共1条
ISA Bus Technical Summary(2)
4.0 ISA Bus Timing Diagrams
8-Bit I/O Bus Cycles
________
BALE __| |_________________________________________
_ ______________________________________________ __
SA(15:0) _><______________________________________________><__
-SBHE
______________ _______
-IOR/W |______________________________|
_____________
SD(7:0) -------------------------------------<_____________>-
(READ)
SD(7:0) ----------------<__________________________________>-
(WRITE)
__________________ _ _ _ _ _ _ _ _ _ _ _ _ _________
I/OCHRDY |________________________|
8-Bit Memory Bus Cycles
_____
BALE ________| |______________________________________
_ ________________ ________________________________
LA(23:17) _><________________><________________________________
_______ ________________________________________ __
SA(19:0) _______><________________________________________><__
-MEMR/W |______________________________|
_____________
(READ)
(WRITE)
16-Bit I/O Bus Cycles
________
BALE ______________| |_____________________________
_____________ __________________________________ __
SA(15:0) _____________><__________________________________><__
_________________ ___
-IOCS16 |_______________________________|
_____________________ ______
-IOR/W |________________________|
__________________
SD(15:0) -----------------------------<__________________>----
(READ)
SD(15:0) -----------------------<________________________>----
(WRITE)
_______________________ _ _ _ _ _ _ _ _ _ _ ______
I/OCHRDY |___________________|
16-Bit Memory Bus Cycles (1 or more Wait States)
______
BALE _________________| |____________________________
___ ________________________ ______________________
LA(23:17) ___><________________________><______________________
________________ ________________________________ _
SA(19:0) ________________><________________________________><_
-MEMCS16 |______________________|
-MEMR/W |_____________________|
_______________
SD(15:0) --------------------------------<_______________>----
(READ)
SD(15:0) --------------------------<_____________________>----
(WRITE)
__________________________ _ _ _ _ _ _ _ _ __________
I/OCHRDY |_______________|
16-Bit Memory Bus Cycles (0 Wait State)
______
________________ _________________________ ________
SA(19:0) ________________><_________________________><________
_________________________ ______________________
-0WS |____|
-MEMR/W |___________|
______
SD(15:0) --------------------------------<______>-------------
(READ)
____________
SD(15:0) --------------------------<____________>-------------
(WRITE)
DMA Read
______________
DRQ(n) __| |___________________________________
-DACK(n) |__________________________|
AEN,BALE ________| |_______
_______________ ___________________________ _______
SA(15:0) _______________><___________________________><_______
-SBHE
________________ ________________________ _________
SA(19:16) ________________><________________________><_________
LA(23:17)
-MEMR |_____________________|
____________
SD(15:0) -------------------------------<____________>--------
-IOW |__________________|
__________
TC _______________________________| |__________
I/OCHRDY |______|
DMA Write
______________
-SBHE
LA(23:17)
-IOR |_____________________|
____________
-MEMW |__________________|
__________
I/OCHRDY |______|
Alternate Bus Master Cycles
-MASTER |__________________________|
AEN ________| |__________________________| |_
_____________________________________________________
BALE ________| |_
________________________ ___________ ______________
SA(19:0) ________________________><___________><_______________
-SBHE
LA(23:17) ________________________><___________><______________
_____________________________ _________________
-IOR,-IOW |_____|
-MEMR,-MEMW
_____
SD(15:0) -------------------------------<_____>---------------
Memory Refresh Cycles
-REFRESH |_____________________|
_________________ ____________ ____________________
SA(9:0) _________________><____________><____________________
-SMEMR |_____________|
_________________________ _ _ _ _ ___________________
I/OCHRDY |_______|
关键词: Technical Summary
共1条
