LPC213X,PWM LPC213X四路单边PWM模块应用源码
问
ARM水鸟 HotPower@126.com
2006.06.26 23:55 于西安大雁塔村队部
void PwmObj::OpenPwm(unsigned int worknum)
worknum &= 3;
PWM->PWM_PR = 0x00;
PWM->PWM_MCR = (1 << PWMMCRR0);
switch (worknum) {
case 0://CD1
PINSEL->PIN_SEL0 |= (P0_7_PWM2 << P0_7_PINSEL);// P0.7连接到PWM2
PWM->PWM_PCR |= (1 << PWMENA2);
PWM->PWM_MR0 = PwmSize;//16KHz (周期数=864)
PWM->PWM_MR2 = PwmStartSize;
PWM->PWM_LER = (1 << PWMLER2) | (1 << PWMLER0);
break;
case 1://CD2
PINSEL->PIN_SEL0 |= (P0_8_PWM4 << P0_8_PINSEL);// P0.8连接到PWM4
PWM->PWM_PCR |= (1 << PWMENA4);
PWM->PWM_MR4 = PwmStartSize;
PWM->PWM_LER = (1 << PWMLER4) | (1 << PWMLER0);
break;
case 2://CD3
PINSEL->PIN_SEL0 |= (P0_9_PWM6 << P0_9_PINSEL);// P0.9连接到PWM6
PWM->PWM_PCR |= (1 << PWMENA6);
PWM->PWM_MR6 = PwmStartSize;
PWM->PWM_LER = (1 << PWMLER6) | (1 << PWMLER0);
break;
case 3://CD4
PINSEL->PIN_SEL1 |= (P0_21_PWM5 << P0_21_PINSEL);// P0.21连接到PWM5
PWM->PWM_PCR |= (1 << PWMENA5);
PWM->PWM_MR5 = PwmStartSize;
PWM->PWM_LER = (1 << PWMLER5) | (1 << PWMLER0);
break;
PWM->PWM_TCR = 0x02;
PWM->PWM_TCR = 0x09;
void PwmObj::ClosePwm(unsigned int worknum)
worknum &= 3;
switch (worknum) {
case 0:
PWM->PWM_MR2 = 0;//PWM2
CDPORT->IOCLR = (1 << P0_7);
CDPORT->IODIR |= (1 << P0_7);
PINSEL->PIN_SEL0 &= ~(3 << P0_7_PINSEL);// P0.7连接到GPIO
break;
case 1:
PWM->PWM_MR4 = 0;//PWM4
CDPORT->IOCLR = (1 << P0_8);
CDPORT->IODIR |= (1 << P0_8);
PINSEL->PIN_SEL0 &= ~(3 << P0_8_PINSEL);// P0.8连接到GPIO
break;
case 2:
PWM->PWM_MR6 = 0;//PWM6
CDPORT->IOCLR = (1 << P0_9);
CDPORT->IODIR |= (1 << P0_9);
PINSEL->PIN_SEL0 &= ~(3 << P0_9_PINSEL);// P0.9连接到GPIO
break;
case 3:
PWM->PWM_MR5 = 0;//PWM5
CDPORT->IOCLR = (1 << P0_21);
CDPORT->IODIR |= (1 << P0_21);
PINSEL->PIN_SEL1 &= ~(3 << P0_21_PINSEL);// P0.21连接到GPIO
break;
void PwmObj::IncPwm(unsigned int worknum)
worknum &= 3;
switch(worknum) {
case 0:
if ((PWM->PWM_MR2 + 1) < (PWM->PWM_MR0 * 70 / 100)) {
PWM->PWM_MR2 += 1;
break;
case 1:
if ((PWM->PWM_MR4 + 1) < (PWM->PWM_MR0 * 70 / 100)) {
PWM->PWM_MR4 += 1;
break;
case 2:
if ((PWM->PWM_MR6 + 1) < (PWM->PWM_MR0 * 70 / 100)) {
PWM->PWM_MR6 += 1;
break;
case 3:
if ((PWM->PWM_MR5 + 1) < (PWM->PWM_MR0 * 70 / 100)) {
PWM->PWM_MR5 += 1;
break;
void PwmObj::DecPwm(unsigned int worknum)
worknum &= 3;
switch(worknum) {
case 0:
if (PWM->PWM_MR2 >= 1) {
PWM->PWM_MR2 -= 1;
break;
case 1:
if (PWM->PWM_MR4 >= 1) {
PWM->PWM_MR4 -= 1;
break;
case 2:
if (PWM->PWM_MR6 >= 1) {
PWM->PWM_MR6 -= 1;
break;
case 3:
if (PWM->PWM_MR5 >= 1) {
PWM->PWM_MR5 -= 1;
break;
答 1: 好大哥,让弟弟见识了。支持 答 2: 有没有C的代码啊???? 答 3: 能说一说其实现什么功能吗????它的方波频率是多少?
它的四路输出的频率是一样的吗???
你是怎么实现脉冲输出个数的计数的??
worknum &= 3;
PWM->PWM_PR = 0x00;
switch (worknum) {
case 0://CD1
break;
case 1://CD2
break;
case 2://CD3
break;
case 3://CD4
break;
worknum &= 3;
switch (worknum) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
worknum &= 3;
switch(worknum) {
case 0:
PWM->PWM_MR2 += 1;
break;
case 1:
PWM->PWM_MR4 += 1;
break;
case 2:
PWM->PWM_MR6 += 1;
break;
case 3:
PWM->PWM_MR5 += 1;
break;
worknum &= 3;
switch(worknum) {
case 0:
PWM->PWM_MR2 -= 1;
break;
case 1:
PWM->PWM_MR4 -= 1;
break;
case 2:
PWM->PWM_MR6 -= 1;
break;
case 3:
PWM->PWM_MR5 -= 1;
break;
它的四路输出的频率是一样的吗???
你是怎么实现脉冲输出个数的计数的??
| AG32VH407下光照强度传感器BH1750及其检测被打赏¥22元 | |
| AT32VH407下使用温湿度传感器DHT22进行检测被打赏¥20元 | |
| DIY一个婴儿澡盆温度计被打赏¥34元 | |
| 【FreeRtos】FreeRtos+MPU region 配置规则被打赏¥23元 | |
| 【分享开发笔记,赚取电动螺丝刀】三分钟快速上手驱动墨水屏(ArduinoIDE)被打赏¥28元 | |
| 【S32K3XX】LIN 通讯模块使用被打赏¥31元 | |
| 【FreeRtos】FreeRtos + MPU模块的配置使用被打赏¥32元 | |
