共3条
求助班竹!!!!
#define _IO_ADDRESS(r) ((r)+0xf0000000)
unsigned int READREG(unsigned int r)
volatile unsigned int * reg;
reg = (volatile unsigned int*) _IO_ADDRESS(r);
return *reg;
void WRITEREG(unsigned int r, unsigned int val)
volatile unsigned int *reg;
*reg = val;
return;
中是针对MX1关于LCD的一段代码,其中的#define _IO_ADDRESS(r) ((r)+0xf0000000)
为什么要加0XF0000000不加的话才对啊!
关键词: 求助 班竹
共3条
