EEPROM,25AA640,VC33 【求助】串行EEPROM 25AA640与VC33的C语言读写程序
问
十万火急!!!我现在正在调试25AA640,已经整了两个星期了还没调通,不知道问题出在哪里了?请各位大虾帮忙检查一下下面的程序!!小弟不胜感激。。。
我的接线如下:
SI--->FSX0;
SO--->FSR0;
SCK-->XF0;
CS--->XF1;
附程序:
#define SET_DSP_IO0 SERIAL_PORT_CONTROL1 |= 0x0400
#define CLR_DSP_IO0 SERIAL_PORT_CONTROL1 &= (0xffff-0x0400)
#define SO SERIAL_PORT_CONTROL2 &= 0x0800
#define SET_SCK IOF|= 0x04
#define CLR_SCK IOF&= (0xff-0x04)
#define SET_CS IOF|= 0x40
#define CLR_CS IOF&= (0xff-0x40)
void main(void)
{ int a;
a=0;
SERIAL_PORT_CONTROL1 = 0x0222;
SERIAL_PORT_CONTROL2 = 0x0022;
IOF=0x22;
CLR_SCK;
CLR_CS;
WriteEEPROM(8,0x06);
SET_CS;
CLR_SCK;
CLR_CS;
WriteEEPROM(8,0x02);
CLR_SCK;
WriteEEPROM(16,0x0100);
CLR_SCK;
WriteEEPROM(8,0x55);
CLR_SCK;
SET_CS;
CLR_SCK;
CLR_CS;
WriteEEPROM(8,0x03);
SET_SCK;
CLR_SCK;
a=ReadEEPROM(8)& 0xff;
SET_CS;
CLR_SCK;
void WR_EN(void)
CLR_CS;
SET_CS;
int RD_SR(void)
{ int j;
CLR_CS;
WriteEEPROM(8,0x05);
j=ReadEEPROM(8);
SET_CS;
return j;
void WR_SR(void)
CLR_CS;
SET_CS;
CLR_CS;
WriteEEPROM(8,0x01);
WriteEEPROM(8,0x00);
SET_CS;
StopEEPROM();
void WriteEEPROM(int iBits,int iValue)
do {
CLR_SCK;
Delay_100NS();
ADDR_EEPROM = iValue >> (iBits - 1);
iBits--;
if((ADDR_EEPROM&0x01)==0)
CLR_DSP_IO0;
else
SET_DSP_IO0;
SET_SCK;
Delay_100NS();
}while(iBits != 0);
int ReadEEPROM(int iBits)
int iData;
iData=0x00;
ADDR_EEPROM=0x00;
do{
SET_SCK;
Delay_100NS();
CLR_SCK;
Delay_100NS();
CLR_SCK;
Delay_100NS();
ADDR_EEPROM=SERIAL_PORT_CONTROL2>>11;
iData|=(ADDR_EEPROM & 0x01)<<(iBits-1);
iBits--;
CLR_SCK;
Delay_100NS();
}while(iBits !=0 );
return iData;
void StopEEPROM(void) /* 等待8位数据写完 */
int iData;
do {
CLR_CS;
iData=RD_SR();
SET_CS;
}while((iData & 0x01)!=0); /*fake check the last bit */
void Delay_100NS()
unsigned int i,j;
for(i=0;i<10;i++) {j=i;}
答 1: 个人觉得应该是程序有问题最好还是自己单步调试程序,发现问题, 答 2: 我知道程序有问题,可我找不出来阿! 大哥,我已经找了2个多星期了还是没有找出问题来!能不能帮我检查检查啊。。。
我的接线如下:
SI--->FSX0;
SO--->FSR0;
SCK-->XF0;
CS--->XF1;
附程序:
void main(void)
{ int a;
a=0;
IOF=0x22;
CLR_SCK;
CLR_CS;
SET_CS;
CLR_SCK;
CLR_CS;
CLR_SCK;
CLR_SCK;
CLR_SCK;
SET_CS;
CLR_SCK;
CLR_CS;
SET_SCK;
CLR_SCK;
SET_CS;
CLR_SCK;
void WR_EN(void)
CLR_CS;
SET_CS;
int RD_SR(void)
{ int j;
CLR_CS;
j=ReadEEPROM(8);
SET_CS;
return j;
void WR_SR(void)
CLR_CS;
SET_CS;
CLR_CS;
SET_CS;
StopEEPROM();
do {
CLR_SCK;
Delay_100NS();
iBits--;
CLR_DSP_IO0;
else
SET_DSP_IO0;
SET_SCK;
Delay_100NS();
}while(iBits != 0);
int iData;
iData=0x00;
ADDR_EEPROM=0x00;
do{
SET_SCK;
Delay_100NS();
CLR_SCK;
Delay_100NS();
CLR_SCK;
Delay_100NS();
iBits--;
CLR_SCK;
Delay_100NS();
}while(iBits !=0 );
return iData;
int iData;
do {
CLR_CS;
iData=RD_SR();
SET_CS;
void Delay_100NS()
unsigned int i,j;
