0x01,
		0x00,0x00,0x00,0x00,0x0C,0x0F,0x03,0x00,0x33,0x3D,0x1F,0x07,0x0F,0x6F,0x7B,0x1E,
		0x0F,0x0F,0x2F,0x3F,0x3F,0x0F,0x03,0x00,0x03,0x1D,0x1E,0x07,0x00,0x00,0x00,0x00},//17
		0x0F,0x0F,0x2F,0x3F,0x3F,0x0F,0x03,0x00,0x03,0x1D,0x1E,0x07,0x00,0x00,0x00,0x00},//18
		0x03,0x07,0x0F,0x0E,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xCC,0xEC,0xCC,0x0C,
		0x0C,0x0C,0x0C,0x0C,0x0C,0xCC,0xCC,0xCC,0x0C,0x0C,0xCE,0xEE,0xEE,0x07,0x03,0x01,
		0x00,0x00,0x00,0x00,0x38,0x3E,0x1F,0x07,0x00,0x00,0x04,0x0F,0x07,0x01,0x00,0x38,
		0x3E,0x1F,0x07,0x1C,0x1C,0x19,0x01,0x01,0x0C,0x0E,0x0C,0x00,0x00,0x00,0x00,0x00},//19
		0x03,0x07,0x0F,0x0E,0x0C,0x0C,0x0C,0x0C,0x0C,0x8C,0x8C,0x0C,0x0C,0x0C,0x0C,0x0C,
		0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x8C,0x8C,0x0C,0x0E,0x0E,0x0E,0x07,0x03,0x01,
		0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x1C,0x1F,0x0F,0x03,0x00,0x00,0x1B,0x1F,0x1E,
		0x1E,0x1F,0x1B,0x00,0x00,0x1C,0x1F,0x0F,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//20
		0x00,0x00,0x18,0x3C,0x3C,0x98,0xC0,0xE0,0xE0,0x72,0x77,0xF7,0xF3,0xE0,0xE0,0xC0,
		0xD8,0xFC,0xBC,0x98,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x1C,0x1E,0x0C,0x80,0x9E,0xFF,0xFF,0xFD,0x3E,0x0F,0x07,0x03,0x03,0x01,0x01,0x01,
		0x01,0x01,0x01,0x03,0x03,0x0F,0x3E,0x7C,0xF0,0xE0,0xE0,0xC0,0xC0,0x80,0x80,0x00,
		0xFC,0xFE,0xCF,0x03,0x03,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x81,0xC7,0xFF,0xFE,
		0x00,0x01,0x03,0x03,0x07,0x07,0xFF,0xFF,0xF7,0xFF,0xDF,0x07,0x07,0x07,0xFF,0xFF,
		0xF7,0xFF,0xDF,0x07,0x07,0x07,0xFF,0xFF,0xF7,0xFF,0xDF,0x03,0x03,0x03,0x01,0x00},//21
		0x03,0x07,0x0F,0x0E,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xCC,0xCC,
		0x8C,0x8C,0xCC,0x8C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0E,0x0E,0x0E,0x07,0x03,0x01,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0D,0x0F,
		0x07,0x0F,0x0F,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//22
		0x03,0x07,0x0F,0x0E,0x0C,0x0C,0x0C,0x0C,0x0C,0xCC,0xCC,0x8C,0x8C,0xCC,0xCC,0x0C,
		0x0C,0x0C,0x0C,0xCC,0xCC,0x8C,0x8C,0xCC,0xCC,0x0C,0x0E,0x0E,0x0E,0x07,0x03,0x01,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x0F,0x07,0x07,0x0F,0x0E,0x00,
		0x00,0x00,0x00,0x0D,0x0F,0x07,0x07,0x0F,0x0D,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//23
		0x03,0x07,0x0F,0x0E,0xCC,0xCC,0x8C,0x8C,0xCC,0xCC,0x0C,0x0C,0x0C,0xCC,0xCC,0x8C,
		0x8C,0xCC,0xCC,0x0C,0x0C,0x0C,0x8C,0xCC,0x8C,0x8C,0xCE,0xCE,0x0E,0x07,0x03,0x01,
		0x00,0x00,0x00,0x00,0x0D,0x0F,0x07,0x07,0x0F,0x0C,0x00,0x00,0x00,0x0D,0x0F,0x07,
		0x07,0x0F,0x0D,0x00,0x00,0x00,0x0C,0x0F,0x0F,0x07,0x0F,0x0D,0x00,0x00,0x00,0x00},//24
		0x01,0x07,0x0F,0xCE,0xCC,0xCC,0xCC,0xCC,0x0C,0x0C,0x0C,0x0C,0x0C,0xCC,0xCC,0xCC,
		0xCC,0xCC,0xCC,0x0C,0x0C,0x0C,0x0C,0x0C,0xCC,0xCC,0x8C,0xCE,0xCE,0x07,0x07,0x01,
		0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x06,0x36,0x3E,0x3C,0x3E,0x3E,0x06,0x07,0x07,
		0x07,0x07,0x06,0x3E,0x3E,0x3C,0x3E,0x3E,0x06,0x07,0x07,0x07,0x07,0x00,0x00,0x00},//25
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xCC,0xDE,0x8C,0x00,0x00,0x00,0x38,
		0x38,0x30,0x00,0x00,0x8C,0xDE,0xCC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x70,0x71,0x71,0x70,0x70,0x70,0x70,0x77,
		0x77,0x73,0x70,0x70,0x70,0x71,0x71,0x70,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//26
		0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,
		0x00,0x00,0x80,0x80,0xC0,0xC0,0xC0,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0xC1,0xC3,0xC3,0x00,0x1C,0x1C,0x18,0x00,0xC3,0xC3,0x00,0x00,0x3C,
		0x3E,0x07,0x03,0x01,0x01,0x01,0x01,0x01,0x01,0x03,0xFF,0xFE,0x70,0x00,0x00,0x00,
		0x00,0x00,0x00,0x08,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,
		0x0C,0x0C,0x0C,0x0C,0x0C,0x1C,0x0C,0x0C,0x0E,0x07,0x03,0x01,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x01,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
		0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x01,0x00,0x00,0x00},//27
		0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0x80,0x00,0x00,0x80,0xC0,0xC0,0x00,0x00,0x00,
		0xC0,0xE0,0x60,0x60,0xE0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x08,0x99,0x99,0x99,0x18,0x18,0x99,0x99,0x99,0x98,0x98,0x98,
		0x98,0x98,0x98,0x9C,0x9C,0x8F,0x87,0x80,0x8C,0xFC,0xFC,0x70,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x10,0x9B,0x9B,0x19,0x18,0x19,0x19,0x99,0x99,0x19,0x19,0x19,
		0x99,0x99,0x99,0x19,0x19,0x19,0x19,0x19,0x39,0xF9,0xF0,0xC0,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x00,0x00,0x03,0x03,0x03,0x00,0x00,0x00,
		0x03,0x03,0x03,0x00,0x01,0x03,0x07,0x06,0x06,0x07,0x03,0x01,0x00,0x00,0x00,0x00},//28
		0x03,0x03,0x03,0x00,0x01,0x03,0x07,0x06,0x06,0x07,0x03,0x01,0x00,0x00,0x00,0x00},//29
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xF0,0x78,0x1C,0x0C,0x0E,0x0E,0x0E,
		0x0E,0x0E,0x0E,0x1C,0x38,0xF8,0xE0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0xC0,0xF8,0xFC,0x0E,0x0E,0x07,0x07,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x06,0x0E,0x1C,0xF8,0xF0,0x00,0x00,
		0x00,0x00,0x07,0x0F,0x1C,0x1C,0x18,0x38,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,
		0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x38,0x18,0x1C,0x0E,0x07,0x03,0x00,0x00,
		0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x77,0x77,0x77,0x77,0x77,0x77,0x70,0x70,
		0x70,0x70,0x77,0x77,0x77,0x77,0x27,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07},//30
		0x00,0x20,0x78,0x78,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x78,
		0x78,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x78,0x78,0x30,0x00,
		0x00,0xC0,0xF0,0xF8,0x3C,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1E,0x3C,0xF8,0xF0,
		0xE0,0xF8,0x3C,0x1C,0x0E,0x0E,0x0E,0x06,0x0E,0x0E,0x0E,0x3C,0xF8,0xF0,0xE0,0x00,
		0x00,0x01,0x0F,0x1F,0x3C,0x78,0x70,0x70,0x70,0x70,0x70,0x78,0x38,0x3C,0x1F,0x0F,
		0x07,0x0F,0x1E,0x38,0x78,0x70,0x70,0x70,0x70,0x70,0x78,0x3C,0x1F,0x0F,0x07,0x00,
		0x00,0x04,0x0E,0x1E,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0E,
		0x1E,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x00},//31
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xF0,0x78,0x38,0x38,
		0x38,0xF0,0xE0,0xC0,0x00,0x00,0x80,0xC0,0xE0,0xE0,0xE0,0xE0,0xC0,0xC0,0x80,0x00,
		0x18,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,0xB8,
		0x9C,0x9F,0x8F,0x87,0x80,0x87,0x87,0x81,0x80,0x80,0x80,0xC0,0xE3,0xFF,0x7F,0x0C,
		0x19,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,
		0x1D,0x1D,0x1D,0x1D,0x1D,0x1D,0x39,0xF9,0xF1,0xE1,0x01,0x01,0x01,0x00,0x00,0x00,
		0x00,0x07,0x0F,0x1E,0x1C,0x1C,0x1C,0x0F,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00},//32
		0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0xE0,0xE0,0xE0,0xEC,0xEC,0xEC,0xEC,0xEC,
		0xEC,0xEC,0xEC,0xEC,0xEC,0xEC,0xEC,0x60,0x70,0x3F,0x1F,0x06,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x02,0x07,0x07,0x07,0x17,0x37,0x37,0x37,0x37,0x37,0x37,0x37,
		0x37,0xF7,0xE7,0xC7,0x07,0x07,0x07,0x06,0x8E,0xFC,0xF8,0x60,0x00,0x00,0x00,0x00,
		0x07,0x07,0x03,0x01,0x07,0x07,0x07,0x07,0x03,0x03,0x01,0x00,0x00,0x00,0x00,0x00},//33
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,
		0x80,0x80,0x80,0x00,0x20,0x70,0x70,0x70,0x70,0x70,0xE0,0xE0,0xC0,0x00,0x00,0x00,
		0x00,0x00,0x00,0x70,0x70,0x70,0x70,0x70,0x70,0x73,0x73,0x73,0x73,0x73,0x73,0x73,
		0x73,0x73,0x73,0x71,0x70,0x70,0x70,0x70,0x70,0x70,0x39,0x3F,0x1F,0x07,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x38,0x38,
		0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x78,0xF0,0xF0,0xE0,0x00,0x00,
		0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x08,0x1C,0x1C,0x1C,0x1E,0x1E,0x0F,0x07,0x03,0x00,0x00},//34
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x60,0x70,0x70,0x70,0x70,0x70,0x70,0xE0,
		0xD8,0x9C,0x3C,0x38,0xF0,0xE0,0xC0,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x60,0xF0,0x78,0x3C,0x8E,0xCE,0xC7,0x07,0x07,0x06,0x00,0x00,0x00,0x00,
		0x01,0x01,0x00,0x00,0x00,0x0F,0x0F,0x07,0x80,0xFF,0xFF,0x7E,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x7E,0xFF,0xFF,0x01,0xE0,0xF0,0xF0,0x00,0x00,0x00,0x80,0x80,
		0x00,0x00,0x00,0x00,0x60,0xE0,0xE0,0xE3,0xF3,0x71,0x7C,0x3F,0x0F,0x06,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x03,0x07,0x0F,0x1C,0x3C,0x39,0x13,
		0x07,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x06,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//35
		0xE0,0xF0,0x38,0x1C,0x0C,0x0E,0x06,0x06,0x07,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
		0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x07,0x06,0x06,0x0E,0x0C,0x18,0x38,0xE0,0xC0,
		0x01,0x03,0x07,0x0E,0x7C,0xFC,0xD8,0x98,0xB8,0x30,0x30,0x30,0x30,0x30,0x30,0x30,
		0x20,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x18,0x18,0x9C,0x8C,0xCE,0xE7,0x73,0x30,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x0F,0x1F,0x1B,0x33,0xB2,0xE6,0x66,0x66,
		0x46,0xC6,0xC6,0xC6,0xC6,0x46,0x66,0x66,0x63,0x63,0x73,0x31,0xB9,0x9E,0x0C,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x07,0x06,
		0x76,0x6C,0xCC,0xCC,0x8C,0x8C,0x8C,0x8C,0xCC,0xCC,0xC6,0xE6,0x77,0x33,0x00,0x00},//36
		0x00,0x00,0x00,0x00,0x00,0x00,0x40,0xC0,0x80,0xC0,0xC0,0x00,0x00,0x20,0x70,0xF8,
		0xF8,0x60,0x20,0x00,0x00,0x00,0xC0,0x80,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x80,0x80,0xE0,0xE0,0xC2,0x83,0x83,0x87,0x8C,0x98,0xF0,0x30,0x3F,
		0x3F,0x30,0xF0,0xF8,0x9C,0x8E,0x87,0x83,0x83,0xC2,0xE0,0x80,0x80,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x06,0x03,0xE1,0xE0,0xE0,0xF0,0x38,0x1D,0x0F,0x04,0xFC,
		0xFC,0x0C,0x0F,0x1F,0x38,0xF0,0xE0,0xE0,0xE1,0x03,0x07,0x02,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x01,0x01,0x01,0x00,0x00,0x04,0x06,0x1F,
		0x1F,0x06,0x04,0x00,0x00,0x01,0x01,0x01,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x00},//37
		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC6,0xFC,0xF8,
		0xF0,0xE0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xE0,0xF0,0xF8,0xF8,0xFC,0xFE,0xFF,0xFF,0xFF,
		0xFF,0xFF,0xFF,0xFF,0xB8,0xC0,0xF8,0xF0,0xE0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x3C,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
		0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1E,0x00,0x00,0x00,0x00,0x00,
		0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x07,0x0F,0x1F,0x1F,0x3F,0x3F,0x3F,0x3F,0x3F,
		0x3F,0x3F,0x3F,0x3F,0x1F,0x0F,0x0F,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//38
		0xF3,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x03,0x07,0x0E,0x0C,0x00,0x00,0x00,0x00},//39
因为99跟0一样,所以就不取模了,这里建一个二级数组,直接简单写两句代码就行了
if(code == 99)
	code = 1;
Draw_BMP(0u,4u,32u,8u,(uint8_t *)&BMP1[code]);
成果秀
对比一下
还不错
