电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 请高手指点LPC2131中断问题
共3条 1/1 1 跳转至页
请高手指点LPC2131中断问题
2005-10-07 03:53:49     打赏
在调试一个ZLG的LPC2131的开发板中,分别都能工作正常的定时器和串口中断处理程序,在先后都使能后却只有定时器中断处理程序工作正常,而串口中断处理程序得不到调用。对此深感疑惑,请指点迷津 ....... VICIntSelect = 0x00000000; // 设置所有的通道为IRQ中断 VICVectCntl0 = (0x20 | 0x06); // UART0分配到IRQ slot0,即最高优先级 VICVectAddr0 = (uint32)UART0_Handler; // 设置UART0向量地址 VICIntEnable = (1 << 0x06); // 使能UART0中断 ...... VICVectAddr1 = (uint32)Timer0_Handler; VICVectCntl1 = (0x20 | 0x04); VICIntEnable = (1 << 4); ...... [em35][em35]
关键词: 高手     指点     LPC2131     中断     问题
2005-10-10 06:34:00     打赏
进一步试验发现在定时器函数中屏蔽UCOS的OSTimeTick就可以正常响应UART0中断,这是为什么呢?否则UART0的中断处理函数根本无法被调用到。是中断重入有问题? void Timer0_Exception(void) { uint32 regBak; regBak = VICIntEnable; VICIntEnClr = ( 1<<0x04)|(1<<0x06); VICVectAddr = 0x00; // 中断处理结束 T0IR = 0x01; /* OSTimeTick();*/ VICIntEnable = regBak; } [em06][em06]
2005-10-11 05:59:00     打赏
应该是比较普通的操作,屏蔽掉其中关、开中断的操作代码也是一样的现象 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ { ptcb = OSTCBList; while (ptcb->OSTCBPrio != OS_IDLE_PRIO) { OS_ENTER_CRITICAL(); if (ptcb->OSTCBDly != 0) { if (--ptcb->OSTCBDly == 0) { if ((ptcb->OSTCBStat & OS_STAT_SUSPEND) == OS_STAT_RDY) { OSRdyGrp |= ptcb->OSTCBBitY; OSRdyTbl[ptcb->OSTCBY] |= ptcb->OSTCBBitX; } else { ptcb->OSTCBDly = 1; } } } ptcb = ptcb->OSTCBNext; OS_EXIT_CRITICAL(); } } +++++++++++++++++++++++++++++++++++++++++++++++++++++++ OS_ENTER_CRITICAL(): __asm { MRS R0, SPSR ORR R0, R0, #NoInt MSR SPSR_c, R0 } OsEnterSum++; +++++++++++++++++++++++++++++++++++++++++++++++++++ OS_EXIT_CRITICAL() __asm { MRS R0, SPSR BIC R0, R0, #NoInt MSR SPSR_c, R0 } [em48]
共3条 1/1 1 跳转至页
