ARM ARM是不是不能定义结构体???
问
代码:
#if (OS_MAX_EVENTS >= 2)
typedef struct {
void *OSEventPtr; /* Pointer to message or queue structure */
INT8U OSEventTbl[OS_EVENT_TBL_SIZE]; /* List of tasks waiting for event to occur */
INT16U OSEventCnt; /* Count of used when event is a semaphore */
INT8U OSEventType; /* OS_EVENT_TYPE_MBOX, OS_EVENT_TYPE_Q or OS_EVENT_TYPE_SEM */
INT8U OSEventGrp; /* Group corresponding to tasks waiting for event to occur */
} OS_EVENT;
#endif
编译后,出现错误:
type disagreement for "OS_EVENT"
哪里错了呢?
请高手帮忙!谢谢 答 1: 问题不在这里!问题不在这里!
我把这个STRUCT放到我的工程中,编译没有问题 答 2: 一定是你在EXTERN 的时候出了问题.
typedef struct {
} OS_EVENT;
#endif
编译后,出现错误:
哪里错了呢?
