电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【换取逻辑分析仪】SoEasy!基于ESP32的简易Wi-Fi遥控小车
2024-12-20 09:46:33   被打赏 41 分(兑奖)     打赏
感谢EEPW推出的“换取逻辑分析仪”活动,让我分享更有动力!
本次继续分享之前做的Wi-Fi遥控小车。
主控还是老朋友ESP32 Firebeetle,采用锂电池供电。
电机驱动采用L298N,性价比不错:
安装在小车上,输入接单片机的IO信号,输出连接到两个电机上。
代码:
连接WIFI:
WiFi.begin("TP-LINK", "helloeepw");      // 启动网络连接
  Serial.print("Connecting to ");  // 串口监视器输出网络连接信息
  Serial.print(ssid);
  Serial.println("Connect to TP LINK successfully");  // 告知用户NodeMCU正在尝试WiFi连接
  WiFi.softAP(ssid, password);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
通信控制采用的是websocket:
server.begin();
  Serial.println("Server started");
  webSocket.onConnection([](WebSocket &ws) {
    const auto protocol = ws.getProtocol();
    if (protocol) {
      Serial.print(F("Client protocol: "));
      Serial.println(protocol);
    ws.onMessage([](WebSocket &ws, const WebSocket::DataType dataType,
                    const char *message, uint16_t length) {
      String cmd_str = String((char *)message);
      int command = cmd_str.toInt();
      Serial.print("command: ");
      Serial.println(command);
      switch (dataType) {
        case WebSocket::DataType::TEXT:
          switch (command) {
            case CMD_STOP:
              Serial.println("Stop");
              CAR_stop();
              digitalWrite(LED_BUILTIN, LOW);
              break;
            case CMD_FORWARD:
              Serial.println("Move Forward");
              CAR_moveForward();
              digitalWrite(LED_BUILTIN, HIGH);
              break;
            case CMD_BACKWARD:
              Serial.println("Move Backward");
              CAR_moveBackward();
              break;
            case CMD_LEFT:
              Serial.println("Turn Left");
              CAR_turnLeft();
              break;
            case CMD_RIGHT:
              Serial.println("Turn Right");
              CAR_turnRight();
              break;
            default:
              Serial.println("Unknown command");
          break;
        case WebSocket::DataType::BINARY:
          Serial.println(F("Received binary data"));
          break;
    ws.onClose([](WebSocket &, const WebSocket::CloseCode, const char *,
                  uint16_t) {
      Serial.println(F("Disconnected"));
    Serial.print(F("New WebSocket Connnection from client: "));
    Serial.println(ws.getRemoteIP());
  webSocket.begin();
网页点击UP DOWN LEFT RIGHT后,调用相应的控制还是指挥小车做相应动作。
void CAR_moveForward() {
  digitalWrite(IN1_PIN, HIGH);
  digitalWrite(IN2_PIN, LOW);
  digitalWrite(IN3_PIN, HIGH);
  digitalWrite(IN4_PIN, LOW);
void CAR_moveBackward() {
  digitalWrite(IN1_PIN, LOW);
  digitalWrite(IN2_PIN, HIGH);
  digitalWrite(IN3_PIN, LOW);
  digitalWrite(IN4_PIN, HIGH);
void CAR_turnLeft() {
void CAR_turnRight() {
void CAR_stop() {
实物测试:
  1. 打开WiFi,连接到ESP32 Firebeetle
  2. 打开浏览器,输入网址:192.168.4.1
  3. 切换Wi-Fi信号到本地路由器,联网下载“上” “下” “左” “右” 等图片
    button_up {
    background: url('https://esp32io.com/images/tutorial/up_inactive.png') no-repeat;
    background-size: contain;
    left: 200px;
    top: 0px;
    transform: translateX(-50%);
  4. 切换Wi-Fi到ESP32
  5. 回到浏览器,点击connect,连接到开发板
  6. 控制小车
