44b0x [求助]44b0x是否可以接真彩屏,请各位大侠帮忙
问
我正在使用44b0x,现在手头有一块真彩的屏
我想用44b0x来驱动真彩,我的想法是,数据线只接RGB其中的一路,其他不接(悬空或者拉低)
控制线不变。
现在屏可以初始化,但是显示不了任何东西,控制寄存器的设置如下
时钟60Mhz clkavl=6
rLCDCON1=(0); //|(1<<5)|(0x3<<8)|(0x3<<10)|(CLKVAL<<12);
// disable,4B_SNGL_SCAN,WDLY=16clk,WLH=16clk,CLKVAL=?
rLCDCON2=(240-1)|(79<<10)|(10<<21);
//320x240LCD LINEBLANK=10 (without any calculation)
//LCD frame buffer should be inside aligned 4MB region, which ensures that
//LCDBANK value should not be changed when moving the view port.
/* LCDBANK=0xc000000>>22; //((U32)LCDBuffer16)>>22;
LCDBASEU=0x0; //((U32)LCDBuffer16)&0x3fffff;
LCDBASEL=LCDBASEU+(80)*240;
rLCDSADDR1= (0x2<<27) |(0x30<<21)|0;
//| ((((U32)LCDBuffer16)>>1)&0x7ffffff);
// 16-gray, LCDBANK, LCDBASEU
rLCDSADDR2= (0<<29)|(0<<21)|0x4b00;
rLCDSADDR3= (320/4) | ( 0<<9 );
//No virtual screen.
//The following value has to be changed for better display.
//Select 4 levels among 16 gray levels.
rLCDCON1=LCDCON1_ENVID|(1<<5)|(0x0<<8)|(0x3<<10)|(CLKVAL<<12);
请大家指教,这样做是不是不可行,还是需要其他改动
答 1: 外接显卡芯片 答 2: 不行的44B0不能直接接真彩屏
控制线不变。
时钟60Mhz clkavl=6
| 为遥控小车巧添功能被打赏¥26元 | |
