ATMEGA128,UART0 新鲜出炉的串口测试程序.ATMEGA128 UART0
问
//串口通讯 ,PE0-Rxd0,PE1-Txd0,返回的数据是发送的数据
#include <iom128.h>
#define xtal 3686400 //晶振16MHZ
#define baud0 19200 //波特率
#define baud1 19200 //波特率
SFR_B(UBRR0H, 0x90) // USART0 Baud Rate Register High
SFR_B(UBRR0L, 0x09) // USART0 Baud Rate Register Low
SFR_B(UCSR0B, 0x0A) // USART0 Control and Status Register B
SFR_B(UCSR0A, 0x0B) // USART0 Control and Status Register A
SFR_B(UDR0, 0x0C) // USART0 I/O Data Register
SFR_B(UCSR0C, 0x95) // USART0 Control and Status Register C
串口初始化
// USART0 initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART0 Receiver: On
// USART0 Transmitter: On
// USART0 Mode: Asynchronous
void init_uart0(void)
UCSR0B = 0x00; //disable while setting baud rate
UCSR0A = 0x00;
UCSR0C =(1<<UCSZ01)|(1<<UCSZ00);//8bit+1bit stop
UBRR0L=(xtal/16/(baud0+1))%256;
UBRR0H=(xtal/16/(baud0+1))/256;
UCSR0B =(1<<RXEN0)|(1<<TXEN0)|(1<<RXCIE0);//RXCEN TXCEN RXCIE
发送数据函数
void trans_byte(unsigned char d)
while ( !( UCSR0A & (1<<UDRE0)) )
; // Wait for empty transmit buffer
UDR0 = d;
接收数据函数
unsigned char rece_byte( void )
while ( !(UCSR0A & (1<<RXC0)) )
; // Wait for data to be received
return UDR0;
主 函 数
void main(void)
//PORTA=0;
//DDRA=0xff;
init_uart0();
while(1)
trans_byte(rece_byte());
答 1: 申明:参考了一网友先前发布的代码,在此致谢.IAR 编译. 用丁丁的SSCOM3.2测试.
#include <iom128.h>
串口初始化
UCSR0A = 0x00;
发送数据函数
UDR0 = d;
接收数据函数
return UDR0;
主 函 数
void main(void)
//PORTA=0;
//DDRA=0xff;
init_uart0();
while(1)
