WINCE 求助,我安装 WINCE 4.2 ,当我单击安装文件时,出现下面错误!
问
求助:
各位大哥我安装 WINCE 4.2 ,
当我单击安装文件(CE42 可执行安装文件)时,出现如附件所示的错误,
我单击:CE42 可是弹出的是:
:The Installscript enginge is missing from this machine.
if available,please run ISScript.msi,or contact your
support personnel for further assistance.
单击确定后,弹出
the wizard was interrupted before microsoft windows ce.net
4.2 could be completely installed.
to install this program at a later time ,please run the
instalation again .
各位大哥,到底是什么地方错了啊?
谢谢! 答 1: re求助,我下载了一个 WINCE 4.2 ,可是我单击 CE42.exe 时,出现下面的错误,请各位大哥帮我看看原因!谢谢
请教:
我下载了一个 WINCE 4.2 ,可是我单击 CE42.exe 时,出现下面的错误:
The Installscript enginge is missing from this machine,if available,please run ISScript.msi,
or contact your support personnel for further assistance.
我在微软的网站上找到下面的信息:
symptoms
when you try to install virtual pc 2004,you receive the following error message:
cause:
this issue occurs if you try to start virtual pc setup by using the microsoft virtual
pc 2004.msi file from virtual pc CD.
resolution:
to resolve this issue ,start virtual pc setup by using the setup.exe program,when you
run then setup.exe from the virtual pc CD,setup.exe automatically updates the windows
installer to the version that you need to install virtual pc 2004.
各位大哥,我是错在哪里啊?
要怎么改正呢?
礼致!
答 2: re那位大哥帮我鼎鼎落! 答 3: 急是没有用的也别到处发帖问了,
遇到问题的时候先考虑一下问题出在哪里,然后看看有什么方法解决,
象你这样到处乱问,估计没有多少人愿意帮你回答的
再说了,也不是人人都会碰到你这样的问题
csdn --- ldqmoon
各位大哥我安装 WINCE 4.2 ,
我单击:CE42 可是弹出的是:
单击确定后,弹出
instalation again .
各位大哥,到底是什么地方错了啊?
请教:
我在微软的网站上找到下面的信息:
symptoms
cause:
resolution:
各位大哥,我是错在哪里啊?
要怎么改正呢?
礼致!
再说了,也不是人人都会碰到你这样的问题
csdn --- ldqmoon
