电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » ~~求助!~~VXWORKS下点灯程序Data abort??
共3条 1/1 1 跳转至页
2006-06-08 19:14:23     打赏
请教各位高手:我的S3C4510B的demo板下,vxworks已经下载成功,我在usrAppInit.c中加进去了点灯测试程序,出现Data abort, Exception address:0x0000c278的错误。
点灯部分程序如下:
#define IOPMOD (*(volatile unsigned *)0x3ff5000)
#define IOPDATA (*(volatile unsigned *)0x3ff5008)
unsigned char ledtab[]={0xfe,0xfd,0xfb,0xf7,
0xef,0xdf,0xbf,0x7f};
void out(unsigned int port,unsigned int val)
volatile unsigned *p=(volatile unsigned *)port;
printf("in function :out \n");
*p=val;
printf("leave function :out \n");
void ledshow()
int i;
struct timespec t;
t.tv_sec = 0;
t.tv_nsec = 500000000;
printf("in function :ledshow \n");
for(i=0;i<8;i++)
out(IOPDATA,ledtab[i]);
nanosleep(&t, NULL);
printf("leave function :ledshow \n");
void usrAppInit (void)
#ifdef USER_APPL_INIT
USER_APPL_INIT; /* for backwards compatibility */
#endif
int i=0;
struct timespec t;
t.tv_sec = 0;
/* add application specific code here */
printf("hello!!now run ledshow!\n");
out(IOPMOD,0xff);
while(1)
ledshow();
关键词: 求助     VXWORKS     点灯     程序     abort
2006-06-08 22:16:00     打赏
seasoblue [code]<SCRIPT language=javascript type=text/javascript>
document.write (astro('1975-11-10'));
</script>[/code]
谢谢你啊 果然是这里出错了 真的很感谢 现在我成功了
2006-06-08 22:20:00     打赏
不好意思 刚才复制你的名字的时候出错了
seasoblue 谢谢你啊
共3条 1/1 1 跳转至页
