共1条
请教大虾
architecture behav of test1 is
type my_state is(state1,state2);
signal p_state,n_state:my_state;
signal n:integer range 0 to 10;
begin
process(p_state,hf1)
begin
case p_state is
when state1 =>
n<=0;
dataout<="00000000";
if(hf1='0') then
n_state<=state2;
else
n_state<=state1;
end if;
when state2 =>
dataout<=datain1;
n<= n + 1;
if(n = 10) then
n_state<=state1;
else
n_state<=state2;
end if;
when others =>
null;
end case;
end process;
process(rst,clk)
begin
if(rst='1') then
p_state<=state1;
elsif(clk='1' and clk'event) then
p_state<=n_state;
end if;
end process;
end behav;
本意想在状态为state2时,把10个输入送给输出,然后又回到state1
结果仿真的时候,发现在state2情况下,n并不是在每个时钟
的上升沿递增,而是一系列很乱的数字,象毛刺似的,状态也就一直
处于state2下,但小弟我实在看不出程序哪儿有问题,请教大虾
我用的是max+plus2 10.0版本
谢谢
关键词: 请教 大虾
共1条
| 为遥控小车巧添功能被打赏¥26元 | |
