我使用filter接收报文放入rxbuff,可以接受ID0x1234568, 如果接收ID 0x1234569 MCU会死机,配置如下,请问哪里配错了
g_mcmcan.canNodeConfig.filterConfig.standardListSize = 1; //Standard Frame
g_mcmcan.canNodeConfig.filterConfig.extendedListSize = 16; //Extended Frame
g_mcmcan.canNodeConfig.filterConfig.messageIdLength = IfxCan_MessageIdLength_extended;
g_mcmcan.canNodeConfig.messageRAM.standardFilterListStartAddress = 0x0;
g_mcmcan.canNodeConfig.messageRAM.extendedFilterListStartAddress = 0x80;
g_mcmcan.canNodeConfig.messageRAM.rxFifo0StartAddress = 0x100;
g_mcmcan.canNodeConfig.messageRAM.rxFifo1StartAddress = 0x200;
g_mcmcan.canNodeConfig.messageRAM.rxBuffersStartAddress = 0x300;
g_mcmcan.canNodeConfig.messageRAM.txEventFifoStartAddress = 0x400;
g_mcmcan.canNodeConfig.messageRAM.txBuffersStartAddress = 0x440;
g_mcmcan.canNodeConfig.messageRAM.baseAddress = MODULE_CAN0_RAM;
g_mcmcan.canFilter.number = 7;
g_mcmcan.canFilter.elementConfiguration = IfxCan_FilterElementConfiguration_storeInRxBuffer;
g_mcmcan.canFilter.id1 = (uint32)0x1234568;
g_mcmcan.canFilter.rxBufferOffset = IfxCan_RxBufferId_7;
IfxCan_Can_setExtendedFilter( g_mcmcan.can00Node, g_mcmcan.canFilter);
g_mcmcan.canFilter.number = 8;
g_mcmcan.canFilter.id1 = (uint32)0x1234569;
g_mcmcan.canFilter.rxBufferOffset = IfxCan_RxBufferId_8;
共1条
使用filter接收报文放入rxbuff,接收ID0x1234569MCU会死机的原因?
关键词: filter mcu rxbuff
共1条
