电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 用PIC单片机的硬件PWM单元产生的正弦波效果还不错哦!
2021-07-06 23:12:44     打赏
用PIC单片机的PWM生产一个频率和幅值可调的正弦波,先看效果~
主要源码如下:
#include "Head.h"
void main (void)
     OSCCON=0b11110000;
     TRISD=0;
     PORTD=0;
     TRISC=0b10000000;
     OPTION_REG=0b10001000;
     INTCON=0b11100000;
     PIE1=0b00100000;//开串口中断
     CCP1CON=0b00001100;
     PR2=255;
     T2CON=0b00000100;//  最大脉冲宽度 4*(255+1)=1024
     TXSTA=0b00100100;     //SYNC=0;BRGH=1;
     RCSTA=0b10010000;
     BAUDCON=0b00001000;   //BRG16=1;
     SPBRGH=0;
     SPBRG=207;            //FOSC/[4(n+1)] (32000000/38400)/4-1=207
     while(1)
      Send();
//定时器中断程序
void interrupt TMR0INT(void)//4/32*256=32us
    static unsigned char a=0,b=0,c=0;
    static unsigned int pwm_duty=0;
    const unsigned int pwm_1[PI_data]={0,13,25,37,50,62,74,85,96,107,118,127,137,146,154,162,
    169,175,181,186,190,194,196,198,200,200,200,198,196,194,190,186,
    181,175,169,162,154,146,137,127,118,107,96,85,74,62,50,37,
    25,13};
    const unsigned int pwm_2[PI_data]={0,31,63,94,124,155,184,213,241,268,294,319,342,364,385,405,
    422,438,452,465,476,484,491,496,499,500,499,496,491,484,476,465,
    452,438,422,405,385,364,342,319,294,268,241,213,184,155,124,94,
    63,31};
    const unsigned int pwm_3[PI_data]={0,63,125,187,249,309,368,426,482,536,588,637,685,729,771,809,
    844,876,905,930,951,969,982,992,998,1000,998,992,982,969,951,930,
    905,876,844,809,771,729,685,637,588,536,482,426,368,309,249,187,
    125,63};
    if(T0IF)
        T0IF=0;
        LATD6^=1;
        if(++a==Pwm_frequency)  //1000000/(Pwm_frequency*32*50)=频率HZ  1000000/(6*32*50)=104HZ
          a=0;
          if(++b==PI_data)b=0;
          switch(c)
             case 1:  {pwm_duty=pwm_1[b];break;}
             case 2:  {pwm_duty=pwm_2[b];break;}
             case 3:  {pwm_duty=pwm_3[b];break;}
             default: {pwm_duty=pwm_1[b];break;}
          }  CCP1CON=(CCP1CON&0xcf)|((pwm_duty&3)<<4);CCPR1L=pwm_duty>>2;
   if(RCIF)
      static unsigned char temp=0;
      if(OERR==1){CREN=0;asm("nop");CREN=1;}
      temp=RCREG;
      switch(temp)
        case 'a':{Pwm_frequency++;break;}//频率加
        case 'b':{if(Pwm_frequency)Pwm_frequency--;break;}//频率减
        case 'c':{c++;if(c>3)c=1;break;}//振动幅度
关键词: 正弦波     PWM
