电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 【转载】如何高效解析不定长度的协议帧--from嗷呜
2023-01-09 13:16:13     打赏
通信设计中考虑协议的灵活性,经常把协议设计成“不定长度”。一个实例如下图:锐米LoRa终端的通信协议帧。
如果一个系统接收上述“不定长度”的协议帧,将会有一个挑战--如何高效接收与解析。
为简化系统设计,我们强烈建议您采用“状态机”来解析UART数据帧,并且把解析工作放在ISR(中断服务程序)完成,仅当接收到最后一个字节(0x0D)时,再将整个数据帧提交给进程处理。
该解析状态机的原理如下图所示:
那么ISR处理这个状态机来得及吗?答案是:so easy!因为它只有3个动作,运算量十分小:
比较接收数据 -> 更新状态变量 -> 存储接收数据,C语言仅3条语句,翻译成机器指令也不超过10条。
代码清单如下:
* @brief  Status of received communication frame
typedef enum
    STATUS_IDLE = (uint8_t)0,
    STATUS_HEAD, /* Rx Head=0x3C */
    STATUS_TYPE, /* Rx Type */
    STATUS_DATA, /* Data filed */
    STATUS_TAIL, /* Tail=0x0D */
    STATUS_END, /* End of this frame */
} COMM_TRM_STATUS_TypeDef;
* @brief  Data object for received communication frame
typedef struct
    uint8_t    byCnt; /* Count of 1 field */
    uint8_t    byDataLen; /* Length of data field */
    uint8_t    byFrameLen; /* Length of frame */
    COMM_TRM_STATUS_TypeDef    eRxStatus;
    uint8_t    a_byRxBuf[MAX_LEN_COMM_TRM_DATA];
} COMM_TRM_DATA;
* @brief  Data object for received communication frame.
* @note  Prevent race condition that accessed by both ISR and process.
static COMM_TRM_DATA    s_stComm2TrmData;
  * @brief  Put a data that received by UART into buffer.
  * @note  Prevent race condition this called by ISR.
  * @param  uint8_t byData: the data received by UART.
  * @retval  None
void comm2trm_RxUartData(uint8_t byData)
    /* Update status according to the received data */
    switch (s_stComm2TrmData.eRxStatus)
        case STATUS_IDLE:
            if (COMM_TRM_HEAD == byData) /* Is Head */
                s_stComm2TrmData.eRxStatus = STATUS_HEAD;
            else
                goto rx_exception;
            break;
        case STATUS_HEAD:
            if (TYPE_INVALID_MIN < byData && byData < TYPE_INVALID_MAX) /* Valid type */
                s_stComm2TrmData.eRxStatus = STATUS_TYPE;
            else
                goto rx_exception;
            break;
        case STATUS_TYPE:
            if (byData <= MAX_LEN_UART_FRAME_DATA) /* Valid data size */
                s_stComm2TrmData.eRxStatus = STATUS_DATA;
                s_stComm2TrmData.byDataLen = byData;
            else
                goto rx_exception;
            break;
        case STATUS_DATA:
            if (s_stComm2TrmData.byCnt < s_stComm2TrmData.byDataLen)
                ++s_stComm2TrmData.byCnt;
            else
                s_stComm2TrmData.eRxStatus = STATUS_TAIL;
            break;
        case STATUS_TAIL:
            if (COMM_TRM_TAIL == byData)
                /* We received a frame of data, now tell process to deal with it! */
                process_poll(&Comm2TrmProcess);
            else
                goto rx_exception;
            break;
        default:
            ASSERT(!"Error: Bad status of comm2trm_RxUartData().\r\n");
            break;
    /* Save the received data */
    s_stComm2TrmData.a_byRxBuf[s_stComm2TrmData.byFrameLen++] = byData;
    return;
rx_exception:
    ClearCommFrame();
    return;
转载自网络,如有侵权,联系删除。
