电子产品世界 » 论坛首页 » 行业应用 » 汽车电子 » 【RA6M4】驱动DockerPi4继电器
2026-08-09 15:26:34   被打赏 35 分(兑奖)     打赏
【简介】
本地在压测过程中需要使用继电器模块,手头正好有个 DockerPi 4  继电器。查看继电器的使用手册用起来是很简单对应的I2C通信接口来控制继电器。以下是 DockerPi 4   的Feature 说明对应模块有四路的的继电器通路,硬件上通过I2C的接口来控制支持3A 250V AC和3A 30V DC 的参数。
   对应寄存器模块的I2C 7bit 的访问地址可以通过拨码开关来配置,默认拨码地址为0x10.
对应的寄存器配置也很简单每每个通道对应一个寄存器地址,写入0关闭 1/255 开启。
本地通过瑞萨的RA6M4 的开发板来控制该寄存器模组配置好I2C接口即可 控制  DockerPi 4  模块,对应的I2C配置如下:
配置完成后后添加如下的测试代码来控制继电器。
#include <string.h>
#include <stdlib.h>
#include "dev_i2c.h"
#include "bsp_api.h"
#include "hal_data.h"
*                                      LOCAL CONSTANTS
*                                       LOCAL FUNCTIONS
*                                       LOCAL VARIABLES
static uint8_t i2c_init = 0;
volatile i2c_master_event_t g_i2c_callback_event;
*                          LOCAL TYPEDEFS (STRUCTURES, UNIONS, ENUMS)
*                                   LOCAL FUNCTION PROTOTYPES
int32_t ra6m4_i2c_master_xfer(struct dev_i2c_bus *bus,
struct dev_i2c_msg *msgs,
uint32_t           num)
/* Set i2c slave address */
R_SCI_I2C_SlaveAddressSet(&g_i2c3_ctrl, msgs[0].addr, I2C_MASTER_ADDR_MODE_7BIT);
for(uint32_t i = 0; i < num; i++)
if((msgs[i].flags  == DEV_I2C_RD) == 0)
printf("I2C write.\r\n");
R_SCI_I2C_Write(&g_i2c3_ctrl, msgs[i].buf, msgs[i].len, true);
else
printf("I2C read.\r\n");
/* read */
R_SCI_I2C_Read(&g_i2c3_ctrl, msgs[i].buf, msgs[i].len, true);
return 0;
static int i2c_probe(char addr)
fsp_err_t err;
if(i2c_init == 0)
err = R_SCI_I2C_Open(&g_i2c3_ctrl,&g_i2c3_cfg);
if(FSP_SUCCESS != err)
mini_printf("i2c init failed %d \r\n",err);
else
i2c_init = 1;
if(i2c_init)
/* Send data to I2C slave on the same channel */
R_SCI_I2C_SlaveAddressSet(&g_i2c3_ctrl, addr, I2C_MASTER_ADDR_MODE_7BIT);
static uint8_t data;
data = 0x00;
uint32_t timeout = 0x1000;
/* Send data to I2C slave */
g_i2c_callback_event = I2C_MASTER_EVENT_ABORTED;
err = R_SCI_I2C_Write(&g_i2c3_ctrl, &data, 1, true);
mini_printf("i2c write failed %d \r\n",err);
/* Since there is nothing else to do, block until Callback triggers*/
while ((I2C_MASTER_EVENT_TX_COMPLETE != g_i2c_callback_event) && timeout)
timeout--;
return (g_i2c_callback_event == I2C_MASTER_EVENT_TX_COMPLETE) ? 1 : 0 ;
static void i2c_scan(uint8_t start_addr, uint8_t stop_addr)
mini_printf("    00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F");
uint8_t pos = start_addr <= 0xF? 0x00: start_addr & 0xF;
for(; pos < stop_addr; pos++)
if((pos & 0xF) == 0)
printf("\r\n%02X: ", pos);
if(pos < start_addr)
mini_printf("   ");
continue;
if( i2c_probe(pos) == 1)
printf("%02X", pos);
else
printf("--");
printf(" ");
printf("\r\n");
*                                       GLOBAL VARIABLES
*                                       GLOBAL CONSTANTS
*                                       GLOBAL FUNCTIONS
void sci_i2c_master_callback(i2c_master_callback_args_t *p_args)
switch(p_args->event)
case I2C_MASTER_EVENT_TX_COMPLETE:
g_i2c_callback_event = I2C_MASTER_EVENT_TX_COMPLETE;
break;
case I2C_MASTER_EVENT_ABORTED:
break;
default:
break;
unsigned int i2c(char argc, char **argv)
if(strcmp(argv[1],"scan") == 0)
i2c_scan(0x00,0x7f);
else if(strcmp(argv[1],"send") == 0)
static struct dev_i2c_msg msg;
msg.addr = myatoi(argv[2]);
msg.flags = DEV_I2C_WR;
msg.len = 2;
static uint8_t data[2];
data[0] = myatoi(argv[3]);
data[1] = myatoi(argv[4]);
msg.buf = &data[0];
ra6m4_i2c_master_xfer(NULL, &msg, 1);
else if(strcmp(argv[1],"recv") == 0)
msg.flags = DEV_I2C_RD;
msg.len = 1;
msg.buf = &data;
printf("recv data: %02x\r\n", data);
return 0;
通过 i2c  scan 接口读取到I2C 0X10 的地址状态信息。
本地试验通过i2c send 控制四路继电器的吸合和关闭。
