GCC,IO 用GCC怎样访问数据空间的绝对地址及IO口地址?
问
请问用GCC如何访问数据空间的绝对地址及IO口地址?
是否一定要内嵌汇编语句? 答 1: 我想不用,下面代码是刚刚调试通过的,请指教#define IC_0832_ADDR 0x7E0C /* A8=0 and must larger 0x25F */
#define IC_0804_ADDR 0x7D00 /* A9=0 and must larger 0x25F */
#define ic_0832_write(num) *(volatile uint8_t*)(IC_0832_ADDR) = num;
#define ic_0804_write(num) *(volatile uint8_t*)(IC_0804_ADDR) = num; 答 2: 能否解释一下上面的代码.谢谢 答 3: 访问如下://设置地址为0x6000:
volatile unsigned char *FIFOdata =(unsigned char*)0x6000;
//读出:
x=*FIFOdata;
//写入:
*FIFOdata=x; 答 4: 学习一下
//读出:
x=*FIFOdata;
//写入:
