ARM2200 ARM2200编程中的语法疑问
问
定义如下:
void test(uint8 &a,uint8 &b)
uint8 c;
c=a;
a=b;
b=c;
一个包含引用的函数
编译时就会报错出来。。。
这里编译器难道不支持“引用”??
Error : C2285E: expected ')' or ',' - inserted ')' before '&'
test.c line 10
Error : C2285E: expected ';' or ',' - inserted ';' before '&'
test.c line 10
Error : (Serious) C2322E: Expecting <declarator> or <type> but found '&'
test.c line 10
test.c line 207
test.c line 207
test.c line 207
Error : C2285E: expected ';' or ',' - inserted ';' before '{'
test.c line 208
Error : (Serious) C2337E: Misplaced '{' at top level - ignoring block
test.c line 208
Error : C2456E: undeclared name, inventing 'extern int a'
test.c line 210
Error : C2456E: undeclared name, inventing 'extern int b'
test.c line 211
D:\test\20060802\lpc2200\src\test.c: 0 warnings, 7 errors, 3 serious errors
答 1: uint8 &c;定义出错 答 2: c不支持引用吧
uint8 c;
c=a;
a=b;
b=c;
一个包含引用的函数
编译时就会报错出来。。。
这里编译器难道不支持“引用”??
test.c line 10
test.c line 10
test.c line 10
test.c line 207
test.c line 207
test.c line 207
test.c line 208
test.c line 208
test.c line 210
test.c line 211
