电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 自己DIY的STM32F103C8T6最小系统板+ADC
2025-11-18 19:28:59   被打赏 100 分(兑奖)     打赏
结合上篇这篇进行ADC输出,使用的是F103的ADC1.
下面进行,先在CUBEMX中进行配置。
设置好后,再进行输出。
下面来点其它的资料,分享一下进行时查过的资料,了解一下ADC的功能与框图:
掌握了ADC的功能框图,就可以对ADC有一个整体的把握,在编程的时候可以做到了然如胸,不会一知半解。 框图讲解采用从左到右的方式,跟ADC采集数据,转换数据,传输数据的方向大概一致。
代码
void MX_ADC1_Init(void)
  /* USER CODE BEGIN ADC1_Init 0 */
  /* USER CODE END ADC1_Init 0 */
  ADC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN ADC1_Init 1 */
  /* USER CODE END ADC1_Init 1 */
  /** Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 4;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = ADC_REGULAR_RANK_2;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_2;
  sConfig.Rank = ADC_REGULAR_RANK_3;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_3;
  sConfig.Rank = ADC_REGULAR_RANK_4;
    Error_Handler();
  /* USER CODE BEGIN ADC1_Init 2 */
  /* USER CODE END ADC1_Init 2 */
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  if(adcHandle->Instance==ADC1)
  /* USER CODE BEGIN ADC1_MspInit 0 */
  /* USER CODE END ADC1_MspInit 0 */
    /* ADC1 clock enable */
    __HAL_RCC_ADC1_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    /**ADC1 GPIO Configuration
    PA0-WKUP     ------> ADC1_IN0
    PA1     ------> ADC1_IN1
    PA2     ------> ADC1_IN2
    PA3     ------> ADC1_IN3
    GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    /* ADC1 DMA Init */
    /* ADC1 Init */
    hdma_adc1.Instance = DMA1_Channel1;
    hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
    hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
    hdma_adc1.Init.Mode = DMA_CIRCULAR;
    hdma_adc1.Init.Priority = DMA_PRIORITY_LOW;
    if (HAL_DMA_Init(&hdma_adc1) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc1);
    /* ADC1 interrupt Init */
    HAL_NVIC_SetPriority(ADC1_2_IRQn, 2, 0);
    HAL_NVIC_EnableIRQ(ADC1_2_IRQn);
  /* USER CODE BEGIN ADC1_MspInit 1 */
  /* USER CODE END ADC1_MspInit 1 */
ADC主函数运行代码
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_ADC1_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
    HAL_ADCEx_Calibration_Start(&hadc1);
    HAL_Delay(200);
    HAL_ADC_Start_DMA(&hadc1,(uint32_t*)ADC_buffer,4);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    for(int i = 0; i < 4; i++)
        printf("ADCbuffer%d: %d \r\n", i, ADC_buffer[i]);
        HAL_Delay(100);
        printf("ADCValue%d:  %f \r\n", i, (ADC_buffer[i]) * 3.3 / 4095);
        HAL_Delay(100);
        SEGGER_RTT_WriteString(0, "Hello World from SEGGER!666\r\n");
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
解析一下,使用到GPIO时候都必须开启对应的GPIO时钟,GPIO用于AD转换功能必须配置为模拟输入模式。
定义 ADC 初始化结构体 ADC_InitTypeDef 用于配置 ADC 工作模式。先调用 RCC_APB2PeriphClockCmd() 开启 ADC 时钟,再通过 RCC_ADCCLKConfig() 配置 ADC 工作时钟,其参数为 PCLK2 分频系数,且 ADC 时钟最大不能超 14M。
对 ADC 工作参数具体配置:设为独立模式,单通道采集无需扫描,启动连续转换,采用内部软件触发,数据右对齐,转换通道选 1,调用 ADC_Init 函数完成 ADC1 工作环境配置。
使用 ADC_RegularChannelConfig 函数绑定 ADC 通道转换顺序和时间,它有 4 个形参,分别用于选择 ADC 外设、通道、转换顺序和采样周期,采样周期影响转换数据输出周期与精度。
利用 ADC 转换完成中断可确保读取到稳定数据,通过 ADC_ITConfig 函数使能该中断,在中断服务函数中读取转换结果数据,以此实现 ADC 稳定且准确的转换与数据读取。
输出结果
