电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » 16,LCD 分享:2*16字符型LCD程序
2006-09-17 18:14:16     打赏
关键词: 分享     字符型     程序
2006-12-22 22:43:00     打赏
问 #include<reg51.h>
//#include <intrins.h>
#define uchar unsigned char
bit bflag;
//sbit LIGHT=P0^4;
sbit P1_0=P1^0;
sbit P1_2=P1^2;
sbit RS=P2^0;//4jiao
sbit RW=P2^1;//5jiao
sbit E=P2^2;//6jiao
void lcd_clear(void);    /*清屏*/
void lcd_chekbusy(void);     /*测试忙*/
void lcd_wrcmd(uchar lcd_cmd);    /*写命令*/
void lcd_wrdata(uchar lcd_data);    /*写数据*/
void lcd_moveto(uchar position);    /*写要显示的地方*/
//void lcd_cursor ( uchar cursor_cmd );    /*光标控制*/
void lcd_init(void);    /*初始化*/
void delay(uchar x)
    uchar i;
    do
    for(i=0;i<125;i++)
    while (x--);
    uchar middle;
    do
        RS=0;
        RW=1;
        E=1;
        //delay(10);
        middle=P0;
        E=0;
        bflag=(0x80&middle);
    while(bflag==1);
    bflag=1;
    //delay(1);
    RS=0;
    RW=0;
    E=1;
    P0=lcd_cmd;
    //delay(1);
    E=0;
    //lcd_chekbusy();
    //delay(1);
    //lcd_chekbusy();
    RS=1;
    RW=0;
    E=1;
    P0=lcd_data;
    E=0;
    //lcd_chekbusy();
    lcd_wrcmd (0x01);
void lcd_moveto(uchar position)        /*position为从左起算起1--16 */
    uchar temp_1;
    //lcd_chekbusy();
    if (position<16)
        temp_1=(position+0x80-1);
    else
        temp_1=((position-16)+0xc0);/////////////////已经修改
    lcd_wrcmd(temp_1);
    //lcd_chekbusy();
    //delay ( 1 );
void lcd_wrstr( uchar *pdispstrda ) /* 函数 */
{    uchar i;
    lcd_wrcmd(0x80); /*设置显示数据RAM*/
    for (i=0;i<=7;i++)
        lcd_wrdata(*pdispstrda);/* char of LCM */
        pdispstrda++;
    lcd_wrcmd(0xc0); /*设置显示数据RAM*/
    for (i=0;i<=7;i++)
        pdispstrda++;
void lcd_wrchar(uchar lcd_add,uchar lcd_data)
    lcd_moveto(lcd_add);
    lcd_wrdata(lcd_data);
void lcd_init(void)
{    uchar i;
    delay(20);
    for(i=0;i<8;i++)
    {    lcd_wrcmd(0x30);
        delay(5);
    //lcd_chekbusy();
    lcd_wrcmd(0x38);
    lcd_chekbusy();
    lcd_wrcmd(0x0c);
    lcd_chekbusy();
    lcd_wrcmd(0x06);
    lcd_chekbusy();
    lcd_wrcmd(0x01);
    lcd_chekbusy();
main()
    uchar dis_string[16]={"this is a test"};
    uchar i,j,k;
    k=1;
    P0=0xff;
    P2=0xff;
    P1_2=1;
    P1_0=0;
    lcd_init();
bee:
    lcd_moveto(1);
    j='A';
    for(i=0;i<16;i++)
        delay(1);
        lcd_wrdata(j);
        j++;
    lcd_wrcmd(0xc0);
    for(i=0;i<16;i++)
        delay(1);
        lcd_wrdata(j);
        j++;
    delay(250);
    lcd_wrstr(dis_string);
    lcd_clear();
    delay(1);
    lcd_wrchar(3,'G');
    delay(1);
    lcd_wrdata('O');
    delay(1);
    lcd_wrdata('O');
    delay(1);
    lcd_wrdata('D');
    P1_2=~P1_2;
goto bee;
} 答 1: 楼主的LCD主控芯片是什么型号啊? 答 2: 应该是通用的1602 lcd吧 答 3: ts1620对不起,各位,忘说了.是内含hd44780的ts1620.
