结果输出为1,这种操作方式保证了当前的Matlab实体可以用于通信。 在winwrp界面,为增加和使用Matlab类型的目录库,我们需要如下步骤:1. 在FRED脚本编辑界面找到参考.2. 找到Matlab Automation Server Type Library3. 将名字改为MLAPP 在Matlab里面有两种常用的数据发送选项PutWorkspaceData 及PutFullMatrix,PutWorkspaceData适用于存储一般的数据在工作区,并赋予其为变量,PutFullMatrix试用于复数数据。
图 编辑/参考
现在将脚本代码公布如下,此脚本执行如下几个步骤:1. 创建Matlab服务器。2. 移动探测面对于前一聚焦面的位置。3. 在探测面追迹光线4. 在探测面计算照度5. 使用PutWorkspaceData发送照度数据到Matlab6. 使用PutFullMatrix发送标量场数据到Matlab中7. 用Matlab画出照度数据8. 在Matlab计算照度平均值9. 返回数据到FRED中 代码分享: Option Explicit Sub Main Dim ana As T_ANALYSIS Dim move As T_OPERATION Dim Matlab As MLApp.MLApp Dim detNode As Long, detSurfNode As Long, anaSurfNode As Long Dim raysUsed As Long, nXpx As Long, nYpx As Long Dim irrad() As Double, imagData() As Double, reals() As Double, imags() As Double Dim z As Double, xMin As Double, xMax As Double, yMin As Double, yMax As Double Dim meanVal As Variant Set Matlab = CreateObject("Matlab.Application") ClearOutputWindow 'Find the node numbers for the entities being used. detNode = FindFullName("Geometry.Screen") detSurfNode = FindFullName("Geometry.Screen.Surf 1") anaSurfNode = FindFullName("Analysis Surface(s).Analysis 1") 'Load the properties of the analysis surface being used. LoadAnalysis anaSurfNode, ana 'Move the detector custom element to the desired z position. z = 50 GetOperation detNode,1,move move.Type = "Shift" move.val3 = z SetOperation detNode,1,move Print "New screen position, z = " &z 'Update the model and trace rays. EnableTextPrinting (False) Update DeleteRays TraceCreateDraw EnableTextPrinting (True) 'Calculate the irradiance for rays on the detector surface. raysUsed = Irradiance( detSurfNode, -1, ana, irrad ) Print raysUsed & " rays were included in the irradiance calculation. 'When using real number data to send to MATLAB, it is simplest to use PutWorkspaceData. Matlab.PutWorkspaceData("irradiance_pwd","base",irrad) 'PutFullMatrix is more useful when actually having complex data such as with 'scalar wavefield, for example. Note that the scalarfield array in MATLAB 'is a complex valued array. raysUsed = ScalarField ( detSurfNode, -1, ana, reals, imags ) Matlab.PutFullMatrix("scalarfield","base", reals, imags ) Print raysUsed & " rays were included in the scalar field calculation." 'Calculate plot characteristics from the T_ANALYSIS structure. This information is used 'to customize the plot figure. xMin = ana.posX+ana.AcellX*(ana.Amin-0.5) xMax = ana.posX+ana.AcellX*(ana.Amax+0.5) yMin = ana.posY+ana.BcellY*(ana.Bmin-0.5) yMax = ana.posY+ana.BcellY*(ana.Bmax+0.5) nXpx = ana.Amax-ana.Amin+1 nYpx = ana.Bmax-ana.Bmin+1 'Plot the data in Matlab with some parameters calculated from the T_ANALYSIS 'structure. Set the axes labels, title, colorbar and plot view. Matlab.Execute( "figure; surf(linspace("&xMin &","&xMax &","&nXpx &"),linspace("& yMin &"," & yMax & "," & nYpx & "),irradiance_pwd, 'EdgeColor', 'None');" ) Matlab.Execute( "xlabel('X Position (" & GetUnits() & ")')" ) : Matlab.Execute( "ylabel('Y Position (" & GetUnits() & ")')" ) : Matlab.Execute( "zLabel( 'Irradiance' )" ) Matlab.Execute( "title('Detector Irradiance')" ) Matlab.Execute( "colorbar" ) Matlab.Execute( "view(2)" ) Print "" Print "Matlab figure plotted..." 'Have Matlab calculate and return the mean value. Matlab.Execute( "irrad = mean(mean(irradiance_pwd));" ) Matlab.GetWorkspaceData( "irrad", "base", meanVal ) Print "The mean irradiance value calculated by Matlab is: " & meanVal 'Release resources Set Matlab = Nothing End Sub 最后在Matlab画图如下:
并在工作区保存了数据:
并返回平均值:
与FRED中计算的照度图对比:
例: 此例系统数据,可按照此数据建立模型系统数据
光源数据:Type: Laser Beam(Gaussian 00 mode)Beam size: 5;Grid size: 12;Sample pts: 100;相干光;波长0.5876微米,距离原点沿着Z轴负方向25mm。 对于执行代码,如果想保存图片,请在开始之前一定要执行如下代码:enableservice('AutomationServer', true)enableservice('AutomationServer')
