电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » select串口通讯容易丢失数据
select串口通讯容易丢失数据
2006-02-15 22:46:52     打赏
串口设置:
ioctl(SerialDevFd, FIOBAUDRATE, 115200);
/* set to 'line‘ mode */
ioctl(SerialDevFd, FIOSETOPTIONS, OPT_TERMINAL & OPT_LINE );
/* set to data bits*/
ioctl(SerialDevFd, SIO_HW_OPTS_SET,8);
接受:
FD_ZERO (&readFds);
/* initialize bit mask */
FD_SET (SerialDevFd, &readFds);
width = SerialDevFd + 1;
/* loop forever reading data and servicing clients */
FOREVER
/* pend, waiting for one or more fds to become ready */
if ((numbit=select (width, &readFds, NULL, NULL, NULL)) == ERROR)
printf("typereadr: ERROR\n");
printf("typereadr: number=%d\n",numbit);
/* check if this fd has data to read */
if (FD_ISSET (SerialDevFd, &readFds))
FOREVER
bzero (buffer, MAX_DATA);
/* typically read from fd now that it is ready */
if ( (DataLen = read (SerialDevFd, buffer, MAX_DATA))==ERROR )
printf("typereadr: ERROR Reading\n");
/* normally service request, for this example print it */
printf ("typereadr: Reading...DataLen=%d %s\n",DataLen,(char*)buffer );
if(DataLen == 0)
break;
printf("typereadr: Read OK!");
出现问题:接受打印的数据很容易丢失?谢谢关注!!1
关键词: select     串口     通讯     容易     丢失     数据
2006-02-17 00:59:00     打赏
能给个中断接受的例子么?
