电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » rtthread sensor V2 框架分析
2025-02-25 22:03:26     打赏
       rtthread的sensor框架存在两个版本,其中V2版的框架号称是为了解决V1对多传感器共用一颗IC的场景支持问题而设计的(之前PR群内沟通迭代计划时提到的)。
源码解析
源码路径
components\drivers\sensor\v2\sensor.c
注册入口
 *                 Sensor mode
 *              rt_uint16_t mode
 *   0000   |    0000    |   0000   |    0000
 *  unused     accuracy      power     fetch data
#define RT_SENSOR_MODE_ACCURACY_BIT_OFFSET    (8)
#define RT_SENSOR_MODE_POWER_BIT_OFFSET       (4)
#define RT_SENSOR_MODE_FETCH_BIT_OFFSET       (0)
#define RT_SENSOR_MODE_GET_ACCURACY(mode)     (rt_uint8_t)((mode >> RT_SENSOR_MODE_ACCURACY_BIT_OFFSET) & 0x0F)
#define RT_SENSOR_MODE_GET_POWER(mode)        (rt_uint8_t)((mode >> RT_SENSOR_MODE_POWER_BIT_OFFSET) & 0x0F)
#define RT_SENSOR_MODE_GET_FETCH(mode)        (rt_uint8_t)((mode >> RT_SENSOR_MODE_FETCH_BIT_OFFSET) & 0x0F)
#define RT_SENSOR_MODE_CLEAR_ACCURACY(mode)   (mode &= ((rt_uint16_t)~((rt_uint16_t)0x0F << RT_SENSOR_MODE_ACCURACY_BIT_OFFSET)))
#define RT_SENSOR_MODE_CLEAR_POWER(mode)      (mode &= ((rt_uint16_t)~((rt_uint16_t)0x0F << RT_SENSOR_MODE_POWER_BIT_OFFSET)))
#define RT_SENSOR_MODE_CLEAR_FETCH(mode)      (mode &= ((rt_uint16_t)~((rt_uint16_t)0x0F << RT_SENSOR_MODE_FETCH_BIT_OFFSET)))
#define RT_SENSOR_MODE_SET_ACCURACY(mode, accuracy_mode) RT_SENSOR_MODE_CLEAR_ACCURACY(mode); (mode |= (accuracy_mode << RT_SENSOR_MODE_ACCURACY_BIT_OFFSET))
#define RT_SENSOR_MODE_SET_POWER(mode, power_mode)       RT_SENSOR_MODE_CLEAR_POWER(mode); (mode |= (power_mode << RT_SENSOR_MODE_POWER_BIT_OFFSET))
#define RT_SENSOR_MODE_SET_FETCH(mode, fetch_mode)       RT_SENSOR_MODE_CLEAR_FETCH(mode); (mode |= (fetch_mode << RT_SENSOR_MODE_FETCH_BIT_OFFSET))
static char *const sensor_name_str[] =
    "None",
    "ac-",       /* Accelerometer     */
    "gy-",       /* Gyroscope         */
    "ma-",       /* Magnetometer      */
    "tm-",       /* Temperature       */
    "hm-",       /* Relative Humidity */
    "br-",       /* Barometer         */
    "li-",       /* Ambient light     */
    "pr-",       /* Proximity         */
    "hr-",       /* Heart Rate        */
    "tv-",       /* TVOC Level        */
    "ni-",       /* Noise Loudness    */
    "st-",       /* Step sensor       */
    "fr-",       /* Force sensor      */
    "du-",       /* Dust sensor       */
    "ec-",       /* eCO2 sensor       */
    "gn-",       /* GPS/GNSS sensor   */
    "tf-",       /* TOF sensor        */
    "sp-",       /* SpO2 sensor       */
    "ia-",       /* IAQ sensor        */
    "et-",       /* EtOH sensor       */
    "bp-",       /* Blood Pressure    */
    RT_NULL
/* sensor local ops */
static rt_ssize_t _local_fetch_data(rt_sensor_t sensor, rt_sensor_data_t buf, rt_size_t len)
    LOG_D("Undefined fetch_data");
    return -RT_EINVAL;
static rt_err_t _local_control(rt_sensor_t sensor, int cmd, void *arg)
    LOG_D("Undefined control");
    return -RT_EINVAL;
static struct rt_sensor_ops local_ops =
    .fetch_data = _local_fetch_data,
    .control = _local_control
int rt_hw_sensor_register(rt_sensor_t    sensor,
                          const char    *name,
                          rt_uint32_t    flag,
                          void          *data)
    rt_int8_t result;
    rt_device_t device;
    RT_ASSERT(sensor != RT_NULL);
    char *sensor_name = RT_NULL, *device_name = RT_NULL;
    if (sensor->ops == RT_NULL)
        sensor->ops = &local_ops;
    /* Add a type name for the sensor device */
    sensor_name = sensor_name_str[sensor->info.type];
    device_name = (char *)rt_calloc(1, rt_strlen(sensor_name) + 1 + rt_strlen(name));
    if (device_name == RT_NULL)
        LOG_E("device_name calloc failed!");
        return -RT_ERROR;
    rt_memcpy(device_name, sensor_name, rt_strlen(sensor_name) + 1);
    strcat(device_name, name);
    if (sensor->module != RT_NULL && sensor->module->lock == RT_NULL)
        /* Create a mutex lock for the module */
        sensor->module->lock = rt_mutex_create(name, RT_IPC_FLAG_PRIO);
        if (sensor->module->lock == RT_NULL)
            rt_free(device_name);
            return -RT_ERROR;
    device = &sensor->parent;
#ifdef RT_USING_DEVICE_OPS
    device->ops         = &rt_sensor_ops;
#else
    device->init        = RT_NULL;
    device->open        = _sensor_open;
    device->close       = _sensor_close;
    device->read        = _sensor_read;
    device->write       = RT_NULL;
    device->control     = _sensor_control;
#endif
    device->type        = RT_Device_Class_Sensor;
    device->rx_indicate = RT_NULL;
    device->tx_complete = RT_NULL;
    device->user_data   = data;
    result = rt_device_register(device, device_name, flag | RT_DEVICE_FLAG_STANDALONE);
    if (result != RT_EOK)
        LOG_E("sensor[%s] register err code: %d", device_name, result);
        return result;
    LOG_I("sensor[%s] init success", device_name);
    return RT_EOK;
    注册函数和v1版相比,除了名称外,几乎没有任何修改,因此可以沿用v1的分析。
打开入口
static void _sensor_cb(rt_sensor_t sen)
    if (sen->parent.rx_indicate == RT_NULL)
        return;
    if (sen->irq_handle != RT_NULL)
        sen->irq_handle(sen);
    /* The buffer is not empty. Read the data in the buffer first */
    if (sen->data_len > 0)
        sen->parent.rx_indicate(&sen->parent, sen->data_len / sizeof(struct rt_sensor_data));
    else if (RT_SENSOR_MODE_GET_FETCH(sen->info.mode) == RT_SENSOR_MODE_FETCH_INT)
        /* The interrupt mode only produces one data at a time */
        sen->parent.rx_indicate(&sen->parent, 1);
    else if (RT_SENSOR_MODE_GET_FETCH(sen->info.mode) == RT_SENSOR_MODE_FETCH_FIFO)
        sen->parent.rx_indicate(&sen->parent, sen->info.fifo_max);
static void _irq_callback(void *args)
    rt_sensor_t sensor = (rt_sensor_t)args;
    rt_uint8_t i;
    if (sensor->module)
        /* Invoke a callback for all sensors in the module */
        for (i = 0; i < sensor->module->sen_num; i++)
            _sensor_cb(sensor->module->sen[i]);
    else
        _sensor_cb(sensor);
static rt_err_t _sensor_irq_init(rt_sensor_t sensor)
    if (sensor->config.irq_pin.pin == PIN_IRQ_PIN_NONE)
        return -RT_EINVAL;
    rt_pin_mode(sensor->config.irq_pin.pin, sensor->config.irq_pin.mode);
    if (sensor->config.irq_pin.mode == PIN_MODE_INPUT_PULLDOWN)
        rt_pin_attach_irq(sensor->config.irq_pin.pin, PIN_IRQ_MODE_RISING, _irq_callback, (void *)sensor);
    else if (sensor->config.irq_pin.mode == PIN_MODE_INPUT_PULLUP)
        rt_pin_attach_irq(sensor->config.irq_pin.pin, PIN_IRQ_MODE_FALLING, _irq_callback, (void *)sensor);
    else if (sensor->config.irq_pin.mode == PIN_MODE_INPUT)
        rt_pin_attach_irq(sensor->config.irq_pin.pin, PIN_IRQ_MODE_RISING_FALLING, _irq_callback, (void *)sensor);
    rt_pin_irq_enable(sensor->config.irq_pin.pin, RT_TRUE);
    LOG_I("interrupt init success");
    return 0;
static rt_err_t _sensor_open(rt_device_t dev, rt_uint16_t oflag)
    rt_sensor_t sensor = (rt_sensor_t)dev;
    RT_ASSERT(dev != RT_NULL);
    rt_err_t res = RT_EOK;
    rt_err_t (*local_ctrl)(rt_sensor_t sensor, int cmd, void *arg) =  _local_control;
    if (sensor->module)
        /* take the module mutex */
        rt_mutex_take(sensor->module->lock, RT_WAITING_FOREVER);
    if (sensor->module != RT_NULL && sensor->info.fifo_max > 0 && sensor->data_buf == RT_NULL)
        /* Allocate memory for the sensor buffer */
        sensor->data_buf = rt_malloc(sizeof(struct rt_sensor_data) * sensor->info.fifo_max);
        if (sensor->data_buf == RT_NULL)
            res = -RT_ENOMEM;
            goto __exit;
    if (sensor->ops->control != RT_NULL)
        local_ctrl = sensor->ops->control;
    if (oflag & RT_DEVICE_FLAG_RDONLY && dev->flag & RT_DEVICE_FLAG_RDONLY)
        /* If polling mode is supported, configure it to polling mode */
        if (local_ctrl(sensor, RT_SENSOR_CTRL_SET_FETCH_MODE, (void *)RT_SENSOR_MODE_FETCH_POLLING) == RT_EOK)
            RT_SENSOR_MODE_SET_FETCH(sensor->info.mode, RT_SENSOR_MODE_FETCH_POLLING);
    else if (oflag & RT_DEVICE_FLAG_INT_RX && dev->flag & RT_DEVICE_FLAG_INT_RX)
        /* If interrupt mode is supported, configure it to interrupt mode */
        if (local_ctrl(sensor, RT_SENSOR_CTRL_SET_FETCH_MODE, (void *)RT_SENSOR_MODE_FETCH_INT) == RT_EOK)
            /* Initialization sensor interrupt */
            _sensor_irq_init(sensor);
            RT_SENSOR_MODE_SET_FETCH(sensor->info.mode, RT_SENSOR_MODE_FETCH_INT);
    else if (oflag & RT_DEVICE_FLAG_FIFO_RX && dev->flag & RT_DEVICE_FLAG_FIFO_RX)
        /* If fifo mode is supported, configure it to fifo mode */
        if (local_ctrl(sensor, RT_SENSOR_CTRL_SET_FETCH_MODE, (void *)RT_SENSOR_MODE_FETCH_FIFO) == RT_EOK)
            RT_SENSOR_MODE_SET_FETCH(sensor->info.mode, RT_SENSOR_MODE_FETCH_FIFO);
    else
        res = -RT_EINVAL;
        goto __exit;
    /* Configure power mode to highest mode */
    if (local_ctrl(sensor, RT_SENSOR_CTRL_SET_POWER_MODE, (void *)RT_SENSOR_MODE_POWER_HIGHEST) == RT_EOK)
        RT_SENSOR_MODE_SET_POWER(sensor->info.mode, RT_SENSOR_MODE_POWER_HIGHEST);
    /* Configure accuracy mode to highest mode */
    if (local_ctrl(sensor, RT_SENSOR_CTRL_SET_ACCURACY_MODE, (void *)RT_SENSOR_MODE_ACCURACY_HIGHEST) == RT_EOK)
        RT_SENSOR_MODE_SET_ACCURACY(sensor->info.mode, RT_SENSOR_MODE_ACCURACY_HIGHEST);
__exit:
    if (sensor->module)
        /* release the module mutex */
        rt_mutex_release(sensor->module->lock);
    return res;
      和V1版本相比,主要修改点有以下部分:
        a.sen->info.mode的作用范围变宽,原先8bit表示一个意思,现在时3bit表示3种功能,剩余5bit为保留位,对应的操作也改为宏的方式隐藏
        b.RT_PIN_NONE 变成了 PIN_IRQ_PIN_NONE,实际功能一致,个人怀疑是版本修改漏同步了v1
        c.对应驱动的RT_SENSOR_CTRL_SET_MODE入口变成了 RT_SENSOR_CTRL_SET_FETCH_MODE,对应的传递到驱动的参数也由 RT_SENSOR_MODE_xxxx 变成了 RT_SENSOR_MODE_FETCH_xxxx,实际功能未变化
        d.对应驱动的 RT_SENSOR_CTRL_SET_POWER入口变成了RT_SENSOR_CTRL_SET_POWER_MODE,参数 RT_SENSOR_POWER_NORMAL 变成了 RT_SENSOR_MODE_POWER_HIGHEST,具体功能未知,需从包管理器里面找到v2版驱动对应实现才清楚
        e.新增接口 RT_SENSOR_CTRL_SET_ACCURACY_MODE,具体功能未知
关闭入口
static rt_err_t _sensor_close(rt_device_t dev)
    int i;
    if (sensor->module)
    /* Configure power mode to power down mode */
    if (local_ctrl(sensor, RT_SENSOR_CTRL_SET_POWER_MODE, (void *)RT_SENSOR_MODE_POWER_DOWN) == RT_EOK)
        RT_SENSOR_MODE_SET_POWER(sensor->info.mode, RT_SENSOR_MODE_POWER_DOWN);
    if (sensor->module != RT_NULL && sensor->info.fifo_max > 0 && sensor->data_buf != RT_NULL)
        for (i = 0; i < sensor->module->sen_num; i ++)
            if (sensor->module->sen[i]->parent.ref_count > 0)
                goto __exit;
        /* Free memory for the sensor buffer */
            if (sensor->module->sen[i]->data_buf)
                rt_free(sensor->module->sen[i]->data_buf);
                sensor->module->sen[i]->data_buf = RT_NULL;
    if (RT_SENSOR_MODE_GET_FETCH(sensor->info.mode) != RT_SENSOR_MODE_FETCH_POLLING)
        /* Sensor disable interrupt */
        if (sensor->config.irq_pin.pin != PIN_IRQ_PIN_NONE)
            rt_pin_irq_enable(sensor->config.irq_pin.pin, RT_FALSE);
__exit:
    if (sensor->module)
    return RT_EOK;
      相比较于打开接口,关闭接口除了改变函数名称和参数名称,并未改任何功能,因此对照v1看就可以了。
读入口
static rt_ssize_t _sensor_read(rt_device_t dev, rt_off_t pos, void *buf, rt_size_t len)
    rt_size_t result = 0;
    if (buf == NULL || len == 0)
        return 0;
    if (sensor->module)
    if (sensor->data_len > 0)
        if (len > sensor->data_len / sizeof(struct rt_sensor_data))
            len = sensor->data_len / sizeof(struct rt_sensor_data);
        rt_memcpy(buf, sensor->data_buf, len * sizeof(struct rt_sensor_data));
        /* Clear the buffer */
        sensor->data_len = 0;
        result = len;
    else
        /* If the buffer is empty, read the data */
        if (sensor->ops->fetch_data)
            result = sensor->ops->fetch_data(sensor, buf, len);
    if (sensor->module)
    return result;
      与关闭接口一致,读入口也没有改变任何功能,仅仅是参数名和函数名的修改。
控制入口
static rt_err_t _sensor_control(rt_device_t dev, int cmd, void *args)
    rt_err_t result = RT_EOK;
    rt_uint8_t mode;
    if (sensor->module)
    switch (cmd)
        case RT_SENSOR_CTRL_GET_ID:
            if (args)
                result = local_ctrl(sensor, RT_SENSOR_CTRL_GET_ID, args);
            break;
        case RT_SENSOR_CTRL_SET_ACCURACY_MODE:
            /* Configuration sensor power mode */
            mode = (rt_uint32_t)args & 0x000F;
            if (!(mode == RT_SENSOR_MODE_ACCURACY_HIGHEST || mode == RT_SENSOR_MODE_ACCURACY_HIGH ||\
                  mode == RT_SENSOR_MODE_ACCURACY_MEDIUM  || mode == RT_SENSOR_MODE_ACCURACY_LOW  ||\
                  mode == RT_SENSOR_MODE_ACCURACY_LOWEST  || mode == RT_SENSOR_MODE_ACCURACY_NOTRUST))
                LOG_E("sensor accuracy mode illegal: %d", mode);
                return -RT_EINVAL;
            result = local_ctrl(sensor, RT_SENSOR_CTRL_SET_ACCURACY_MODE, args);
            if (result == RT_EOK)
                RT_SENSOR_MODE_SET_ACCURACY(sensor->info.mode, mode);
                LOG_D("set accuracy mode code: %d", RT_SENSOR_MODE_GET_ACCURACY(sensor->info.mode));
            break;
        case RT_SENSOR_CTRL_SET_POWER_MODE:
            if (!(mode == RT_SENSOR_MODE_POWER_HIGHEST || mode == RT_SENSOR_MODE_POWER_HIGH ||\
                  mode == RT_SENSOR_MODE_POWER_MEDIUM  || mode == RT_SENSOR_MODE_POWER_LOW  ||\
                  mode == RT_SENSOR_MODE_POWER_LOWEST  || mode == RT_SENSOR_MODE_POWER_DOWN))
                LOG_E("sensor power mode illegal: %d", mode);
                return -RT_EINVAL;
            result = local_ctrl(sensor, RT_SENSOR_CTRL_SET_POWER_MODE, args);
                RT_SENSOR_MODE_SET_POWER(sensor->info.mode, mode);
                LOG_D("set power mode code: %d", RT_SENSOR_MODE_GET_POWER(sensor->info.mode));
            break;
        case RT_SENSOR_CTRL_SET_FETCH_MODE:
            if (!(mode == RT_SENSOR_MODE_FETCH_POLLING || mode == RT_SENSOR_MODE_FETCH_INT ||\
                  mode == RT_SENSOR_MODE_FETCH_FIFO))
                LOG_E("sensor fetch data mode illegal: %d", mode);
                return -RT_EINVAL;
            result = local_ctrl(sensor, RT_SENSOR_CTRL_SET_FETCH_MODE, args);
                RT_SENSOR_MODE_SET_FETCH(sensor->info.mode, mode);
                LOG_D("set fetch mode code: %d", RT_SENSOR_MODE_GET_FETCH(sensor->info.mode));
            break;
        case RT_SENSOR_CTRL_SELF_TEST:
            /* device self test */
            result = local_ctrl(sensor, RT_SENSOR_CTRL_SELF_TEST, args);
            break;
        case RT_SENSOR_CTRL_SOFT_RESET:
            /* device soft reset */
            result = local_ctrl(sensor, RT_SENSOR_CTRL_SOFT_RESET, args);
            break;
        default:
            if (cmd > RT_SENSOR_CTRL_USER_CMD_START)
                /* Custom commands */
                result = local_ctrl(sensor, cmd, args);
            else
                result = -RT_EINVAL;
            break;
    if (sensor->module)
    return result;
      控制入口算是V2版框架改动最大的地方,主要修改如下:
            a.去掉了入口 RT_SENSOR_CTRL_GET_INFO,其实这个入口在V1上也没啥用,仅仅是系统自带的测试命令需要的入口,而v2版改为直接处理了,不再调用一层。
            b.去掉了 RT_SENSOR_CTRL_SET_RANGE 和 RT_SENSOR_CTRL_SET_ODR两个入口,这个有点无厘头,因为按我理解,其实大部分传感器都支持设置采样率和量程范围的功能,去掉这个接口,意味着只能靠驱动自己内部默认几个参数了
            c.RT_SENSOR_CTRL_SET_POWER 变成了 RT_SENSOR_CTRL_SET_POWER_MODE,功能个人猜测应该没变,但需要找已经适配的代码具体确认
            d.新增了 RT_SENSOR_CTRL_SET_ACCURACY_MODE入口,具体功能未知,需找已适配的代码去确认
            e.新增了入口 RT_SENSOR_CTRL_SET_FETCH_MODE,具体功能为切换传感器的工作模式(中断,轮询,FIFO)
            f.新增了入口 RT_SENSOR_CTRL_SOFT_RESET,从名称上感觉是软复位,是否是需看已适配的v2驱动
新增入口 -- 查找传感器设备
rt_sensor_t rt_sensor_device_find(const char *name)
    rt_uint8_t index;
    char device_name[RT_NAME_MAX];
    rt_device_t device;
    for (index = 0; sensor_name_str[index] != RT_NULL; index++)
        rt_memset(device_name, 0, sizeof(device_name));
        rt_snprintf(device_name, sizeof(device_name), "%s%s", sensor_name_str[index], name);
        device = rt_device_find(device_name);
        if (device != RT_NULL)
            return (rt_sensor_t)device;
    return RT_NULL;
     老实说,个人认为这个入口就是个坑,完全没考虑一颗芯片包含多种传感器的场景,如果不存在这种场景,可以考虑用一下这个接口,如果存在,那就不要用,很容易变成想要一个功能传感器,但拿到的是另一个功能的传感器。
总结
    至此,v2版驱动已经分析完毕,相比较于v1版的驱动框架,个人认为宣传的改进不算大,相反,v2框架还去掉了一些必要的选项(量程和采样率的设置),反而限制了v2版传感器框架的使用。如果使用的话,在v2版框架成熟前,个人倾向于优先使用v1版传感器框架。事实上,如果没记错的话,去年下半年,rtt官方也默认禁用了V2版框架,个人猜测也是因为类似的原因吧。
关键词: rtthread     sensor     框架     分析     v2
