mega8,AD mega8的AD程序问题
问
下面的程序转换到的数据总是0x89左右,而实际上引脚电压只有0.01V左右。
#define VREF 0x00
#define ADPS 0x06
void init_adc(void)
ACSR = _BV(ACD);
ADMUX = _BV(ADLAR) | VREF;
ADCSRA = _BV(ADEN) | ADPS;
uint8_t adc(uint8_t chn)
uint8_t res;
ADMUX |= chn;
ADCSRA |= _BV(ADSC);
loop_until_bit_is_clear(ADCSRA, ADSC);
res = ADCH;
return res;
} 答 1: 太容易了。例程:
config adc = single,prescale=auto,reference=internal
x=getadc(0)
What are you want to do?
答 2: 这个函数哪里有?我用的是WINAVR,有么?
#define VREF 0x00
#define ADPS 0x06
void init_adc(void)
ACSR = _BV(ACD);
uint8_t res;
ADMUX |= chn;
res = ADCH;
return res;
} 答 1: 太容易了。例程:
x=getadc(0)
