工程使用24MHz主频。需要引入<math.h>
#include "AI8051U.h"
#include "intrins.h"
#include "stdio.h"
#include "math.h"
5#define MAIN_Fosc 24000000UL
volatile unsigned long int near uint1, uint2;
volatile unsigned long int near xuint;
volatile long int sint1, sint2;
volatile long int xsint;
unsigned long ultest;
long ltest;
sbit TPIN = P1^0;
#define Baudrate 115200L
#define TM (65536 -(MAIN_Fosc/Baudrate/4))
#define PrintUart 1 //1:printf 使用 UART1; 2:printf 使用 UART2
/******************** 串口打印函数 ********************/
void UartInit(void)
#if(PrintUart == 1)
S1_S1 = 0; //UART1 switch to, 0x00: P3.0 P3.1, 0x40: P3.6 P3.7, 0x80: P1.6 P1.7, 0xC0: P4.3 P4.4
S1_S0 = 1;
SCON = (SCON & 0x3f) | 0x40;
T1x12 = 1; //定时器时钟1T模式
S1BRT = 0; //串口1选择定时器1为波特率发生器
TL1 = TM;
TH1 = TM>>8;
TR1 = 1; //定时器1开始计时
// SCON = (SCON & 0x3f) | 0x40;
// T2L = TM;
// T2H = TM>>8;
// AUXR |= 0x15; //串口1选择定时器2为波特率发生器
#else
S2_S = 1; //UART2 switch to: 0: P1.2 P1.3, 1: P4.2 P4.3
S2CFG |= 0x01; //使用串口2时,W1位必需设置为1,否则可能会产生不可预期的错误
S2CON = (S2CON & 0x3f) | 0x40;
T2L = TM;
T2H = TM>>8;
AUXR |= 0x14; //定时器2时钟1T模式,开始计时
#endif
void UartPutc(unsigned char dat) {
#if(PrintUart == 1)
SBUF = dat;
while(TI==0);
TI = 0;
#else
S2BUF = dat;
while(S2TI == 0);
S2TI = 0; //Clear Tx flag
#endif
char putchar(char c) {
UartPutc(c);
return c;
void delay(unsigned char ms) {
int p = ms*2000;
while(--p);
void PLL_Init() {
// CLKSEL &= ~0x80; //选择PLL的96M(*8)作为PLL的输出时钟
CLKSEL |= 0x80; //选择PLL的144M(*12)作为PLL的输出时钟
USBCLK &= ~0x60;
// USBCLK |= 0x00; //PLL输入时钟为12M则选择1分频
// USBCLK |= 0x20; //PLL输入时钟为24M则选择2分频
USBCLK |= 0x40; //PLL输入时钟为48M则选择4分频
// USBCLK |= 0x60; //PLL输入时钟为96M则选择8分频
USBCLK |= 0x80; //启动PLL
delay(1000); //等待PLL锁频,建议50us以上
HSCLKDIV = 0; //高速外设时钟源不分频
TFPU_CLKDIV = 0; //TFPU时钟源不分频
// CLKSEL &= ~0x40; //选择系统时钟作为高速外设时钟源
CLKSEL |= 0x40; //选择PLL时钟作为高速外设时钟源
volatile float f1=3.9;
volatile float f2=5.1;
volatile float f3=0;
void main(void) {
WTST = 0; //设置程序指令延时参数,赋值为0可将CPU执行指令的速度设置为最快
EAXFR = 1; //扩展寄存器(XFR)访问使能
CKCON = 0; //提高访问XRAM速度
P0M1 = 0x00; P0M0 = 0x00; //设置为准双向口
P1M1 = 0x00; P1M0 = 0x00; //设置为准双向口
P2M1 = 0x00; P2M0 = 0x00; //设置为准双向口
P3M1 = 0x00; P3M0 = 0x00; //设置为准双向口
P4M1 = 0x00; P4M0 = 0x00; //设置为准双向口
P5M1 = 0x00; P5M0 = 0x00; //设置为准双向口
P6M1 = 0x00; P6M0 = 0x00; //设置为准双向口
P7M1 = 0x00; P7M0 = 0x00; //设置为准双向口
UartInit();
PLL_Init();
// DMAIR = 0x3e; //TFPU使用系统时钟作为时钟源
DMAIR = 0x3f; //TFPU使用高速外设时钟作为时钟源
//*** 必须设置此句,TFPU才能使用高速时钟作为时钟源 ***
while(1) {
TPIN=1;
f3 = sqrt(f1);
TPIN=0;
}1、有TFPU
1.373微秒
2、无TFPU
44.352微秒
这个差距也是很大,使用TFPU的优越性特别明显。
