际踅涣?W29C040 哪位能帮我一下,W29C040能读不能写
问
#include <INCLUDE.H>
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
sbit Cs29f040 = P2^7;
#define FALSE 0
#define TRUE 1
#define SECTOR_SIZE 4096 /* Must be 4096 bytes for 39VF080 */
#define BLOCK_SIZE 65536 /* Must be 64K bytes for 39VF080 */
#define SECTORLEN 256//128
#define SST_ID 0xBF /* SST Manufacturer's ID code */
#define SST_29SF040 0x13 /* SST39VF040 device code */
#define SST_39VF080 0xD8 /* SST39VF080 device code */
xdata uchar U6Add _at_ 0x6000 ;
idata uchar U6Data;
xdata WORD SST_id2;
xdata WORD SST_id1;
idata uint iFlashTmp1,iFlashTmp2;
xdata uchar cFlashTmp1,cFlashTmp2;
xdata uchar *pFlashTmp1;
xdata ulong FlashOneByteAdd;
xdata uchar FlashOneByte;
xdata ulong FlashNByteAdd,FlashAddTmp;
xdata uint FlashNByteLen;
xdata uchar *pFlashNByte;
xdata uchar SectorBuf[SECTORLEN];
extern xdata uchar ReBuf[];
extern union
ulong TmpLong;
uint TmpUint[2];
uchar TmpUchar[4];
}UTmpLong;
//使用的全局变量有pFlashTmp1,SST_id1 ,SST_id2 ;
uchar Check_SST_39VF080()
CFLASH=0;
vDelayMS(1);
U6Add=0x80; //高四位为0
/* Issue the Software Product ID code to 39VF080 */
pFlashTmp1= (BYTE xdata *)(0x5555+0x8000); /* set up address to be C000:5555h */
*pFlashTmp1= 0xAA; /* write data 0xAA to the address */
pFlashTmp1= (BYTE xdata *)(0x2AAA+0x8000); /* set up address to be C000:2AAAh */
*pFlashTmp1= 0x55; /* write data 0x55 to the address */
*pFlashTmp1= 0x90; /* write data 0x90 to the address */
vDelayMS(1);
/* Read the product ID from 39VF080 */
pFlashTmp1= (BYTE xdata *)0x8000; /* set up address to be C000:0000h */
SST_id1 = *pFlashTmp1; /* get first ID byte */
SST_id1 = SST_id1 & 0x00FF; /* mask of higher byte */
pFlashTmp1= (BYTE xdata *)0x8001; /* set up address to be C000:0001h */
SST_id2 = *pFlashTmp1; /* get second ID byte */
pFlashTmp1= (BYTE xdata *)0x8002; /* set up address to be C000:0001h */
U6Add=0x8f;//7fff2
pFlashTmp1= (BYTE xdata *)0xfff2; /* set up address to be C000:0001h */
/* Determine whether there is a SST39VF080 installed or not */
if ((SST_id1 == SST_ID) && (SST_id2 ==SST_29SF040))
SST_id1 = TRUE;
else
SST_id1 = FALSE;
/* Issue the Soffware Product ID Exit code thus returning the 39VF080 */
/* to the read operating mode */
//Read/Reset
*pFlashTmp1= 0xAA; _nop_(); /* write data 0xAA to the address */
*pFlashTmp1= 0x55; _nop_(); /* write data 0x55 to the address */
*pFlashTmp1= 0xF0; _nop_(); /* write data 0xF0 to the address */
//Delay_150_Nano_Seconds(); /* insert delay time = Tida */
DeyNTip(250);
CFLASH=1;
return(SST_id1 );
//使用到全局变量pFlashTmp1,FlashOneByte,FlashOneByteAdd
void Read_One_Byte ()
UTmpLong.TmpLong=(FlashOneByteAdd<<1);
U6Data&=0xf0;
U6Data+=UTmpLong.TmpUchar[1];
U6Add=U6Data; //置地址高4位
iFlashTmp1=(uint)FlashOneByteAdd;
iFlashTmp1|= 0x8000;
FlashOneByte=*(BYTE xdata *)iFlashTmp1;
#if 1
//使用到全局变量FlashNByteAdd,lashNByteLen,pFlashNByte
void Read_N_Byte (ulong Add,uint Len,uchar *pBuf)
xdata uint iTmp1;
CFLASH=0;
ET0=0;
for(iTmp1=0;iTmp1<Len;iTmp1++)
UTmpLong.TmpLong=(Add<<1);
U6Data&=0xf0;
//A15=OPENFLASH;
iFlashTmp1=(uint)Add;
*pBuf=*(BYTE xdata *)iFlashTmp1;
//下一个字节
Add++;
pBuf++;
A15=CLOSEFLASH;
ET0=1;
CFLASH=1;
#endif
xdata uint iTmp1;
CFLASH=0;
ET0=0;
U6Data&=0xf0;
A15=OPENFLASH;
//*pBuf=*(BYTE xdata *)iFlashTmp1;
PORT_2=iFlashTmp1>>8;
WR=1;
RD=0;
PORT_0=iFlashTmp1;
ALE=1;
_nop_();
ALE=0;
_nop_();_nop_();
*pBuf=PORT_0;
WR=1;
RD=1;
//下一个字节
Add++;
pBuf++;
A15=CLOSEFLASH;
ET0=1;
CFLASH=1;
void Erase_One_Sector()
return;
ResetWatchDog();
A15=OPENFLASH;
UTmpLong.TmpLong=(FlashNByteAdd<<1);
U6Data&=0xf0;
*(BYTE xdata *)0x5555 = 0xAA;
*(BYTE xdata *)0x2AAA = 0x55;
*(BYTE xdata *)0x5555 = 0x80;
iFlashTmp1=FlashNByteAdd;
iFlashTmp1|=0x8000;
//pFlashTmp1=(BYTE xdata *)iFlashTmp1;
//*pFlashTmp1=0x20;
*(BYTE xdata *)iFlashTmp1 =0x20;
vDelayMS(28);
ResetWatchDog();
data uchar CharTmp;
void Program_One_Sector()
if(FlashNByteAdd<ZIKUENDADDR)
return;
//A15=OPENFLASH;
//关闭写保护
ResetWatchDog();
U6Data&=0xf0;
*(BYTE xdata *)(0x5555+0x8000) = 0xAA;
*(BYTE xdata *)(0x2AAA+0x8000) = 0x55;
*(BYTE xdata *)(0x5555+0x8000) = 0x80;
*(BYTE xdata *)(0x5555+0x8000) = 0x20;
//vDelayMS(15);
//启动写保护时要加此三个字节的命令
ResetWatchDog();
U6Data&=0xf0;
*(BYTE xdata *)(0x5555+0x8000) = 0xA0;
FlashAddTmp=FlashNByteAdd;
UTmpLong.TmpLong=(FlashAddTmp<<1);
U6Data&=0xf0;
FlashAddTmp>>=8;
FlashAddTmp<<=8;
iFlashTmp1=(uint)FlashAddTmp;
iFlashTmp1|=0x8000;
for(iFlashTmp2=0;iFlashTmp2<SECTORLEN;iFlashTmp2++)
CharTmp=SectorBuf[iFlashTmp2];
*((BYTE xdata *)iFlashTmp1) =CharTmp;
iFlashTmp1++;
vDelayMS(15);
//填写FlashNByteAdd,flashNByteLen,pFlashNByte便可使用此函数
void Program_N_Byte ()
CFLASH=0;
EA=0;
//A15=OPENFLASH;
//计算页内偏移量
cFlashTmp2=(uchar)FlashNByteAdd;
//读取此页的内容出来
FlashAddTmp>>=8;
FlashAddTmp<<=8;
Read_N_Byte (FlashAddTmp,SECTORLEN,SectorBuf);
//擦除此扇区
Erase_One_Sector();
//重新组织此扇区的内容
if( FlashNByteLen>SECTORLEN-cFlashTmp2)
memcpy( (uchar *)&SectorBuf[cFlashTmp2], pFlashNByte, SECTORLEN-cFlashTmp2);
//将此扇区的内容写回
Program_One_Sector();
//已经写了SECTORLEN-cFlashTmp2个字节 指针后移
cFlashTmp2=SECTORLEN-cFlashTmp2;
FlashNByteLen-=cFlashTmp2;
pFlashNByte+=cFlashTmp2;
FlashNByteAdd+=cFlashTmp2;
else
//memmove ( pFlashNByte,&SectorBuf[cFlashTmp2], FlashNByteLen);
while(FlashNByteLen)
FlashNByteLen--;
SectorBuf[cFlashTmp2++]=*pFlashNByte++;
//将此扇区的内容写回
//FlashNByteLen=0;
A15=CLOSEFLASH;
EA=1;
CFLASH=1;
return;
//看有没有写完 (整页写)
while(FlashNByteLen>=SECTORLEN)
//擦除此扇区
Erase_One_Sector();
//组织此扇区的内容
memcpy(SectorBuf,pFlashNByte,SECTORLEN);
//将内容写回此扇区
//已经写了SECTORLEN个字节 指针后移
FlashNByteLen-=SECTORLEN;
pFlashNByte+=SECTORLEN;
FlashNByteAdd+=SECTORLEN;
//看有没有写完 (最后一页)
if(FlashNByteLen>0)
//计算页内偏移量
cFlashTmp2=FlashNByteAdd;
cFlashTmp2&=0x80;
//读取此页的内容出来
FlashNByteAdd>>=8;
FlashNByteAdd<<=8;
Read_N_Byte (FlashNByteAdd,SECTORLEN,SectorBuf);
//擦除此扇区
Erase_One_Sector();
//重新组织此扇区的内容
memcpy( SectorBuf, pFlashNByte, FlashNByteLen);
//将此扇区的内容写回
A15=CLOSEFLASH;
EA=1;
CFLASH=1;
#define FALSE 0
#define TRUE 1
idata uchar U6Data;
xdata WORD SST_id2;
xdata WORD SST_id1;
extern union
ulong TmpLong;
uint TmpUint[2];
uchar TmpUchar[4];
}UTmpLong;
CFLASH=0;
vDelayMS(1);
U6Add=0x80; //高四位为0
vDelayMS(1);
U6Add=0x8f;//7fff2
SST_id1 = TRUE;
else
SST_id1 = FALSE;
//Read/Reset
DeyNTip(250);
CFLASH=1;
return(SST_id1 );
U6Data&=0xf0;
#if 1
xdata uint iTmp1;
CFLASH=0;
ET0=0;
U6Data&=0xf0;
//A15=OPENFLASH;
//下一个字节
Add++;
pBuf++;
A15=CLOSEFLASH;
ET0=1;
CFLASH=1;
#endif
xdata uint iTmp1;
CFLASH=0;
ET0=0;
U6Data&=0xf0;
A15=OPENFLASH;
WR=1;
RD=0;
PORT_0=iFlashTmp1;
ALE=1;
_nop_();
ALE=0;
_nop_();_nop_();
*pBuf=PORT_0;
WR=1;
RD=1;
//下一个字节
Add++;
pBuf++;
A15=CLOSEFLASH;
ET0=1;
CFLASH=1;
return;
ResetWatchDog();
A15=OPENFLASH;
U6Data&=0xf0;
iFlashTmp1|=0x8000;
//*pFlashTmp1=0x20;
vDelayMS(28);
ResetWatchDog();
data uchar CharTmp;
return;
//A15=OPENFLASH;
//关闭写保护
ResetWatchDog();
U6Data&=0xf0;
//vDelayMS(15);
//启动写保护时要加此三个字节的命令
ResetWatchDog();
U6Data&=0xf0;
U6Data&=0xf0;
FlashAddTmp>>=8;
FlashAddTmp<<=8;
iFlashTmp1|=0x8000;
iFlashTmp1++;
vDelayMS(15);
CFLASH=0;
EA=0;
//A15=OPENFLASH;
//计算页内偏移量
//读取此页的内容出来
FlashAddTmp>>=8;
FlashAddTmp<<=8;
//擦除此扇区
Erase_One_Sector();
//重新组织此扇区的内容
//将此扇区的内容写回
else
FlashNByteLen--;
//将此扇区的内容写回
//FlashNByteLen=0;
A15=CLOSEFLASH;
EA=1;
CFLASH=1;
return;
//看有没有写完 (整页写)
//擦除此扇区
Erase_One_Sector();
//组织此扇区的内容
//将内容写回此扇区
//看有没有写完 (最后一页)
if(FlashNByteLen>0)
//计算页内偏移量
cFlashTmp2&=0x80;
//读取此页的内容出来
FlashNByteAdd>>=8;
FlashNByteAdd<<=8;
//擦除此扇区
Erase_One_Sector();
//重新组织此扇区的内容
//将此扇区的内容写回
A15=CLOSEFLASH;
EA=1;
CFLASH=1;
| SEGGER RTT常用API函数讲解被打赏¥14元 | |
| 嵌入式芯片调试神器-J-Link RTT被打赏¥21元 | |
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
