电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 关于加载ATA(1,0)的警告?
共5条 1/1 1 跳转至页
关于加载ATA(1,0)的警告?
2005-05-19 16:32:01     打赏
谁能帮帮我? 我在VxWorks中加载CF卡(当作ATA使用),它作为IDE1的主盘,但在启动以后出现下面的报警: Attaching to ATA disk device... done. Loading /ata0 VxWorks...2450384 Starting at 0x308000...
WARNING: Failed to create 131072 bytes of disk cache ATA disk /ata0a configured without cache Error creating partition manager: 850001 RTL8139 irq=43 RTL8139: vector = 344
Attached TCP/IP interface to rtl unit 0 Attaching interface lo0...done
VxWorks
Copyright 1984-2002 Wind River Systems, Inc.
CPU: PC PENTIUM Runtime Name: VxWorks Runtime Version: 5.5.1 BSP version: 1.2/3 Created: May 18 2005, 16:13:53 WDB Comm Type: WDB_COMM_END WDB: Ready.
0x77ffe44 (tRootTask): cbioWrapBlkDev: BLK_DEV pointer 0x077b454c appears invalid. 0x77ffe44 (tRootTask): cbioWrapBlkDev: BLK_DEV pointer 0x077b454c appears invalid. 0x77ffe44 (tRootTask): cbioWrapBlkDev: BLK_DEV pointer 0x00000000 appears invalid.
为什么会出现下面的警告???? 1. WARNING: Failed to create 131072 bytes of disk cache ATA disk /ata0a configured without cache Error creating partition manager: 850001 ???????? 2. 0x77ffe44 (tRootTask): cbioWrapBlkDev: BLK_DEV pointer 0x077b454c appears invalid. 0x77ffe44 (tRootTask): cbioWrapBlkDev: BLK_DEV pointer 0x077b454c appears invalid. 0x77ffe44 (tRootTask): cbioWrapBlkDev: BLK_DEV pointer 0x00000000 appears invalid. ????????
关键词: 关于     加载     警告
2005-05-20 17:10:00     打赏
谢谢楼上的兄弟!
但是我用的usrAtaConfig(1, 0, "/ata0"),我的目标机上确实没有IDE0的主盘,只有IDE1的主盘!
2005-05-23 17:19:00     打赏
谢谢楼上的兄弟们!
2005-05-24 00:59:00     打赏
为什么我在调用usrAtaConfig函数时,它会给出乱码信息?
if ( usrAtaConfig( 1, 0, "/ata0" ) == ERROR ) { printf( "UsrAtaConfig Failed!\n" ); } usrAtaConfig函数返回值正确,但输出了乱码信息,而且每次编译后的乱码信息都不一样:
2005-05-27 16:59:00     打赏
从硬盘加载vxworks文件,需要修改config.h的一些宏
共5条 1/1 1 跳转至页
