电子产品世界 » 论坛首页 » 行业应用 » 汽车电子 » 【S32K3】S32K 时钟系统配置初探
2025-10-22 10:38:54     打赏
【概述】
S32K3 系列的芯片的 RTD 驱动库对时钟系统进行了抽象,按照面向对象的思想将时钟系统的初始化抽成 Clock_Ip_ClockConfigType 结构体,对应的结构体定义如下:
 * @brief Clock configuration structure.
 * Implements Clock_Ip_ClockConfigType_Class
typedef struct
    uint32  ClkConfigId;          /**< The ID for Clock configuration */
    const Clock_Ip_RegisterValueType   (*RegValues)[]; /**< Pointer to register values array */
    uint8   IrcoscsCount;         /**< IRCOSCs count */
    uint8   XoscsCount;           /**< XOSCs count */
    uint8   PllsCount;            /**< PLLs count */
    uint8   SelectorsCount;       /**< Selectors count */
    uint8   DividersCount;        /**< Dividers count */
    uint8   DividerTriggersCount; /**< Divider triggers count */
    uint8   FracDivsCount;        /**< Fractional dividers count */
    uint8   ExtClksCount;         /**< External clocks count */
    uint8   GatesCount;           /**< Clock gates count */
    uint8   PcfsCount;            /**< Clock pcfs count */
    uint8   CmusCount;            /**< Clock cmus count */
    uint8   ConfigureFrequenciesCount; /**< Configured frequencies count */
    Clock_Ip_IrcoscConfigType          Ircoscs[CLOCK_IP_IRCOSCS_NO];    /**< IRCOSCs */
    Clock_Ip_XoscConfigType            Xoscs[CLOCK_IP_XOSCS_NO];        /**< XOSCs */
    Clock_Ip_PllConfigType             Plls[CLOCK_IP_PLLS_NO];          /**< PLLs */
    Clock_Ip_SelectorConfigType        Selectors[CLOCK_IP_SELECTORS_NO];/**< Selectors */
    Clock_Ip_DividerConfigType         Dividers[CLOCK_IP_DIVIDERS_NO];  /**< Dividers */
    Clock_Ip_DividerTriggerConfigType  DividerTriggers[CLOCK_IP_DIVIDER_TRIGGERS_NO];/**< Divider triggers */
    Clock_Ip_FracDivConfigType         FracDivs[CLOCK_IP_FRACTIONAL_DIVIDERS_NO];/**< Fractional dividers */
    Clock_Ip_ExtClkConfigType          ExtClks[CLOCK_IP_EXT_CLKS_NO]; /**< External clocks */
    Clock_Ip_GateConfigType            Gates[CLOCK_IP_GATES_NO];      /**< Clock gates */
    Clock_Ip_PcfsConfigType            Pcfs[CLOCK_IP_PCFS_NO];        /**< Progressive clock switching */
    Clock_Ip_CmuConfigType             Cmus[CLOCK_IP_CMUS_NO];        /**< Clock cmus */
    Clock_IP_SpecificPeriphConfigType  SpecificPeriphalConfiguration; /**< Clock specific peripheral configuration */
    Clock_Ip_ConfiguredFrequencyType   ConfiguredFrequencies[CLOCK_IP_CONFIGURED_FREQUENCIES_NO];     /**< Configured frequency values */
} Clock_Ip_ClockConfigType;
上述配置结构体对时钟系统的 xosc/pll/divider 进行了抽每一个对象有对应的counter 对于小面的配置数组进行描述。
本地的生成的 clock 结构如下:
本地以PLL的配置流程来了解时钟系统初始化的过程,PLL 的配置结构如下:
typedef struct
    Clock_Ip_NameType        Name;                           /**< Clock name associated to pll */
    uint16                   Enable;                         /**< Enable pll. */
    Clock_Ip_NameType        InputReference;                 /**< Input reference. */
    uint8                    Bypass;                         /**< Bypass pll. */
    uint8                    Predivider;                     /**< Input clock predivider. */
    uint16                   Multiplier;                     /**< Clock multiplier.  */
    uint8                    Postdivider;                    /**< Clock postidivder.*/
    uint16                   NumeratorFracLoopDiv;           /**< Numerator of fractional loop division factor (MFN) */
    uint8                    MulFactorDiv;                   /**< Multiplication factor divider (MFD) */
    uint8                    ModulationFrequency;            /**< Enable/disable modulation */
    uint8                    ModulationType;                 /**< Modulation type */
    uint16                   ModulationPeriod;               /**< Stepsize - modulation period */
    uint16                   IncrementStep;                  /**< Stepno  - step no */
    uint8                    SigmaDelta;                     /**< Sigma Delta Modulation Enable */
    uint8                    DitherControl;                  /**< Dither control enable */
    uint8                    DitherControlValue;             /**< Dither control value */
    uint8                    Monitor;                        /**< Monitor type */
    uint16                   Dividers[3U];                   /**< Dividers values */
} Clock_Ip_PllConfigType;
代码中通过配置的回调函数传入上述的配置完成PLL 的配置,其他的结构配置也是通过该方式来完成。
从上述代码可以大致理解S32K3 clk 驱动的配置方法。
关键词: S32K3学习整理
