问
我用的是TKS-52S仿真器,用的是随机软件,但我想在C语言中嵌入汇编语句,参考Keil C书籍,用
#pragma asm
#pragma endasm
发现不行.
请教周先生,如何解决? 答 1: 这样!在C程序中
__asm {
NOP
...自己填代码
} 答 2: 试了,还是不行 答 3: 这样试试看!!1加库函数
__asm {
NOP("中间自己填,可参照资料")
答 4: 楼上的那个是ads中的用法,搂主换个编译器吧 答 5: 才注意到楼主用的是51仿真器,不好意思!好象Keil是不支持内联混合编程的! 答 6: 供参考!QUESTION
I have a problem with following in-line assembly code that I created from an old, existing assembly function:
unsigned char PutChar_I2C(unsigned char ch) {
#pragma asm
SETB MDE
MOV A,R7 ; get ch in ACC
MOV R7,#1 ; return value 1
CLR MCO
#pragma endasm
This code generated these warnings:
warning C280: 'ch': unreferenced local variable
warning C173: missing return-expression
The compiler generates this warning despite the fact I used the variable 'ch' (passed in R7). Also, why is there a warning for a missing return-expression since I set the return value in R7?
ANSWER
There are two solutions to your problem. Since the complete function is just assembly, you should leave it in a separate assembler module and just add the proper segment naming conventions. Then you may call the function from C as shown below:
Assembler Module:
?PR?_PutChar_I2C?FILE SEGMENT CODE
RSEG ?PR?_PutChar_I2C?FILE
PUBLIC _PutChar_I2C
_PutChar_I2C:
SETB MDE
CLR MCO
RET
Function Call from C:
extern unsigned char PutChar_I2C(unsigned char ch);
void main (void) {
val = PutChar_I2C (1);
Another solution is to add dummy statements to the C source file as shown below:
// dummy assignment to avoid warning
// 'unreferenced local variable'
ch = ch;
#pragma asm
SETB MDE
MOV R7,#1 ; return 1
CLR MCO
#pragma endasm
// dummy return to avoid warning
// 'missing return-expression'
return (ch);
The C51 compiler does not generate warnings. However, carefully review the generated code for these statements, and confirm that the variable 'ch' is correctly assigned to the parameter passing register R7 for the return value.
答 7: 几个链接!http://www.keil.com/support/docs/2308.htm
http://www.keil.com/support/docs/2622.htm
http://www.keil.com/support/docs/1671.htm
#pragma asm
#pragma endasm
发现不行.
__asm {
NOP
...自己填代码
__asm {
NOP("中间自己填,可参照资料")
#pragma asm
SETB MDE
CLR MCO
#pragma endasm
ANSWER
Assembler Module:
PUBLIC _PutChar_I2C
_PutChar_I2C:
SETB MDE
CLR MCO
RET
void main (void) {
ch = ch;
#pragma asm
SETB MDE
CLR MCO
#pragma endasm
return (ch);
| 为遥控小车巧添功能被打赏¥26元 | |
