STARTUP 恳请版主及大侠帮忙STARTUP.S:
问
LDR R0, =PINSEL2
IF :DEF: EN_CRP
LDR R1, =0x0f814910
ELSE
LDR R1, =0x0f814914
ENDIF
STR R1, [R0]
LDR R0, =BCFG0
LDR R1, =0x10000400
STR R1, [R0]
LDR R0, =BCFG1
LDR R1, =0x1000ffef
STR R1, [R0]
; LDR R0, =BCFG2
; LDR R1, =0x2000ffef
; STR R1, [R0]
LDR R0, =BCFG3 LDR R1, =0x10000CA0
STR R1, [R0]
BL InitStack ;³õʼ»¯¶ÑÕ»
BL TargetResetInit ;Ä¿±ê°å»ù±¾³õʼ»¯
;Ìø×ªµ½cÓïÑÔÈë¿Ú
B __main
LDR R1, =0x10000CA0,这个值在不同的例子里是要变的,但是它是如何设置的(每位的含义不清楚),找资料也没看到.
答 1: 详见使用指南可以设置读写周期等待时间等等,详细介绍可以看相关器件的使用指南:外部存储控制器(EMC)一节,在周立功网站上有pdf下载,中英文都有(英文有目录,好找一点)
LDR R0, =PINSEL2
IF :DEF: EN_CRP
LDR R1, =0x0f814910
ELSE
LDR R1, =0x0f814914
ENDIF
STR R1, [R0]
LDR R0, =BCFG0
LDR R1, =0x10000400
STR R1, [R0]
LDR R0, =BCFG1
LDR R1, =0x1000ffef
STR R1, [R0]
; LDR R0, =BCFG2
; STR R1, [R0]
STR R1, [R0]
;Ìø×ªµ½cÓïÑÔÈë¿Ú
B __main
