电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 编译uclinux时出错
编译uclinux时出错
2006-03-07 17:11:38     打赏
用的是uclinux-dist-20040408.tar.gz和arm-elf-tools-20030314.sh
make menuconfig选择samsung 4510b,make dep ,make clean,make lib_only,make romfs,都顺利通过。。。。到了make image,有个错,
arm-elf-objcopy: /usr/local/uClinux-dist/linux-2.4.x/linux: ?????????
make[1]: *** [image] Error 1
make[1]: Leaving directory `/usr/local/uClinux-dist/vendors/Samsung/4510B'
make: *** [image] Error 2
我忽略。。
但是到了make 时,就出错。。
drivers/block/block. In function `blk_dev_init':
/usr/local/uClinux-dist/linux-2.4.x/drivers/block/ll_rw_blk.c:1506: undefined reference to `romfs_data'
make[1]: *** [linux] Error 1
make[1]: Leaving directory `/usr/local/uClinux-dist/linux-2.4.x'
make: *** [linux] Error 1
大家帮我看看这是为什么了?
关键词: 编译     uclinux     出错
