win10下rknn_toolkit-1.6.0-cp36-cp36m-win_amd64运行example/pytorch/test.py出现两个问题
1. Init runtime environment报错找不到指定的模块,但adb能看到设备,报错如下
--> Export RKNN model
done
--> Init runtime environment
E Catch exception when init runtime!
E Traceback (most recent call last):
E File "rknn\api\rknn_base.py", line 815, in rknn.api.rknn_base.RKNNBase.init_runtime
E File "rknn\api\rknn_runtime.py", line 162, in rknn.api.rknn_runtime.RKNNRuntime.__init__
E File "rknn\api\rknn_runtime.py", line 227, in rknn.api.rknn_runtime.RKNNRuntime._load_library
E File "D:\Anaconda3\envs\rk\lib\ctypes\__init__.py", line 348, in __init__
E self._handle = _dlopen(self._name, mode)
E OSError: [WinError 126] 找不到指定的模块。
E Current device id is: cd819f60fdbe2abe
E Devices connected:
E []
Init runtime environment failed
2.resnet18输出的.rknn文件报错,push到板上报错如下
[root@RV1126_RV1109:/userdata/examples/rktest]# ls
pic.jpg resnet_18.rknn1
[root@RV1126_RV1109:/userdata/examples/rktest]# ./resnet_18.rknn ./pic.jpg
./resnet_18.rknn: line 1: syntax error: unexpected word (expecting ")")
共5条
rknn文件在rv1126平台上运行报错是怎么回事呢?
关键词: rv1126 报错 rknn文件
问题1已解决,重新安装zading的usb驱动,拔掉电脑其他usb设备,成功输出.rknn文件。
问题2未解决
adb shell进入rknn文件所在目录,运行./resnet_18.rknn ./pic.jpg
报错./resnet_18.rknn: line 1: syntax error: unexpected word (expecting ")")
Core-1126-JD4用的builtroot最新固件AIO-RV1126_RV1109-JD4_IPC_2021_1206_1919,rknntoolket1.7
具体报错代码
[root@RV1126_RV1109:/userdata/exam]# chmod 777 resnet_18.rknn
[root@RV1126_RV1109:/userdata/exam]# ls -ls
total 1154111517 -rwxrwxrwx 1 root root 11745855 Jan 21 2022 resnet_18.rknn
[root@RV1126_RV1109:/userdata/exam]# ./resnet_18.rknn ./space_shuttle_224.jpg
共5条
