Li rxisr..is finsish.x 2.4 rxisr..is finsish.00010000>] [<00010 rxisr..is finsish.iety NET3.039 rxisr..is finsish.000 0000 0000 0000 rxisr..is finsish.0reate: Forcing si *** ILLEGAL INSTRUCTION *** FORMAT=4 sh 20: Child 29 died In rx Current process id is 4t d4: fffffffe d5: 00000001 a0: 0018e27a a1: 80000054 Process kswapd (pid: 4, stackpage=00fea000) Frame format=4 Stack from 00fead5c: 00002004 00000001 00feaddc 00004390 00000080 00000000 00fead78 00000000 00002004 00000000 fffffffe 00000001 00000000 00075300 00000001 000001c5 000001c5 00000000 42002000 0000d2e4 00002004 00000000 fffffffe 00000001 00ea8980 fffffffd 00000000 000e4934rxisr..is finsish. 000e4960 000e5714 00000000 42942000 00feadec 0000abb8 00002004 00000000 00feae14 0000aab4 00000000 00000001 fffffffe 0013f940 00002704 0013f940 000e493c 000e4934 00feae3c 0000a81c Call Trace: [<00002004>] [<00004390>] [<00002004>] [<00075300>] [<0000d2e4>] [<00002004>] [<0000abb8>] [<00002004>] [<0000aab4>] [<00002704>] [<0000a81c>] [<00004104>] [<00019806>] [<00002000>] [<0001c622>] [<0001c776>] [<0001ac6c>] [<0001535a>] [<0001559a>] [<00015820>] [<000155fe>] [<0001566a>] [<00010f00>] [<00015778>] [<000157ac>] [<000072b6>] [<000157c8>] [<00007244>] [<000158f6>] [<00010f00>] [<0000211e>] Code: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 Kernel panic: Aiee, killing interrupt handler
In interrupt handler - not syncing 我在调试M5429,中断时出现上述错误,请问是什么原因?
我用的UCLINUX 系统.
