电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 基于51单片机的DS18B20的测温系统以及1602显示和超温时蜂鸣器报警
2023-08-17 16:09:33     打赏
想写一个基于51单片机的DS18B20的测温报警系统,但是蜂鸣器一直不响
#include
#include
#include
#include
#define uchar unsigned char
  #define uint unsigned int
 sbit dula = P2^6;
 sbit wela = P2^7;
sbit RS = P3^5;
 sbit LCDEN = P3^4;
sbit beep=P2^3;
uint tmp;
uint warn_l1=270;
uint warn_h1=300;
void delayUs()
    _nop_();
 void delayMs(uint a)
    uint i, j;
    for(i = a; i > 0; i--)
        for(j = 100; j > 0; j--);
void writeComm(uchar comm)
     RS = 0;
    P0 = comm;
    LCDEN = 1;
     delayUs();
    LCDEN = 0;
    delayMs(1);
//写数据:RS=1, RW=0;
void writeData(uchar dat)
     RS = 1;
     P0 = dat;
     LCDEN = 1;
    delayUs();
    LCDEN = 0;
    delayMs(1);
 void init()
     dula = wela = 0;
    writeComm(0x38);
   writeComm(0x0c);
    writeComm(0x06);
    writeComm(0x01);
void writeString(uchar * str, uchar length)
     uchar i;
    for(i = 0; i < length; i++)
         writeData(str);
/**//*****************************DS18B20*******************************/
 sbit ds = P2^2;
void dsInit()
    unsigned int i;
    ds = 0;
    i = 100;
     while(i>0) i--;
    ds = 1;
    i = 4;
     while(i>0) i--;
void dsWait()
      unsigned int i;
      while(ds);
      while(~ds);
      i = 4;
      while(i > 0) i--;
bit readBit()
    unsigned int i;
    bit b;
    ds = 0;
    i++;
    ds = 1;
   i++; i++;
    b = ds;
    i = 8;
    while(i>0) i--;
    return b;
unsigned char readByte()
    unsigned int i;
    unsigned char j, dat;
   dat = 0;
    for(i=0; i<8; i++)
        j = readBit();
        dat = (j << 7) | (dat >> 1);
    return dat;
void writeByte(unsigned char dat)
    unsigned int i;
    unsigned char j;
    bit b;
    for(j = 0; j < 8; j++)
        b = dat & 0x01;
        dat >>= 1;
        if(b)
           ds = 0;          i++; i++;
            ds = 1;
            i = 8; while(i>0) i--;
        else
            ds = 0;
            ds = 1;
           i++; i++;
void sendChangeCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0x44);
void sendReadCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0xbe);
int getTmpValue()
    unsigned int tmpvalue;
    int value;
    float t;
    unsigned char low, high;
    sendReadCmd();
    low = readByte();
    high = readByte();
    tmpvalue = high;
    tmpvalue <<= 8;
    tmpvalue |= low;
    value = tmpvalue;
    t = value * 0.0625;
    value = t * 100 + (value > 0 ? 0.5 : -0.5); //大于0加0.5, 小于0减0.5
    return value;
void display(int v)
    unsigned char count;
    unsigned char datas[] = {0, 0, 0, 0, 0};
    unsigned int tmp = abs(v);
    datas[0] = tmp / 10000;
    datas[1] = tmp % 10000 / 1000;
    datas[2] = tmp % 1000 / 100;
    datas[3] = tmp % 100 / 10;
    datas[4] = tmp % 10;
    writeComm(0xc0+3);
    if(v < 0)
        writeString("- ", 2);
    else
       writeString("+ ", 2);
    if(datas[0] != 0)
        writeData('0'+datas[0]);
    for(count = 1; count != 5; count++)
        writeData('0'+datas[count]);
        if(count == 2)
            writeData('.');
//蜂鸣器报警
void warn(uint s)
     uchar i;i=s;
     dula=0;wela=0;
     beep=0;
     while(i--)
        display(getTmpValue());
     beep=1;
     P1=0XFF;
     i=s;
       while(i--)
//温度处理函数
void deal(uint value)
  uchar i;
  if(value<=warn_l1)
    beep=0;
   else if(value>=warn_h1)
      beep=0;
   else
       i=40;
       while(i--)
void main()
    uchar table[] = " xianzaiwendu:";
    sendChangeCmd();
    init();
    writeComm(0x80);
    writeString(table, 16);
    while(1)
        delayMs(1000); //温度转换时间需要750ms以上
        writeComm(0xc0);
        sendChangeCmd();
关键词: 单片机     DS18B20     蜂鸣器
