Uboot Uboot编译问题,如何解决?
问
我的主机系统是FC4,ARM交叉编译工具是3.4.1。
uboot版本是1.1.4。默认编译怎么都通不过?
信息如下:
[root@localhost u-boot-1.1.4]# make
make[1]: Entering directory `/usr/u-boot-1.1.4/tools'
ln -s ../common/environment.c environment.c
ln -s ../lib_generic/crc32.c crc32.c
gcc -M -Wall -pedantic -idirafter ../include -DTEXT_BASE=0x33F80000 -DUSE_HOSTCC environment.c img2srec.c mkimage.c crc32.c envcrc.c gen_eth_addr.c bmp_logo.c > .depend
make[1]: Leaving directory `/usr/u-boot-1.1.4/tools'
make[1]: “.depend”是最新的。
make[1]: Entering directory `/usr/u-boot-1.1.4/examples'
/usr/usr/local/ARM/3.4.1/bin/ARM-linux-gcc -M -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x33F80000 -I/usr/u-boot-1.1.4/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/usr/local/ARM/3.4.1/bin/../lib/gcc/ARM-linux/3.4.1/include -pipe -DCONFIG_ARM -D__ARM__ -march=ARMv4 -mabi=apcs-gnu -Wall -Wstrict-prototypes hello_world.c stubs.c > .depend
cc1: error: invalid option `abi=apcs-gnu'
make[1]: *** [.depend] 错误 1
make[1]: Leaving directory `/usr/u-boot-1.1.4/examples'
make[1]: Entering directory `/usr/u-boot-1.1.4/post'
/usr/usr/local/ARM/3.4.1/bin/ARM-linux-gcc -M -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x33F80000 -I/usr/u-boot-1.1.4/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/usr/local/ARM/3.4.1/bin/../lib/gcc/ARM-linux/3.4.1/include -pipe -DCONFIG_ARM -D__ARM__ -march=ARMv4 -mabi=apcs-gnu -Wall -Wstrict-prototypes cache_8xx.S cache.c codec.c cpu.c DSP.c ether.c i2c.c memory.c post.c rtc.c spr.c sysmon.c tests.c uart.c USB.c watchdog.c > .depend
make[1]: Leaving directory `/usr/u-boot-1.1.4/post'
make[1]: Entering directory `/usr/u-boot-1.1.4/post/cpu'
/usr/usr/local/ARM/3.4.1/bin/ARM-linux-gcc -M -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x33F80000 -I/usr/u-boot-1.1.4/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/usr/local/ARM/3.4.1/bin/../lib/gcc/ARM-linux/3.4.1/include -pipe -DCONFIG_ARM -D__ARM__ -march=ARMv4 -mabi=apcs-gnu -Wall -Wstrict-prototypes asm.S cmp.c cmpi.c two.c twox.c three.c threex.c threei.c andi.c srawi.c rlwnm.c rlwinm.c rlwimi.c store.c load.c cr.c b.c multi.c string.c complex.c > .depend
make[1]: Leaving directory `/usr/u-boot-1.1.4/post/cpu'
make: *** [depend] 错误 2 答 1: 用3.3.4看看,最新的总是有问题的。 答 2: 啊大家帮忙看看啊,有什么解决方案? 答 3: 注意版本最好用redhat9.0 答 4: 呵呵 我也遇到类似问题uboot1.1.4编译不过去,换成uboot1.1.1就可以了,可能是GCC和uboot不兼容的问题,呵呵
信息如下:
| OrangePiZero2W系统被打赏¥33元 | |
