blx,symbol,symbol blx symbol 不跳转到symbol处是何故?
问
在ADS环境下,Project就包含一个C文件:
#include "stdio.h"
int main(void)
int a,b,c ;
a = 10;
b = 110;
c = a + b;
printf ("abcdefghijklmn\n");
c = a+ b;
c = a + b;
return c;
编译和链接都没有问题,运行也没问题。但是利用AXD调试时,如果看反汇编的代码,
main [0xe92d4070] stmfd r13!,{r4-r6,r14}
000000cc [0xe3a0500a] mov r5,#0xa
000000d0 [0xe3a0606e] mov r6,#0x6e
000000d4 [0xe0854006] add r4,r5,r6
000000d8 [0xe28f0010] add r0,pc,#0x10 ; #0xf0
000000dc [0xfa000008] blx _printf
000000e0 [0xe0854006] add r4,r5,r6
000000e4 [0xe0854006] add r4,r5,r6
_printf [0xb40f] push {r0-r3}
00000106 [0xb500] push {r14}
00000108 [0xb08f] sub r13,#0x3c
0000010a [0xa811] add r0,r13,#0x44
0000010c [0x0880] lsr r0,r0,#2
单步跟踪,发现blx _printf根本不会跳转到_printf符号处,而是直接执行下面的add r4,r5,r6指令,这是怎么回事啊?
请大家指点!谢谢! 答 1: 大家碰到过此类问题吗?
#include "stdio.h"
int main(void)
int a,b,c ;
a = 10;
b = 110;
c = a + b;
c = a+ b;
c = a + b;
return c;
