简介:
我们在上一篇适配了LVGL(8.3.10)显示的功能,还没有对接输入响应,板子上已经集成了一块GT911主控的触摸屏,我们在之前的基础上继续添加触摸屏的输入响应支持。对于触摸的驱动程序我们就不重复造轮子了,直接使用STM32Cube_FW_H7RS_V1.1.0\Drivers\BSP\STM32H7S78-DK 软件包里的驱动即可,把对应的驱动文件加入工程编译。
将上述驱动文件加入编译成功后对应的驱动程序已经ready,我么只要对接到 LVGL touch 设备依赖的驱动函数即可完成对应的适配,主要依赖我们porting的接口如下。
touchpad_init 接口初始化touch对应代码如下:
TS_Init_t hTS;
TS_State_t TS_State;
/*Initialize your touchpad*/
static void touchpad_init(void)
uint32_t ts_status = BSP_ERROR_NONE;
/*Your code comes here*/
hTS.Width = 800;
hTS.Height = 480;
hTS.Orientation = TS_SWAP_NONE;
hTS.Accuracy = 5;
/* Touchscreen initialization */
ts_status = BSP_TS_Init(0, &hTS);
if(ts_status != BSP_ERROR_NONE)
printf("touch init failed %d\r\n",ts_status);
else
printf("touch init ok\r\n");
}touch 按键状态检测接口touchpad_is_pressed
/*Return true is the touchpad is pressed*/
static bool touchpad_is_pressed(void)
ts_status = BSP_TS_GetState(0, &TS_State);
return TS_State.TouchDetected ? true : false;
}获取touch 位置坐标接口 touchpad_is_pressed
/*Get the x and y coordinates if the touchpad is pressed*/
static void touchpad_get_xy(lv_coord_t * x, lv_coord_t * y)
(*x) = TS_State.TouchX;
(*y) = TS_State.TouchY;
printf("x %d y %d \r\n",TS_State.TouchX,TS_State.TouchY);
}touch 初始化接口,向lvgl 注册输入设备
void lv_port_indev_init(void)
* Here you will find example implementation of input devices supported by LittelvGL:
* - Touchpad
* - Mouse (with cursor support)
* - Keypad (supports GUI usage only with key)
* - Encoder (supports GUI usage only with: left, right, push)
* - Button (external buttons to press points on the screen)
* The `..._read()` function are only examples.
* You should shape them according to your hardware
static lv_indev_drv_t indev_drv;
* Touchpad
/*Initialize your touchpad if you have*/
touchpad_init();
/*Register a touchpad input device*/
lv_indev_drv_init(&indev_drv);
indev_drv.type = LV_INDEV_TYPE_POINTER;
indev_drv.read_cb = touchpad_read;
indev_touchpad = lv_indev_drv_register(&indev_drv);
}在lvgl task 内添加lv_port_indev_init 调用完成touch 输入设备的注册。
板卡验证,LVGL 已经按照预期的可以响应触摸事件了。
