电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » ADC采样之Timer周期触发DMA自动搬运
2026-06-20 23:57:23     打赏
在一个电流采样的典型嵌入式应用项目中,我们需要持续 对采样电阻进行采样,以得出当前电流值。项目描述仅仅简单几句,但其内涵着许多硬性要求:
  1. 要有ADC外设采样
  2. 要按固定周期采样,如10ms
  3. 采样RAW值,需要保存在SRAM缓存区
  4. 采样在多次采样,再执行滤波算法
没有想到吧!一个普通的ADC采样竟然包含这么多的技术点。我们现在就一项一项来解决。我们以STM32F407为示例,使用AIN3通道为示例,并以10ms为周期对电流进行采样。我们先通过配置ADC的IN3通道的配置属性:
TIM2来实现10ms的中断触发:
我们再来看看关键代码生成:
  * @brief TIM2 Initialization Function
  * @param None
  * @retval None
static void MX_TIM2_Init(void)
  /* USER CODE BEGIN TIM2_Init 0 */
  /* USER CODE END TIM2_Init 0 */
  TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  TIM_MasterConfigTypeDef sMasterConfig = {0};
  /* USER CODE BEGIN TIM2_Init 1 */
  /* USER CODE END TIM2_Init 1 */
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 83;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = 9999;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV2;
  htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
  if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
    Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
    Error_Handler();
  * @brief ADC1 Initialization Function
  * @param None
  * @retval None
static void MX_ADC1_Init(void)
  /* USER CODE BEGIN ADC1_Init 0 */
  /* USER CODE END ADC1_Init 0 */
  ADC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN ADC1_Init 1 */
  /* USER CODE END ADC1_Init 1 */
  /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.ScanConvMode = DISABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
  hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T2_TRGO;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
  sConfig.Channel = ADC_CHANNEL_3;
  sConfig.Rank = 1;
  sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
爽不爽!有了固定周期的采样还可以计算电压电流的增量,也就是电量计。
