电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » Let'sdo2026年第3期—开箱与电机驱动
2026-11-16 23:06:24     打赏
感谢Digikey和EEPW联合举办的Let's do 2026年第3期基于边缘AI的电机状态检测活动。本次活动我选用的器件包括NUCLEO-H533RE、LIS3DH 加速计传感器评估板、电机驱动模块,如下图所示。
本次活动需要实现的功能包括电机驱动、加速计传感器获取三轴的加速度参数,以及最终通过NanoEdgeAI判断电机运行状态。本文将实现电机驱动的相关功能。
根据电机驱动板接线图,可以看到需要有4个输入信号用于确定电机状态,这4个信号可以组成8种通电线序,实现电机旋转
在STM32CubeMX中选取开发板NUCLEO-H533RE,并选取了开发板上连续的4个引脚作为向电机的信号输出
设计电机控制代码如下,其核心原理为定时器提供时间基准,IN1-IN4依次导通控制电机旋转
  * @file    step_motor.c
  * @brief   Step motor state machine implementation.
  * Non-blocking design:
  *   - StepMotor_Tick() runs every iteration of the main loop. It compares
  *     HAL_GetTick() against last_step_tick to decide whether to advance the
  *     phase index, and against last_led_tick to decide whether to toggle the
  *     status LED.
  *   - StepMotor_ButtonHandler() records debounced button events in EXTI13;
  *     the main loop processes them in StepMotor_Tick().
#include "step_motor.h"
/* Private constants ---------------------------------------------------------*/
/* 8-step half-step sequence, HIGH-active. Column order: IN1, IN2, IN3, IN4. */
static const uint8_t halfstep_seq[8][4] = {
    {1, 0, 0, 0},  /* step 0: A         */
    {1, 1, 0, 0},  /* step 1: A + B     */
    {0, 1, 0, 0},  /* step 2: B         */
    {0, 1, 1, 0},  /* step 3: B + C     */
    {0, 0, 1, 0},  /* step 4: C         */
    {0, 0, 1, 1},  /* step 5: C + D     */
    {0, 0, 0, 1},  /* step 6: D         */
    {1, 0, 0, 1}   /* step 7: D + A     */
/* Step interval (ms) per state. Index 0 (STOP) is unused. */
static const uint16_t step_interval_ms[4] = {0, 3, 2, 1};
/* LED blink half-period (ms) per state. 0 means "solid on"; STOP forces off
 * inside Tick regardless of table value.                                    */
static const uint16_t led_blink_period_ms[4] = {0, 0, 500, 150};
/* Debounce window for the user button (ms). */
#define BUTTON_DEBOUNCE_MS  200U
/* Private variables ---------------------------------------------------------*/
static StepMotor_State_t motor_state = STATE_STOP;
static uint8_t phase_index = 0;
static uint32_t last_step_tick = 0;
static uint32_t last_led_tick = 0;
static volatile uint8_t button_pending = 0;
static uint32_t last_btn_tick = 0;
/* Private function prototypes -----------------------------------------------*/
static void apply_phase(uint8_t i);
static void coils_off(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Write IN1..IN4 according to the half-step sequence row i.
  * @param  i  Phase index in [0, 7].
    GPIO_PinState s;
    s = (halfstep_seq[i][0] != 0) ? GPIO_PIN_SET : GPIO_PIN_RESET;
    HAL_GPIO_WritePin(IN1_GPIO_Port, IN1_Pin, s);
    s = (halfstep_seq[i][1] != 0) ? GPIO_PIN_SET : GPIO_PIN_RESET;
    HAL_GPIO_WritePin(IN2_GPIO_Port, IN2_Pin, s);
    s = (halfstep_seq[i][2] != 0) ? GPIO_PIN_SET : GPIO_PIN_RESET;
    HAL_GPIO_WritePin(IN3_GPIO_Port, IN3_Pin, s);
    s = (halfstep_seq[i][3] != 0) ? GPIO_PIN_SET : GPIO_PIN_RESET;
    HAL_GPIO_WritePin(IN4_GPIO_Port, IN4_Pin, s);
  * @brief  De-energize all four coils.
    HAL_GPIO_WritePin(IN1_GPIO_Port, IN1_Pin, GPIO_PIN_RESET);
    HAL_GPIO_WritePin(IN2_GPIO_Port, IN2_Pin, GPIO_PIN_RESET);
    HAL_GPIO_WritePin(IN3_GPIO_Port, IN3_Pin, GPIO_PIN_RESET);
    HAL_GPIO_WritePin(IN4_GPIO_Port, IN4_Pin, GPIO_PIN_RESET);
/* Exported functions --------------------------------------------------------*/
  * @brief  Initialize the controller. Coils off, LED off, state = STOP.
void StepMotor_Init(void)
    phase_index    = 0;
    last_step_tick = HAL_GetTick();
    last_btn_tick  = HAL_GetTick() - BUTTON_DEBOUNCE_MS;
    last_led_tick  = HAL_GetTick();
    button_pending = 0;
    coils_off();
    BSP_LED_Off(LED_GREEN);
  * @brief  Periodic update — advances the phase and toggles the LED.
  *         Designed to be called from the main while(1) loop on every pass.
void StepMotor_Tick(void)
    uint32_t now = HAL_GetTick();
    uint32_t primask = __get_PRIMASK();
    uint8_t pressed;
    StepMotor_State_t st;
    __disable_irq();
    pressed = button_pending;
    button_pending = 0;
    __set_PRIMASK(primask);
    if (pressed != 0U) {
        motor_state = (StepMotor_State_t)(((uint32_t)motor_state + 1U) & 0x03U);
        if (motor_state == STATE_STOP) {
            coils_off();
        } else {
            phase_index = 0;
            last_step_tick = now;
            last_led_tick = now;
    st = motor_state;
    /* --- LED heartbeat --------------------------------------------------- */
    if (st == STATE_STOP) {
    } else if (st == STATE_RUN_SLOW) {
        BSP_LED_On(LED_GREEN);
    } else {
        /* RUN_MED / RUN_FAST: blink at led_blink_period_ms[st] half-period. */
        uint16_t period = led_blink_period_ms[st];
        if (period > 0 && (uint32_t)(now - last_led_tick) >= period) {
            BSP_LED_Toggle(LED_GREEN);
    /* --- Stepping (only in RUN states) ---------------------------------- */
        return;
    uint16_t interval = step_interval_ms[st];
    if ((uint32_t)(now - last_step_tick) >= interval) {
        apply_phase(phase_index);
        phase_index = (uint8_t)((phase_index + 1U) & 0x07U);
  * @brief  Record a debounced button press from BSP_PB_Callback.
void StepMotor_ButtonHandler(void)
    /* Debounce: ignore presses within BUTTON_DEBOUNCE_MS of the last one. */
    if ((uint32_t)(now - last_btn_tick) < BUTTON_DEBOUNCE_MS) {
        return;
    last_btn_tick = now;
    button_pending = 1U;
其中我还设置了电机转速控制和灯光控制,按下开发板上的用户按键后电机每一相之间的切换时间变化,从而调整电机转动速度
在main函数中,调用电机控制函数实现电机转动以及按键调速
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
    StepMotor_Tick();
实现效果如下
完整工程代码如下
motor_control.zip
关键词: 开箱     电机驱动     STM32H5
