电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » ARM ARM菜鸟中断系统提高班学习笔记
2006-09-17 18:14:16     打赏
关键词: 菜鸟     中断     系统     提高班     学习     笔记
2006-12-22 22:43:00     打赏
问 /*----------------------------------------------------------------------
              ARM菜鸟外部中断及中断控制提高班学习结业笔记
HotPower@126.com  2005.7.22 于西安大雁塔村队部
/*  This file is part of the CA ARM C Compiler package                 */
/*  Copyright KEIL ELEKTRONIK GmbH 2002 - 2004                         */
/*  MAIN.C:  Demonstration of various interrupt functions              */
#include <LPC213x.H>    // Philips Peripheral Registers
#include "LPC213xDEF.H"    //ARM菜鸟HotPower创建定义文件
* software interrupt function accept parameters and run in
* supervisor mode (interrupt protected).
int myfunc1 (int i1, long i2) __swi (8)  {
  return (i1 / i2);
int myfunc2 (int i1) __swi (9)  {
  return (i1<<4);
void SetVICProtection(unsigned long val) __swi (10) {
  VICProtection = val;//VICProtection可以随意置'1',但清'0'必须在管理模式下
*具有特权保护的用户非向量中断,它只能在VICProtection=0时在用户模式下调用,比SWI更安全
void UserDefineIRQ (void) __irq {
  if (VICIRQStatus & (1 << VICIntSel_SoftInt31)) {
    IOPIN1 ^= (1 << P1_19);    //取反P1.19
    EXTINT = (1 << VICIntSel_SoftInt31);    //清除VICIntSel_SoftInt31中断标志
    VICSoftIntClr = (1 << VICIntSel_SoftInt31);
  VICVectAddr = 0;
* standard interrupt function saves only R0 - R12 and returns with
void DefaultIRQ (void) __irq {//VICIntSelect=0且VICVectCntl0~VICVectCntl15都未中断使能
unsigned long temp;
  temp = VICIRQStatus;
  if (temp & (1 << VICIntSel_EINT0)) {
    IOPIN1 ^= (1 << P1_16);    //取反P1.16
    EXTINT = (1 << EINT0);    //清除INT0中断标志
  else if (temp & (1 << VICIntSel_EINT1)) {
    IOPIN1 ^= (1 << P1_17);    //取反P1.17
    while(EXTINT & (1 << EINT1)) {
      EXTINT = (1 << EINT1);    //清除INT1中断标志
  else if (temp & (1 << VICIntSel_EINT2)) {
    IOPIN1 ^= (1 << P1_18);    //取反P1.18
    EXTINT = (1 << EINT2);    //清除INT2中断标志
  else if (temp & (1 << VICIntSel_EINT3)) {
    EXTINT = (1 << EINT3);    //清除INT3中断标志
  VICSoftIntClr = temp;
  VICVectAddr = 0;
void EINT0IRQ (void) __irq {//IRQ中断函数EINT0IRQ被挂接在VICVectCntl0
  if (VICIRQStatus & (1 << VICIntSel_EINT0)) {
  VICSoftIntClr = (1 << VICIntSel_EINT0);
  VICVectAddr = 0;
void EINT1IRQ (void) __irq {//IRQ中断函数EINT1IRQ被挂接在VICVectCntl1
  if (VICIRQStatus & (1 << VICIntSel_EINT1)) {
    IOSET1 = (1 << P1_17);    //P1.17=1
    IOCLR1 = (1 << P1_17);    //P1.17=0
    VICSoftIntClr = (1 << VICIntSel_EINT1);
  VICVectAddr = 0;
void EINT2IRQ (void) __irq {//IRQ中断函数EINT2IRQ被挂接在VICVectCntl2
  if (VICIRQStatus & (1 << VICIntSel_EINT2)) {
  VICSoftIntClr = (1 << VICIntSel_EINT2);
  VICVectAddr = 0;
void EINT3IRQ (void) __irq {//IRQ中断函数EINT3IRQ被挂接在VICVectCntl3
  if (VICIRQStatus & (1 << VICIntSel_EINT3)) {
  VICSoftIntClr = (1 << VICIntSel_EINT3);
  VICVectAddr = 0;
* fast interrupt function saves only R0 - R7 and returns with
void FIQ_Handler (void)    __fiq  {//VICIntSelect非0
unsigned temp;
  temp = VICFIQStatus;
  VICVectAddr = 0;
* task functions have no register save/restore and no return.
void tsk (void) __task {
  while (1);
* Sample 'main' function
int res;
void main (void)  {
  IODIR1         = (1 << P1_23) | (1 << P1_22) | (1 << P1_21) | (1 << P1_20)
                  |(1 << P1_19) | (1 << P1_18) | (1 << P1_17) | (1 << P1_16);//设置LED输出方式
  PINSEL0          |= (P0_14_EINT1 << P0_14_PINSEL) //选择P0.14为INT1外部中断引脚
//                     | (P0_7_EINT2 << P0_7_PINSEL)   //选择P0.7为INT2外部中断引脚
                     | (P0_15_EINT2 << P0_15_PINSEL); //选择P0.15为INT2外部中断引脚
//                     | (P0_9_EINT3 << P0_9_PINSEL)   //选择P0.9也为INT3外部中断引脚
//                     | (P0_1_EINT0 << P0_1_PINSEL)   //选择P0.1也为INT0外部中断引脚
//                     | (P0_3_EINT1 << P0_3_PINSEL);  //选择P0.3也为INT1外部中断引脚
  PINSEL1          |= (P0_16_EINT0 << P0_16_PINSEL) //选择P0.16为INT0外部中断引脚
//                     | (P0_20_EINT3 << P0_20_PINSEL) //选择P0.20也为INT3外部中断引脚
                     | (P0_30_EINT3 << P0_30_PINSEL);//选择P0.30也为INT3外部中断引脚(Keil仿真不了)
  EXTPOLAR       &= ~((1 << EXTPOLAR0) //INT0为低电平有效
                  |  (1 << EXTPOLAR1)  //INT1为低电平有效
                  |  (1 << EXTPOLAR2)  //INT2为低电平有效
                  |  (1 << EXTPOLAR3));//INT3为低电平有效
  EXTPOLAR       |= (1 << EXTPOLAR0); //INT0为高电平有效
  EXTMODE        |= (1 << EXTMODE0) //设置INT0为边沿触发
                  | (1 << EXTMODE2) //设置INT2为边沿触发
                  | (1 << EXTMODE3);//设置INT3为边沿触发
  EXTMODE        &= ~(1 << EXTMODE1);//设置INT1为电平触发
  VICVectCntl0   = VICIntSel_Enable//使能IRQ中断
                 | VICIntSel_EINT0;//获取EINT0的IRQ级别
  VICVectAddr0   = (unsigned long *) &EINT0IRQ;//取INT0中断服务地址
  VICVectCntl1   = VICIntSel_Enable//使能IRQ中断
                 | VICIntSel_EINT1;//获取EINT1的IRQ级别
  VICVectAddr1   = (unsigned long *) &EINT1IRQ;//取INT1中断服务地址
  VICVectCntl2   = VICIntSel_Enable//使能IRQ中断
                 | VICIntSel_EINT2;//获取EINT2的IRQ级别
  VICVectAddr2   = (unsigned long *) &EINT2IRQ;//取INT2中断服务地址
  VICVectCntl3   = VICIntSel_Enable//使能IRQ中断
                 | VICIntSel_EINT3;//获取EINT3的IRQ级别
  VICVectAddr3   = (unsigned long *) &EINT3IRQ;//取INT3中断服务地址
  VICVectCntl4   = VICIntSel_Enable//使能IRQ中断
                 | VICIntSel_SoftInt31;//获取VICIntSel_SoftInt31的IRQ级别
  VICVectAddr4   = (unsigned long *) &UserDefineIRQ;//取VicInt31中断服务地址
//  VICVectCntl0  &= ~VICIntSel_Enable;//放弃EINT0的IRQ级别,获取默认中断级别
  VICVectCntl1  &= ~VICIntSel_Enable;//放弃EINT1的IRQ级别,获取默认中断级别
//  VICVectCntl2  &= ~VICIntSel_Enable;//放弃EINT2的IRQ级别,获取默认中断级别
  VICDefVectAddr = (unsigned long *) &DefaultIRQ;//取默认中断服务地址
  VICIntSelect   = 0;//全部中断为IRQ中断或默认中断
  VICIntSelect   = (1 << VICIntSel_EINT0) //设置EINT0为FIQ中断
                 | (1 << VICIntSel_EINT1) //设置EINT1为FIQ中断
                 | (1 << VICIntSel_EINT2) //设置EINT2为FIQ中断
                 | (1 << VICIntSel_EINT3);//设置EINT2为FIQ中断
  EXTINT = (1 << EINT0) | (1 << EINT1) | (1 << EINT2) | (1 << EINT3);    //清除INT中断标志
//  VICSoftIntClr = 0xffffffff;//清除所有软中断标志
  VICSoftIntClr  = (1 << VICIntSel_EINT0) //清除EINT0软中断标志
                 | (1 << VICIntSel_EINT1) //清除EINT1软中断标志
                 | (1 << VICIntSel_EINT2) //清除EINT2软中断标志
                 | (1 << VICIntSel_EINT3);//清除EINT3软中断标志
  VICIntEnable   = (1 << VICIntSel_EINT0) //使能EINT0中断
                 | (1 << VICIntSel_EINT1) //使能EINT1中断
                 | (1 << VICIntSel_EINT2) //使能EINT2中断
                 | (1 << VICIntSel_EINT3);//使能EINT3中断
  VICIntEnable  |= (1 << VICIntSel_SoftInt31);//使能VICIntSel_SoftInt31中断
  SetVICProtection(1);//打开特权保护,阻止VICSoftInt软中断
  VICSoftInt     = (1 << VICIntSel_EINT0);//(VICIntEnable & (1 << VICIntSel_EINT0))使能才能软中断
  SetVICProtection(0);//关闭特权保护,允许VICSoftInt软中断
  VICSoftInt     = (1 << VICIntSel_EINT1);//(VICIntEnable & (1 << VICIntSel_EINT1))使能才能软中断
  VICSoftInt     = (1 << VICIntSel_EINT2);//(VICIntEnable & (1 << VICIntSel_EINT2))使能才能软中断
  VICSoftInt     = (1 << VICIntSel_EINT3);//(VICIntEnable & (1 << VICIntSel_EINT3))使能才能软中断
  VICSoftInt     = (1 << VICIntSel_SoftInt31);//(VICIntEnable & (1 << VICIntSel_SoftInt31))使能才能软中断
  res = myfunc1 (10, 2);          // call SWI functions
  res += myfunc2 (res);
  while (1);                      // endless loop
} 答 1: LPC213XDEF.H头文件/*----------------------------------------------------
文   件   名:  LPC213XDEF.H
创   建   人:  ARM菜鸟  HotPower@126.com
创 建 日  期:  2005.7.23   0:38
最近修改日期:  2005.7.23  10:38
创 建 地 点 : 西安大雁塔村队部
说       明 : 未经过硬件调试
#ifndef __LPC213xDEF_H
#define __LPC213xDEF_H
#define BV(val) (1 << val)
#define VICIntSel_Watchdog   0//看门狗中断(WDINT)
#define VICIntSel_SoftInt1   1//保留给软件中断
#define VICIntSel_DbgCommRx  2//ARM内核中断
#define VICIntSel_DbgCommTx  3//ARM内核中断
#define VICIntSel_Time0      4//定时器0中断
#define VICIntSel_Time1      5//定时器1中断
#define VICIntSel_UART0      6//UART0中断
#define VICIntSel_UART1      7//UART1中断
#define VICIntSel_PWM0       8//PWM0中断
#define VICIntSel_I2C0       9//I2C0中断
#define VICIntSel_SPI0      10//SPI0中断
#define VICIntSel_SSP       11//SSP中断
#define VICIntSel_SPI1      11//SPI1中断
#define VICIntSel_PLL       12//PLL中断
#define VICIntSel_RTC       13//RTC中断
#define VICIntSel_EINT0     14//系统控制外部中断0
#define VICIntSel_EINT1     15//系统控制外部中断1
#define VICIntSel_EINT2     16//系统控制外部中断2
#define VICIntSel_EINT3     17//系统控制外部中断3
#define VICIntSel_ADC0      18//A/D转换器0中断
#define VICIntSel_I2C1      19//I2C1中断
#define VICIntSel_BOD       20//掉电检测中断
#define VICIntSel_ADC1      21//A/D转换器1中断
#define VICIntSel_SoftInt22 22//保留给软件中断
#define VICIntSel_SoftInt23 23//保留给软件中断
#define VICIntSel_SoftInt24 24//保留给软件中断
#define VICIntSel_SoftInt25 25//保留给软件中断
#define VICIntSel_SoftInt26 26//保留给软件中断
#define VICIntSel_SoftInt27 27//保留给软件中断
#define VICIntSel_SoftInt28 28//保留给软件中断
#define VICIntSel_SoftInt29 29//保留给软件中断
#define VICIntSel_SoftInt30 30//保留给软件中断
#define VICIntSel_SoftInt31 31//保留给软件中断
#define VICIntSel_Enable    32//
  P0口GPIO位寻址位定义
#define P0_0  0//P0.0
#define P0_1  1//P0.1
#define P0_2  2//P0.2
#define P0_3  3//P0.3
#define P0_4  4//P0.4
#define P0_5  5//P0.5
#define P0_6  6//P0.6
#define P0_7  7//P0.7
#define P0_8  8//P0.8
#define P0_9  9//P0.9
#define P0_10 10//P0.10
#define P0_11 11//P0.11
#define P0_12 12//P0.12
#define P0_13 13//P0.13
#define P0_14 14//P0.14
#define P0_15 15//P0.15
#define P0_16 16//P0.16
#define P0_17 17//P0.17
#define P0_18 18//P0.18
#define P0_19 19//P0.19
#define P0_20 20//P0.20
#define P0_21 21//P0.21
#define P0_22 22//P0.22
#define P0_23 23//P0.23
#define P0_24 24//P0.24
#define P0_25 25//P0.25
#define P0_26 26//P0.26
#define P0_27 27//P0.27
#define P0_28 28//P0.28
#define P0_29 29//P0.29
#define P0_30 30//P0.30
#define P0_31 31//P0.31
  P1口GPIO位寻址位定义
#define P1_0  0//P1.0
#define P1_1  1//P1.1
#define P1_2  2//P1.2
#define P1_3  3//P1.3
#define P1_4  4//P1.4
#define P1_5  5//P1.5
#define P1_6  6//P1.6
#define P1_7  7//P1.7
#define P1_8  8//P1.8
#define P1_9  9//P1.9
#define P1_10 10//P1.10
#define P1_11 11//P1.11
#define P1_12 12//P1.12
#define P1_13 13//P1.13
#define P1_14 14//P1.14
#define P1_15 15//P1.15
#define P1_16 16//P1.16
#define P1_17 17//P1.17
#define P1_18 18//P1.18
#define P1_19 19//P1.19
#define P1_20 20//P1.20
#define P1_21 21//P1.21
#define P1_22 22//P1.22
#define P1_23 23//P1.23
#define P1_24 24//P1.24
#define P1_25 25//P1.25
#define P1_26 26//P1.26
#define P1_27 27//P1.27
#define P1_28 28//P1.28
#define P1_29 29//P1.29
#define P1_30 30//P1.30
#define P1_31 31//P1.31
  外部中断标志寄存器EXTINT位定义
#define EINT0 0//EXTINT.0//写'1'清除EINT0中断标志
#define EINT1 1//EXTINT.1//写'1'清除EINT1中断标志
#define EINT2 2//EXTINT.2//写'1'清除EINT2中断标志
#define EINT3 3//EXTINT.3//写'1'清除EINT3中断标志
  外部中断方式寄存器EXTMODE位定义
#define EXTMODE0 0//EXTMODE.0//该位为0时,EINT0使用电平激活;该位为1时,EINT0使用边沿激活。
#define EXTMODE1 1//EXTMODE.1//该位为0时,EINT1使用电平激活;该位为1时,EINT1使用边沿激活。
#define EXTMODE2 2//EXTMODE.2//该位为0时,EINT2使用电平激活;该位为1时,EINT2使用边沿激活。
#define EXTMODE3 3//EXTMODE.3//该位为0时,EINT3使用电平激活;该位为1时,EINT3使用边沿激活。
  外部中断极性寄存器EXTPOLAR位定义
#define EXTPOLAR0 0//EXTPOLAR.0//该位为0时,EINT0低电平或下降沿有效(由EXTMODE0决定)。
                               //该位为1时,EINT0高电平或上升沿有效(由EXTMODE0决定)。
#define EXTPOLAR1 1//EXTPOLAR.1//该位为0时,EINT1低电平或下降沿有效(由EXTMODE1决定)。
                               //该位为1时,EINT1高电平或上升沿有效(由EXTMODE1决定)。
#define EXTPOLAR2 2//EXTPOLAR.2//该位为0时,EINT2低电平或下降沿有效(由EXTMODE2决定)。
                               //该位为1时,EINT2高电平或上升沿有效(由EXTMODE2决定)。
#define EXTPOLAR3 3//EXTPOLAR.3//该位为0时,EINT3低电平或下降沿有效(由EXTMODE3决定)。
                               //该位为1时,EINT3高电平或上升沿有效(由EXTMODE3决定)。
  外部中断唤醒寄存器EXTWAKE位定义
#define EXTWAKE0  0//EXTWAKE.0//该位为1时,使能EINT0将处理器从掉电模式唤醒。
#define EXTWAKE1  1//EXTWAKE.1//该位为1时,使能EINT1将处理器从掉电模式唤醒。
#define EXTWAKE2  2//EXTWAKE.2//该位为1时,使能EINT2将处理器从掉电模式唤醒。
#define EXTWAKE3  3//EXTWAKE.3//该位为1时,使能EINT3将处理器从掉电模式唤醒。
#define BODWAKE  14//EXTWAKE.14//该位为1时,BOD中断产生时可将处理器从掉电模式唤醒。
#define RTCWAKE  15//EXTWAKE.15//该位为1时,RTC中断产生时可将处理器从掉电模式唤醒。
  GPIO管脚功能配置
应用示例:
  PINSEL0          |= (P0_0_TXD0 << P0_0_PINSEL) | (P0_1_RXD0 << P0_1_PINSEL); //选择P0.0和P0.1为UART0的输出输入引脚
或:
  PINSEL0          |= (TXD0 << P0_0_PINSEL) | (RXD0 << P0_1_PINSEL); //选择P0.0和P0.1为UART0的输出输入引脚
  PINSEL0          |= (P0_3_EINT1 << P0_3_PINSEL); //选择P0.3为INT1外部中断引脚
  PINSEL0          |= (P0_14_EINT1 << P0_14_PINSEL); //选择P0.14也可为INT1外部中断引脚
  PINSEL0          |= (P0_1_EINT0 << P0_1_PINSEL)   //选择P0.1为INT0外部中断引脚
  PINSEL1          |= (P0_16_EINT0 << P0_16_PINSEL); //选择P0.16也可为INT0外部中断引脚
注:由于INT0,INT1可配置多个引脚,故不能简化,必须指明引脚号
  PINSEL0          |= (EINT1 << P0_3_PINSEL);  //出错
  PINSEL0          |= (EINT1 << P0_14_PINSEL); //出错
因为P0_3_EINT1=3,P0_14_EINT1=2.故功能虽然相同,但功能序号不同!!!
#define P0_0_GPIO      0//通用数字输入输出管脚
  #define TXD0         1//UART0的发送器输出
  #define PWM1         2//脉宽调制器输出1
  #define P0_0_TXD0    1//UART0的发送器输出
  #define P0_0_PWM1    2//脉宽调制器输出1
#define P0_0_PINSEL    2 * P0_0
#define P0_1_GPIO      0//通用数字输入输出管脚
  #define RXD0         1//UART0的接收器输入
  #define PWM3         2//脉宽调制器输出3
  #define P0_1_RXD0    1//UART0的接收器输入
  #define P0_1_PWM3    2//脉宽调制器输出3
  #define P0_1_EINT0   3//**外部中断0输入
#define P0_1_PINSEL    2 * P0_1
#define P0_2_GPIO      0//通用数字输入输出管脚
  #define SCL0         1//I2C0时钟输入/输出。开漏输出(符合I2C规范)
  #define P0_2_SCL0    1//I2C0时钟输入/输出。开漏输出(符合I2C规范)
  #define P0_2_CAP0_0  2//***定时器0的捕获输入通道0
#define P0_2_PINSEL    2 * P0_2
#define P0_3_GPIO      0//通用数字输入输出管脚
  #define SDA0         1//I2C0数据输入/输出。开漏输出(符合I2C规范)
  #define P0_3_SDA0    1//I2C0数据输入/输出。开漏输出(符合I2C规范)
  #define P0_3_MAT0_0  2//**定时器0的匹配输出通道0
  #define P0_3_EINT1   3//**外部中断1输入
#define P0_3_PINSEL    2 * P0_3
#define P0_4_GPIO      0//通用数字输入输出管脚
  #define SCK0         1//SPI0的串行时钟。SPI时钟从主机输出,从机输入
  #define AD0_6        3//A/D转换器0输入6。该模拟输入总是连接到相应的管脚
  #define P0_4_SCK0    1//SPI0的串行时钟。SPI时钟从主机输出,从机输入
  #define P0_4_CAP0_1  2//**定时器0的捕获输入通道1
  #define P0_4_AD0_6   3//A/D转换器0输入6。该模拟输入总是连接到相应的管脚
  #define P0_4_PINSEL  2 * P0_4
#define P0_5_GPIO      0//通用数字输入输出管脚
  #define MISO0        1//SPI0主机输入从机输出端。从机到主机的数据传输
  #define P0_5_MISO0   1//SPI0主机输入从机输出端。从机到主机的数据传输
  #define P0_5_MAT0_1  2//**定时器0的匹配输出通道1
  #define P0_5_AD0_7   3//A/D转换器0输入7。该模拟输入总是连接到相应的管脚
#define P0_5_PINSEL    2 * P0_5
#define P0_6_GPIO      0//通用数字输入输出管脚
  #define MOSI0        1//SPI0主机输出从机输入端。主机到从机的数据传输
  #define P0_6_MOSI0   1//SPI0主机输出从机输入端。主机到从机的数据传输
  #define P0_6_CAP0_2  2//***定时器0的捕获输入通道2
  #define P0_6_AD1_0   3//A/D转换器1输入0。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_6_PINSEL    2 * P0_6
#define P0_7_GPIO      0//通用数字输入输出管脚
  #define SSEL0        1//SPI0从机选择。选择SPI接口用作从机
  #define PWM2         2//脉宽调制器输出2
  #define P0_7_SSEL0   1//SPI0从机选择。选择SPI接口用作从机
  #define P0_7_PWM2    2//脉宽调制器输出2
  #define P0_7_EINT2   3//**外部中断2输入
#define P0_7_PINSEL    2 * P0_7
#define P0_8_GPIO      0//通用数字输入输出管脚
  #define TXD1         1//UART1的发送器输出
  #define PWM4         2//脉宽调制器输出4
  #define AD1_1        3//A/D转换器1输入1。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_8_TXD1    1//UART1的发送器输出
  #define P0_8_PWM4    2//脉宽调制器输出4
  #define P0_8_AD1_1   3//A/D转换器1输入1。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_8_PINSEL    2 * P0_8
#define P0_9_GPIO      0//通用数字输入输出管脚
  #define RXD1         1//UART1的接收器输入
  #define PWM6         2//脉宽调制器输出6
  #define P0_9_RXD1    1//UART1的接收器输入
  #define P0_9_PWM6    2//脉宽调制器输出6
  #define P0_9_EINT3   3//***外部中断3输入
#define P0_9_PINSEL    2 * P0_9
#define P0_10_GPIO     0//通用数字输入输出管脚
  #define RTS1         1//UART1请求发送出端(仅用于LP138)
  #define CAP1_0       2//定时器1的捕获输入通道0
  #define AD1_2        3//A/D转换器1输入2。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_10_RTS1   1//UART1请求发送出端(仅用于LP138)
  #define P0_10_CAP1_0 2//定时器1的捕获输入通道0
  #define P0_10_AD1_2  3//A/D转换器1输入2。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_10_PINSEL   2 * P0_10
#define P0_11_GPIO     0//通用数字输入输出管脚
  #define CTS1         1//UART1清除发送入端(仅用于LP138)
  #define CAP1_1       2//定时器1的捕获输入通道1
  #define SCL1         3//I2C1时钟输入/输。开漏输出(符合I2C规范)
  #define P0_11_CTS1   1//UART1清除发送入端(仅用于LP138)
  #define P0_11_CAP1_1 2//定时器1的捕获输入通道1
  #define P0_11_SCL1   3//I2C1时钟输入/输。开漏输出(符合I2C规范)
#define P0_11_PINSEL   2 * P0_11
#define P0_12_GPIO     0//通用数字输入输出管脚
  #define DSR1         1//UART1数据设置就绪端(仅用于 LPC2138)
  #define MAT1_0       2//定时器1的匹配输出通道0
  #define AD1_3        3//A/D转换器1输入3。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_12_DSR1   1//UART1数据设置就绪端(仅用于 LPC2138)
  #define P0_12_MAT1_0 2//定时器1的匹配输出通道0
  #define P0_12_AD1_3  3//A/D转换器1输入3。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_12_PINSEL   2 * P0_12
#define P0_13_GPIO     0//通用数字输入输出管脚
  #define DTR1         1//UART1数据终端就绪
  #define MAT1_1       2//定时器1的匹配输出通道1
  #define AD1_4        3//A/D转换器1输入4。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_13_DTR1   1//UART1数据终端就绪
  #define P0_13_MAT1_1 2//定时器1的匹配输出通道1
  #define P0_13_AD1_4  3//A/D转换器1输入4。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_13_PINSEL   2 * P0_13
#define P0_14_GPIO     0//通用数字输入输出管脚
  #define DCD1         1//UART1数据载波检测输入(仅用于 LPC2138)
  #define SDA1         3//I2C1数据输入/输出。开漏输出(符合I2C规范)
  #define P0_14_DCD1   1//UART1数据载波检测输入(仅用于 LPC2138)
  #define P0_14_EINT1  2//**外部中断1输入
  #define P0_14_SDA1   3//I2C1数据输入/输出。开漏输出(符合I2C规范)
#define P0_14_PINSEL   2 * P0_14
#define P0_15_GPIO     0//通用数字输入输出管脚
  #define RI1          1//UART1铃响指示输入(仅用于 LPC2138)
  #define AD1_5        3//A/D转换器1输入5。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_15_RI1    1//UART1铃响指示输入(仅用于 LPC2138)
  #define P0_15_EINT2  2//**外部中断2输入
  #define P0_14_AD1_5  3//A/D转换器1输入5。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_15_PINSEL   2 * P0_15
#define P0_16_GPIO     0//通用数字输入输出管脚
  #define P0_16_EINT0  1//**外部中断0输入
  #define P0_16_MAT0_2 2//**定时器0的匹配输出通道2
  #define P0_16_CAP0_2 3//***定时器0的捕获输入通道2
#define P0_16_PINSEL   2 * P0_0
#define P0_17_GPIO     0//通用数字输入输出管脚
  #define SCK1         2//SPI1的串行时钟。SPI时钟从主机输出,从机输入
  #define P0_17_CAP1_2 1//**定时器1的捕获输入通道2
  #define P0_17_SCK1   2//SPI1的串行时钟。SPI时钟从主机输出,从机输入
  #define P0_17_MAT1_2 3//**定时器1的匹配输出通道2
#define P0_17_PINSEL   2 * P0_1
#define P0_18_GPIO     0//通用数字输入输出管脚
  #define MISO1        2//SPI1主机输入从机输出端。从机到主机的数据传输
  #define P0_18_CAP1_3 1//**定时器1的捕获输入通道3
  #define P0_18_MISO1  2//SPI1主机输入从机输出端。从机到主机的数据传输
  #define P0_18_MAT1_3 3//**定时器1的匹配输出通道3
#define P0_18_PINSEL   2 * P0_2
#define P0_19_GPIO     0//通用数字输入输出管脚
  #define MOSI1        2//SPI1主机输出从机输入端。主机到从机的数据传输
  #define P0_19_MAT1_2 1//**定时器1的匹配输出通道2
  #define P0_18_MOSI1  2//SPI1主机输出从机输入端。主机到从机的数据传输
  #define P0_19_CAP1_2 3//**定时器1的捕获输入通道2
#define P0_19_PINSEL   2 * P0_3
#define P0_20_GPIO     0//通用数字输入输出管脚
  #define SSEL1        2//SPI1从机选择。选择SPI接口用作从机
  #define P0_20_MAT1_3 1//**定时器1的匹配输出通道3
  #define P0_20_SSEL1  2//SPI1从机选择。选择SPI接口用作从机
  #define P0_20_EINT3  3//***外部中断3输入
#define P0_20_PINSEL   2 * P0_4
#define P0_21_GPIO     0//通用数字输入输出管脚
  #define PWM5         1//脉宽调制器输出5
  #define AD1_6        2//A/D转换器1输入6。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_21_PWM5   1//脉宽调制器输出5
  #define P0_21_AD1_6  2//A/D转换器1输入6。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_21_CAP1_3 3//**定时器1的捕获输入通道3
#define P0_21_PINSEL   2 * P0_5
#define P0_22_GPIO     0//通用数字输入输出管脚
  #define AD1_7        1//A/D转换器1输入7。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_22_AD1_7  1//A/D转换器1输入7。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_22_CAP0_0 2//***定时器0的捕获输入通道0
  #define P0_22_MAT0_0 3//**定时器0的匹配输出通道0
#define P0_22_PINSEL   2 * P0_6
#define P0_23_GPIO     0//通用数字输入输出管脚
#define P0_23_PINSEL   2 * P0_7
//#define P0_24_GPIO     0//P0.24 脚未用
//#define P0_24_PINSEL 2 * P0_8
#define P0_25_GPIO     0//通用数字输入输出管脚
  #define AD0_4        1//A/D转换器0输入4。该模拟输入总是连接到相应的管脚.D/A 转换器输出(仅用于 LPC2138)
  #define P0_25_AD0_4  1//A/D转换器0输入4。该模拟输入总是连接到相应的管脚.D/A 转换器输出(仅用于 LPC2138)
#define P0_25_PINSEL   2 * P0_9
#define P0_26_GPIO     0//通用数字输入输出管脚
  #define AD0_5        1//A/D转换器0输入5。该模拟输入总是连接到相应的管脚
  #define P0_26_AD0_5  1//A/D转换器0输入5。该模拟输入总是连接到相应的管脚
#define P0_26_PINSEL   2 * P0_10
#define P0_27_GPIO     0//通用数字输入输出管脚
  #define AD0_0        1//A/D转换器0输入0。该模拟输入总是连接到相应的管脚
  #define P0_27_AD0_0  1//A/D转换器0输入0。该模拟输入总是连接到相应的管脚
  #define P0_27_CAP0_1 2//**定时器0的捕获输入通道1
  #define P0_27_MAT0_1 3//**定时器0的捕获输入通道1
#define P0_27_PINSEL   2 * P0_11
#define P0_28_GPIO     0//通用数字输入输出管脚
  #define AD0_1        1//A/D转换器0输入1。该模拟输入总是连接到相应的管脚
  #define P0_28_AD0_1  1//A/D转换器0输入1。该模拟输入总是连接到相应的管脚
  #define P0_28_CAP0_2 2//***定时器0的捕获输入通道2
  #define P0_28_MAT0_2 3//**定时器0的匹配输出通道2
#define P0_28_PINSEL   2 * P0_12
#define P0_29_GPIO     0//通用数字输入输出管脚
  #define AD0_2        1//A/D转换器0输入2。该模拟输入总是连接到相应的管脚
  #define CAP0_3       2//定时器0的捕获输入通道3
  #define MAT0_3       3//定时器0的匹配输出通道3
  #define P0_29_AD0_2  1//A/D转换器0输入2。该模拟输入总是连接到相应的管脚
  #define P0_29_CAP0_3 2//定时器0的捕获输入通道3
  #define P0_29_MAT0_3 3//定时器0的匹配输出通道3
#define P0_29_PINSEL   2 * P0_13
#define P0_30_GPIO     0//通用数字输入输出管脚
  #define AD0_3        1//A/D转换器0输入3。该模拟输入总是连接到相应的管脚
  #define P0_30_AD0_3  1//A/D转换器0输入3。该模拟输入总是连接到相应的管脚
  #define P0_30_EINT3  2//***外部中断3输入
  #define P0_30_CAP0_0 3//***定时器0的捕获输入通道0
#define P0_30_PINSEL   2 * P0_14
#define P0_31_GPO      0//通用数字输出管脚(注意:此管脚仅为输出)
#define P0_31_PINSEL   2 * P0_15
//RSIR
#define RSIR          (*((volatile unsigned char *) 0xE01FC180))//
  #define POR          0//RSIR.0//POR信号有效时该位置位,并清除RSIR寄存器的其它位
  #define EXTR         1//RSIR.1//RESET信号有效时该位置位
  #define WDTR         2//RSIR.2//当看门狗定时器溢出和看门狗方式寄存器的WDTRESET位为1时,该位置位。
                                //该位可被其它任何一个复位源清除。
  #define BODR         3//RSIR.3//当3.3V的电源降到低于2.6V时该位置位
#endif  // __LPC213xDEF_H
答 2: ARM菜农浇水心得---"看书"不如"抄书","抄书"不如"撕书"好累呀...
村里"交通不便"---没ARM开发板,没ARM的书,没见过ARM的芯片,没...
创建LPC213XDEF.H头文件就费时进6个小时...
菜农无知没见过类似的头文件定义,但那些IO模块功能的链接写法实在太累,
一气之下决定自己创建,虽然累些,但没见过通过建立头文件也能对IO搞个456出来...
这样引用宏就方便多了,...
例如接个串口0,只需简单地写为:
PINSEL0 |= (P0_0_TXD0 << P0_0_PINSEL);//设置P0.0为TXD0引脚
PINSEL0 |= (P0_1_RXD0 << P0_1_PINSEL);//设置P0.1为RXD0引脚
例如接个SPI0,只需简单地写为:
PINSEL0 |= (P0_4_SCK0  << P0_4_PINSEL);//设置P0.4为SCK0引脚
PINSEL0 |= (P0_5_MISO0 << P0_5_PINSEL);//设置P0.5为MISO0引脚
PINSEL0 |= (P0_6_MOSI0 << P0_6_PINSEL);//设置P0.6为MOSI0引脚
可能有人会说: 这不更麻烦吗???为何不定义为:
PINSEL0 |= (SCK0  << P0_4_PINSEL);//设置P0.4为SCK0引脚
PINSEL0 |= (MISO0 << P0_5_PINSEL);//设置P0.5为MISO0引脚
PINSEL0 |= (MOSI0 << P0_6_PINSEL);//设置P0.6为MOSI0引脚
这样不更简单吗???
因为我暂时考虑通用性和多引脚链接某一个功能(如EINT3等)
以后我会将不重复的功能简化的,但也保留现在的"版本"...
研究了两天的ARM中断,收获很大,但也带来了更多的担心...
终于搞清了所有的中断寄存器的使用,心得都在提高班笔记中,它可以任意组合...
看来学习最好的方法就是"抄书"而非"看书","抄书"虽然很累,但收获将远远大于"看书"...
因为菜农没开发板,那么"抄书"肯定会升华为"撕书"... 答 3: ARM菜鸟中断系统安全之担忧最近论坛内有"风声"说LPC2132要淘汰AVR,就恶补了几天的Philips ARM.
经过农校的扫盲,首先选修了最烦人的IO配置和中断控制...
感觉IO无上拉电阻配置确实遗憾...估计和5V接口连接有关,也罢...
头痛的是IO功能配置的晕...还好,自己先创建了LPC213XDEF.H头文件止痛...
中断还不难,就VICVectCntlX,VICVectAddrX,VICDefVectAddr,VICIntSelect,VICIntEnable等几个寄存器瞎折腾...
都说中断退出前应该清除VICVectAddr,但我仿真时VICSoftInt对应位也应该清除.否则搞个VICSoftInt = (1 << VICIntSel_EINT0);就死翘翘了...
再者,ARM与MCU最大的不同是中断向量的存贮方式的不同,这也在工控中带来了质的不同!!!
MCU中断向量一般在ROM中存入中断的实际跳入地址,而ARM必须连接到具体的中断.即ARM中断地址实际上是在RAM中保存的,这样可能很容易受到干扰信号的攻击!!!
所以动态保护或恢复VICVectCntlX,VICVectAddrX等几个瞎折腾的寄存器就成了工控中的新课题...
MCU中的"千万不要在中断中喂狗"的"学说"就是基于MCU中断向量是存在ROM中不易受攻击的"理论"...
因为程序飞但MCU的固定中断程序地址是定死的,所以程序飞也能成功的进入定时中断...."MCU疯狗论"就会很容易地将其从死难的边缘救起...
而ARM的中断体制可能比MCU更加灵活但却带来了新课题所要付出的代价...
个人之忧,个人之虑,个人之意见... 答 4: ARM菜鸟心中的中断防御系统设想在Philips ARM的中断体系中,中断干扰应该主要侵入SWI,IRQ,FIQ这三个中断向量.
SWI比较好防御,但IRQ,FIQ确实很难防御...
但是FIQ的向量可以在编译时固定,虽然IRQ分支很多没定义VICVectAddrX或VICVectCntl未开放中断,但都会归入VICDefVectAddr.
这样我们就可以从FIQ_Handler()和DefaultIRQ()中拦截...
拦截模型:
unsigned temp;
  else {//其他干扰源
//再次填入干扰处理代码
  VICSoftIntClr = temp;//抗击无效VICSoftInt=XXX的入侵
  VICVectAddr = 0;
unsigned long temp;
  else {//其他干扰源
//再次填入干扰处理代码
  VICVectAddr = 0;
我并非主张将中断都在FIQ_Handler()和DefaultIRQ()中处理,而是在原设计上
"加高一层",以增强防御能力...
纸上谈兵,个人意见...
发表此说并非说ARM不如MCU抗打击,而是想如何去面对现实... 答 5: 佩服--为你的学习劲头,买块开发板吧,这对学习满有用的! 答 6: 哈哈,开发板对我没多大意思,纸上谈兵一样上战场这些玩意对我来说应该是喝凉水吧...
稍后继续分析... 答 7: ARM菜鸟终于在Keil里用上了C++心情很好,就是中断还暂时未搞定...不过已决定在ARM中放弃C语言编程... 答 8: 实际应用上FIQ只用一个中断源才可以体现出FIQ快速的优越性... 答 9: PIC的单中断向量的抗干扰能力可能这是重点之一 答 10: 期待菜鸟中断系统高级班学习笔记...中断嵌套...
uCOS-II... 答 11: 哈哈...终于水鸟快毕业了不急...慢慢忽悠...
