cy68013 请用过cy68013的大侠们指教,谢谢!
问
我想用68013实现简单的数据传输,但要求很高的可靠性,现在硬件已经出来了,用开发板的软件试了下官方提供的例程(bulkloop)能正常运行.上位机的软件准备用VB来做,调用其驱动ezUSB.sys需要调用API函数creatfile()和iocontrol()由于上位机编程是第一次,所以没经验,现在主要问题是:
1:如何获得设备的句柄?
2:获得句柄后如果想发送数据或读取数据(bulk传输),发送的控制信号(调用iocontrol())的顺序是怎样的?下位机要作怎样的反应呢?
3:有没有用VB编好的样例程序可以参考?
谢谢各位!
答 1: 没有人用过吗? 答 2: 学习!请问你的硬件是哪种模式的啊?
是从FIFO模式的吗? 答 3: 我没有用到FIFO模式,我的要求主要在于可靠性对速度的要求不是很高.硬件比较容易,照经典电路一次就成功了.
为什么这段程序打不开呢?Createfile()返回的总是-1
哪位用VB做过的指点一下啊,谢谢!
Private Sub Form_Load()
'Handle HidDevice
Dim HidDevice As Long
DevicePathName = "\\.\ezUSB-0"
HidDevice = CreateFile _
(DevicePathName, _
GENERIC_WRITE, _
FILE_SHARE_WRITE, _
0, _
OPEN_EXISTING, _
0, _
0)
'INVALID_HANDLE_VALUE = -1
If (HidDevice = INVALID_HANDLE_VALUE) Then
'OpenDevice = False
'Form1.Shape6.Height = (MaxTemper - 0) * TemperScale
MsgBox " 未发现与之通信的USB设备!" + _
Chr(13) & Chr(10) + _
" 请确定其硬件设备是否已连接," + _
"并确定其驱动程序是否已加载。", _
17, "错误"
Else
MsgBox " 发现与之通信的USB设备!" + _
" 请确定," + _
"!", _
1, "成功打开设备"
'OpenDevice = True
End If
End Sub
Public Declare Function CreateFile _
Lib "kernel32" _
Alias "CreateFileA" _
(ByVal lpFileName As String, _
ByVal dwDesiredAccess As Long, _
ByVal dwShareMode As Long, _
ByRef lpSecurityAttributes As Long, _
ByVal dwCreationDisposition As Long, _
ByVal dwFlagsAndAttributes As Long, _
ByVal hTemplateFile As Long) _
As Long
'API constants.
'IOCTL Code
'Public Const FILE_DEVICE_UNKNOWN = &H22
Public Const CyUSB_IOCTL_INDEX = &H800
Public Const METHOD_BUFFERED = &H0
Public Const FILE_ANY_ACCESS = &H0
'CreateFile
Public Const GENERIC_READ = &H80000000
Public Const GENERIC_WRITE = &H40000000
Public Const FILE_SHARE_READ = &H1
Public Const FILE_SHARE_WRITE = &H2
Public Const OPEN_EXISTING = 3
'Public Const INVALID_HANDLE_VALUE = -1
1:如何获得设备的句柄?
谢谢各位!
哪位用VB做过的指点一下啊,谢谢!
'Handle HidDevice
(DevicePathName, _
GENERIC_WRITE, _
FILE_SHARE_WRITE, _
0, _
OPEN_EXISTING, _
0, _
0)
'OpenDevice = False
"并确定其驱动程序是否已加载。", _
17, "错误"
Else
" 请确定," + _
"!", _
1, "成功打开设备"
'OpenDevice = True
End If
End Sub
Lib "kernel32" _
As Long
'API constants.
'IOCTL Code
'CreateFile
| 为遥控小车巧添功能被打赏¥26元 | |
