电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » IPQ6018/Qualcomm-Atheros IPQ6010CPUindus
IPQ6018/Qualcomm-Atheros IPQ6010CPUindustrialwifirouterDR6018SHighpowerWallys
2023-02-07 10:17:52     打赏
IPQ6018/Qualcomm-Atheros IPQ6010 CPU industrial wifi router DR6018S High power Wallys
IPQ6018
IPQ6018 is the latest generation OF IPQ6000 series WiFi access point/wireless router solution launched by Qualcomm, a leading WLAN chip manufacturer in the industry. It supports WiFi5, also known as IEEE802.11ax. The chipset consists of WiFi subsystem, network processing subsystem and CPU subsystem. Different from the previous generation of 802.11AC Wave2 schemes such as IPQ4018 and IPQ4019, IPQ6018 does not integrate the RF part of WiFi, but adopts the separation of rf and baseband, which is estimated to reduce the heat of the chipset.
IPQ6018 has rich peripheral interfaces, which can meet various business needs and evolve into a variety of product forms. IPQ6018 have a PCIe three generation of interface, a USB 3.0 interface, a USB 2.0 interface, SPI/I2C/UART serial interface (optional), 2 SDIO interface, I2S/TDM/PCM/PDM/Soundwire interface. IPQ6018 supports 16/32 DDR3L/4, up to 1866/2133MT/s, and supports parallel NAND Flash and serial NOR Flash. In addition, IPQ6018 also supports advanced power management with low operating and standby power consumption, making it ideal for carrier gateways and enterprise-class wireless aps.
WiFi subsystem
The antenna configuration 5GHz: 2 x 2 MIMO, 80MHz channel bandwidth
2.4GHz: 2 x 2 MIMO, 40MHz channel bandwidth
802.11 ac mode The physical layer speed of the 5GHz band can reach 866.7Mbps
The physical layer speed in the 2.4GHz band can reach 400Mbps
Support su-MIMO and MU-MIMO 3.2US
OFDM symbol length 0.4us and 0.8us protection interval
802.11 ax mode The physical layer speed of the 5GHz band can reach 1201Mbps
The physical layer speed of the 2.4GHz band can reach 573.5Mbps
Supports SU-MIMO, upstream and downstream MU-MIMO, and upstream and downstream OFDMA
12.8 US symbol length 0.8us, 1.6us and 3.2us protection interval
802.11 a/b/g/n support
Network subsystem
IPQ6018's network subsystem is a high-performance, high-throughput programmable network processing engine, which can greatly reduce the burden of the main processor and is very suitable for carrier paid services, such as voice calls and video calls, which can ensure zero packet loss. IPQ6018 has two SerDes interfaces for connecting to external Ethernet PHY. One SerDes interface supports 6.25/5/3.125/1.25Gbps and works in PSGMII, QSGMII, SGMII+, or SGMII modes. Another SerDes interface can work in SGMII+ or SGMII mode.
CPU subsystem
ARM Cortex A53, 1.8ghz, quad-core
32KB/32KB I$/D$, 512KB L2$
Supports 64-bit floating point arithmetic and NEON SIMD DSP extensions for enhanced audio, voice, and video processing capabilities
Support encryption instruction
Peripheral interface
One PCI Express 3g interface
One USB 3.0 port
One USB 2.0 port
Multiple optional serial interfaces: SPI, UART, I2C
Parallel NAND and display interface
Serial NOR Flash interface
SD/eMMC interface
Supports 16/32 DDR3L (1800MT/s) or DDR4 (2133MT/s)
Below the info for your quick knowledge of Wallys routerboard DR6018-S
DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
Processor with Quad-core ARM 64bit A53 @1.8GHz
System Memory with 1GB DDRL3L
8MB NOR Flash, 256MB NAND Flash
Dynamic Frequency Selection (DFS) Supported
Other details:
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
For more information for DR6018,please click below the link
https://www.wallystech.com/Routerboard/DR6018-S-V02-wifi6-Qualcomm-IPQ6010-2T2R-2-GE-port-supporting-QCN9074-wifi-card-802.11AX-MU-MIMO-OFDMA.html
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Email us by sales1@wallystech.com
Visit our website:https://www.wallystech.com/
关键词: IPQ6018     Qualcomm-Atheros
