电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » Let'sdo2025年第3期—过程贴01:颜色传感器
2025-12-04 11:25:13     打赏
先在白色环境下校准白平衡:
然后就可以开始测试识别颜色了,采集识别到的颜色会在屏幕上再显示出来:
源码如下:
import time
import board
import digitalio
import displayio
import terminalio
from adafruit_display_text import label
import neopixel
# TCS3200 传感器类
class TCS3200:
    def __init__(self, s0, s1, s2, s3, out_pin):
        self.s0 = s0
        self.s1 = s1
        self.s2 = s2
        self.s3 = s3
        self.out = out_pin
        self.s0.direction = digitalio.Direction.OUTPUT
        self.s1.direction = digitalio.Direction.OUTPUT
        self.s2.direction = digitalio.Direction.OUTPUT
        self.s3.direction = digitalio.Direction.OUTPUT
        self.out.direction = digitalio.Direction.INPUT
        # 白平衡校准值
        self.white_r = 1.0
        self.white_g = 1.0
        self.white_b = 1.0
        # 颜色校正参数
        self.color_threshold = 0.15  # 颜色阈值,低于此值的颜色分量将被设为0
        self.calibration_mode = False  # 校准模式标志
    def set_frequency(self, freq_mode):
        if freq_mode == 0:  # 2%
            self.s0.value = False
            self.s1.value = False
        elif freq_mode == 1:  # 20%
            self.s1.value = True
        elif freq_mode == 2:  # 100%
            self.s0.value = True
        else:
    def set_color_channel(self, color):
        if color == 'R':
            self.s2.value = False
            self.s3.value = False
        elif color == 'G':
            self.s2.value = True
            self.s3.value = True
        elif color == 'B':
    def calibrate_white(self, out_pin):
        """执行白平衡校准,获取白色表面的RGB频率值"""
        text_label.text = "White balance calibration...\nPoint sensor at white surface"
        display.refresh()
        time.sleep(2)
        # 测量白色表面的RGB频率
        self.set_color_channel('R')
        time.sleep(0.2)
        self.white_r = measure_frequency(out_pin)
        self.set_color_channel('G')
        time.sleep(0.2)
        self.white_g = measure_frequency(out_pin)
        self.set_color_channel('B')
        time.sleep(0.2)
        self.white_b = measure_frequency(out_pin)
        print(f"White balance calibration complete: R={self.white_r}, G={self.white_g}, B={self.white_b}")
    def frequency_to_rgb(self, freq_r, freq_g, freq_b):
        """将频率值转换为RGB(0-255)值"""
        # 避免除以0
        if self.white_r <= 0: self.white_r = 1
        if self.white_g <= 0: self.white_g = 1
        if self.white_b <= 0: self.white_b = 1
        # 计算相对值并转换为0-255范围
        r = min(255, int(255 * freq_r / self.white_r))
        g = min(255, int(255 * freq_g / self.white_g))
        b = min(255, int(255 * freq_b / self.white_b))
        # 颜色校正:增强颜色饱和度,减少偏色
        # 找出最大值
        max_val = max(r, g, b)
        if max_val > 0:
            # 计算阈值,低于阈值的颜色分量设为0
            threshold = max_val * self.color_threshold
            if g < threshold: g = 0
            if b < threshold: b = 0
            if r < threshold: r = 0
        return (r, g, b)
    def adjust_color_threshold(self, delta):
        """调整颜色阈值参数"""
        self.color_threshold = max(0.05, min(0.5, self.color_threshold + delta))
        print(f"Color threshold adjusted to: {self.color_threshold:.2f}")
        return self.color_threshold
# 频率测量
NUM_CYCLES = 10
def measure_frequency(out_pin):
    timestamps = []
    last = out_pin.value
    while len(timestamps) < NUM_CYCLES:
        current = out_pin.value
        if current != last:
            timestamps.append(time.monotonic_ns())
            last = current
    periods = []
    for i in range(2, len(timestamps), 2):
        period = timestamps[i] - timestamps[i-2]
        periods.append(period)
    avg_period = sum(periods) / len(periods)
    return 1_000_000_000 / avg_period
# TFT 显示设置
display = board.DISPLAY
splash = displayio.Group()
display.root_group = splash
text_label = label.Label(
    font=terminalio.FONT,
    text="Initializing...",
    color=0xFFFFFF,
    scale=1,
    x=10,
    y=30
splash.append(text_label)
# 用于显示颜色的矩形块
color_bitmap = displayio.Bitmap(60, 60, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0x000000  # 初始黑色
color_tilegrid = displayio.TileGrid(color_bitmap, pixel_shader=color_palette, x=150, y=20)
splash.append(color_tilegrid)
# 硬件引脚分配
s0 = digitalio.DigitalInOut(board.D3)
s1 = digitalio.DigitalInOut(board.D4)
s2 = digitalio.DigitalInOut(board.D5)
s3 = digitalio.DigitalInOut(board.D6)
out_pin = digitalio.DigitalInOut(board.D9)
# 校准按键 (D1) - 按下时为高电平
calibrate_button = digitalio.DigitalInOut(board.D1)
calibrate_button.direction = digitalio.Direction.INPUT
# 不需要上拉电阻,因为按键按下时为高电平
# 调整颜色阈值按键 (D2) - 按下时为高电平
adjust_button = digitalio.DigitalInOut(board.D2)
adjust_button.direction = digitalio.Direction.INPUT
sensor = TCS3200(s0, s1, s2, s3, out_pin)
sensor.set_frequency(2)  # 100% 模式
# 初始化NeoPixel
pixel = neopixel.NeoPixel(board.NEOPIXEL, 1)
pixel.brightness = 0.3
# 主循环
# 启动时执行白平衡校准
sensor.calibrate_white(out_pin)
text_label.text = "Calibration complete\nStarting color recognition...\nPress D1 (HIGH) to recalibrate\nPress D2 (HIGH) to adjust color"
display.refresh()
time.sleep(1)
# 主循环
while True:
    # 检查是否需要重新校准(带消抖)
    if calibrate_button.value:
        # 简单消抖:等待一小段时间确认按键仍然被按下
        time.sleep(0.05)
            display.refresh()
            # 等待按键释放
            while calibrate_button.value:
                time.sleep(0.01)
            time.sleep(0.5)  # 额外延迟防止重复触发
    # 检查是否需要调整颜色阈值(带消抖)
    if adjust_button.value:
        time.sleep(0.05)
            # 每次按下增加0.05的阈值
            sensor.adjust_color_threshold(0.05)
            # 等待按键释放
            while adjust_button.value:
                time.sleep(0.01)
    sensor.set_color_channel('R')
    time.sleep(0.05)
    freq_r = measure_frequency(out_pin)
    sensor.set_color_channel('G')
    time.sleep(0.05)
    freq_g = measure_frequency(out_pin)
    sensor.set_color_channel('B')
    time.sleep(0.05)
    freq_b = measure_frequency(out_pin)
    # 将频率转换为RGB值
    r, g, b = sensor.frequency_to_rgb(freq_r, freq_g, freq_b)
    # 更新 TFT 色块为当前颜色
    color_palette[0] = (r << 16) | (g << 8) | b
    # 更新NeoPixel颜色
    pixel.fill((r, g, b))
    text_label.text = (
        f"Frequency:   RGB Value\n"
        f"R: {freq_r:6.1f}    {r:3}\n"
        f"G: {freq_g:6.1f}    {g:3}\n"
        f"B: {freq_b:6.1f}    {b:3}\n"
        f"Threshold: {sensor.color_threshold:.2f}\n"
        f"D1(HIGH):cal D2(HIGH):adj"
    display.refresh()
    time.sleep(0.1)
