电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » ip地址改了,MAC 也改了,可是这里去ping不通
2005-06-21 21:47:20     打赏
(ipmacset是自己写的修改ip\mac的函数)通过ipmacset命令后,ip地址改了,MAC 也改了,可是这里去ping不通, 并且bootline中的目标板的地址却还是原来的,启动时显示的mac还是原来的,奇怪!!
-> ipmacset
ixe0 MAC address: 00:02:b3:3c:16:68 ixe1 MAC address: 00:02:b3:3c:16:69
ixe0 IP address: 169.254.113.143 ixe1 IP address: 169.254.113.144
Any Changes (y/n)> y
Change a MAC address (y/n)> y ixe0 MAC address: 00:02:b3:3c:16:68 00:02:b3:3c:16:68 ixe1 MAC address: 00:02:b3:3c:16:69 00:02:b3:3c:16:64
Change ixe IP address (y/n)> y ixe0 IP address: 169.254.113.143 169.254.113.146 ixe1 IP address: 169.254.113.144 169.254.113.147
ixe0 MAC address: 00:02:b3:3c:16:68 ixe1 MAC address: 00:02:b3:3c:16:64
ixe0 IP address: 169.254.113.146 ixe1 IP address: 169.254.113.147
Change a MAC address (y/n)> n
Change ixe IP address (y/n)> n
Any Changes (y/n)> n
Writing interface data to non-volatile storage... New configuration written, changes will take effect after a reboot value = 0 = 0x0 -> reboot 系统重新启动后。。。
-> ipmacset
Any Changes (y/n)> n value = 0 = 0x0 ->
-> ping "169.254.113.146",1,0 ping: timeout no answer from 169.254.113.146 value = -1 = 0xffffffff -> ping "169.254.113.147",1,0 ping: timeout no answer from 169.254.113.147 value = -1 = 0xffffffff -> ip地址从这里看是改了,MAC 也改了,可是这里去ping不通, 并且bootline中的目标板的地址却还是原来的,奇怪!! '.' = clear field; '-' = go to previous field; ^D = quit
boot device : ixe1 processor number : 0 host name : host file name : vxworks inet on ethernet (e) : 169.254.113.144 inet on backplane (b): host inet (h) : 169.254.113.140 gateway inet (g) : user (u) : xjb ftp password (pw) (blank = use rsh): 1 flags (f) : 0x0 target name (tn) : startup script (s) : other (o) : ixe0 value = 0 = 0x0
关键词: 地址     可是     这里     不通     address
