电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » DIY一个电子测光笔-成果贴
DIY一个电子测光笔-成果贴
2024-11-07 11:41:08     打赏
基础任务的成果发布在b站: https://www.bilibili.com/video/BV1kuD1YwERk/?vd_source=188a3fe7fed3cc24bda413a3b323c659
EETV视频链接:https://v.eepw.com.cn/video/play/id/16186
实现的基本功能:在ISO100感光值下,通过光传感器获得LUX值,然后工具公式算出曝光值,
在根据公式算出快门速度,光圈大小的关系。
然后展示在屏幕上。
完整代码:
#include <Adafruit_GFX.h>     // Core graphics library
#include <Adafruit_ST7789.h>  // Hardware-specific library for ST7789
#include <SPI.h>
#include <M5_DLight.h>
// Use dedicated hardware SPI pins
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
M5_DLight m5ligntSensor;
uint8_t EV;
float F = 1.0, T;
uint8_t ISO = 100;
void setup(void) {
  Serial.begin(115200);
  pinMode(5, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);
  // turn on backlite
  pinMode(TFT_BACKLITE, OUTPUT);
  digitalWrite(TFT_BACKLITE, HIGH);
  // turn on the TFT / I2C power supply
  pinMode(TFT_I2C_POWER, OUTPUT);
  digitalWrite(TFT_I2C_POWER, HIGH);
  delay(10);
  // initialize TFT
  tft.init(135, 240);  // Init ST7789 240x135
  tft.setRotation(3);
  tft.fillScreen(ST77XX_BLACK);
  tft.setTextColor(ST77XX_WHITE);
  delay(1000);
  m5ligntSensor.begin();
  m5ligntSensor.setMode(CONTINUOUSLY_H_RESOLUTION_MODE);
static uint8_t boolBtnPressed = false;
static uint8_t prevLux = 0;
void loop() {
  tft.setCursor(0, 0);
  tft.setTextSize(3);
  tft.println("HELLO EEPW");
  if (digitalRead(5) == LOW) {
    // tft.setCursor(0, 20);
    // tft.setTextSize(3);
    // tft.print("BTN 1 pressed");
    F = 1.4;
    boolBtnPressed = true;
  } else if (digitalRead(6) == LOW) {
    // tft.print("BTN 2 pressed");
    F = 2;
  delay(100);
  if (boolBtnPressed || (prevLux != m5ligntSensor.getLUX())) {
    prevLux = m5ligntSensor.getLUX();
    tft.fillRect(0, 20, 240, 100, ST77XX_BLACK);
    tft.print("LUX = ");
    tft.println(m5ligntSensor.getLUX());
    tft.print("EV:");
    EV = 2 + log2(m5ligntSensor.getLUX() / 10);
    tft.print(EV);
    tft.print(" ISO:");
    tft.print(ISO);
    T = pow(2, log2(F * F) - EV);
    tft.println();
    tft.setTextSize(2);
    tft.print("F:");
    tft.print(F);
    tft.print(" T:");
    tft.print(T, 3);
