uClinux uClinux移植遇到的问题求助
问
用的 是杭州立宇太的安装包,交叉编译工具为ARM-elf-tools-20030314.sh.但是make menuconfig 就出问题了.那位朋友能够指点下,刚刚用linux几乎什么都不懂.
[root@localhost root]# cd uClinux-dist
[root@localhost uClinux-dist]# make menuconfig
config/mkconfig > config.in
make -C /root/uClinux-dist/config/scripts/lxdialog all
make[1]: Entering directory `/root/uClinux-dist/config/scripts/lxdialog'
/bin/sh: line 1: cc: command not found
>> Unable to find the Ncurses libraries.
>> You must have Ncurses installed in order
>> to use 'make menuconfig'
make[1]: *** [ncurses] Error 1
make[1]: Leaving directory `/root/uClinux-dist/config/scripts/lxdialog'
make: *** [menuconfig] Error 2
答 1: linux没有装全 答 2: xiexie是不是少了GCC编译器呢 答 3: Unable to find the Ncurses libraries.
